How to remove/replace spoiler
Discussion in 'Gen 2 Prius Main Forum' started by canbyprius, Feb 7, 2010.
  1. canbyprius
    canbyprius New Member
    Canby, OR
    Are there any detailed instructions or better yet, exploded parts diagram, for how the spoiler is attached to the hatch on a 2008 Prius? Someone hit our spoiler, and it's loose and rattling, but doesn't want to come off easily.
  2. Patrick Wong
    18,200
    6,479
    Start by pulling off the black interior trim panel on the hatch interior, it is held on with 11 blue plastic clips. Grab one corner with your hands and pull until it comes loose, then pull off the panel.
    There are four bolts and three plastic clips securing the spoiler. You'll probably have to remove the rear wiper arm and motor assembly to gain access to the bolts.
    Andyprius1 and Stratospaly like this.
  3. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    Supplementing what Patrick said:
    Sounds like one or more of the spoiler's 4 bolts and/or 3 clips is loose or broken.
    In addition to removing the rear lower interior panel with the 11 blue clips, you will also have to remove the rear upper interior panel (the narrow one behind the spoiler and the wiper arm motor assembly) which has 5 clips.
    Here's a link to TheForce's thread about his installing the Touring Edition spoiler on his Standard Prius:
    http://priuschat.com/forums/gen-ii-...touring-b-type-rear-spoiler-installation.html
    And here's a link to the Exterior chapter of the repair/service manual which includes instructions on removing and installing the spoiler (see pages ET-16 thru ET-18):
    http://www.hybrid-synergy.eu/Documents_2006/ET%20-%20Exterior.pdf
    1/10/11 EDIT: Because the above link to the Exterior chapter is no longer available, I've attached below a PDF of the Exterior chapter.
    Note that if you need replacement clips for the spoiler or the interior panels, I think you'll have to get them from your dealer (or other OEM parts vendor).
  4. canbyprius
    Canby, OR
    "Boo"
    Thank you, this is exactly what I was looking for!
  5. Boo
    5,051
    485
    97
    Flushing, NY
    No problem. Check your Private Messages. I sent you more stuff. Good luck.
  6. McKeeius
    McKeeius New Member
    56
    Redwood City, CA
    Hello,
    I would love to hear about if you were able to replace the spoiler and solve this issue.
    I have an '09 package 2, and I stupidly left the hatch open while working on the car, then backed it up to test something, and pried the spoiler off a little bit so it is loose on the left and right sides. Now if I press on it hard enough on either side, it seems to 'snap' into place, but it is no longer flush, and if I slam closed the hatch it unbuckles and makes noise when driving.
    I am trying to learn how to do more of this work myself, so I want to try to fully diagnose how much damage I did - clips or whatever, and possibly do it myself, or do it on the cheap - order the parts myself and take to a body shop.
    Let me know how your issue ended up working out. Thanks
  7. mikeross
    mikeross New Member
    NY
    2001 Prius
    Yes it is best if you take it to a body shop. I remember damaging the spoiler myself while I was trying to install it.
  8. WillR
    WillR New Member
    Durango, CO
    Boo and others: I had the misfortune of backing out of the garage with the rear hatch open and caught the spoiler on the garage door. The spoiler plastic is cracked at the bolt attachments. I would like to repair it rather than replace it. What kind of plastic glue would work to repair the breaks in the plastic?
    I tried removing the panels on the inside of the hatch with no luck so far. It was mentioned that one really has to force the clips loose, so I will be more forceful next time. Can I assume that I can replace any clips that break?
    Thanks!
    Will
  9. fossilfuel
    fossilfuel New Member
    25
    Manhattan Beach, CA
    Wow, this is exactly what happend to me recently. Not sure if I should have Toyota Dealer look/fix or a bodyshop. I doubt I can get insurance to pay for it. Seems like it can just pop/clip back in, but I am not too car savy so dont want to mess with it.
    Judahgolfs likes this.
  10. mamaloosa
    mamaloosa Junior Member
    Oklahoma City, OK
    I have done exactly the same thing; catching rear hatch open and catching it on the garage door. My dealer wants over $600 to replace the spoiler. That incluces $300 for a NEW spoiler, and $300++ to paint and install. My gripe is, there's NOTHING wrong with the spoiler itself; it just rattles. I'm assuming that's because the clips are broken or damaged. Can the clips be ordered and replaced by a body shop?
  11. born2pdl
    born2pdl Junior Member
    62
    Utah
    The bolts/nuts in the spoiler itsself must have been loosened or broken out. I'd remove the spoiler as described above, then buy some JB weld at any auto parts store. If the spoiler is distorted around the fastener mount, you may need to heat it up locally and manipulate it back into its original shape. Sounds like a Saturday afternoon project. Shouldn't be bad at all.
  12. jackjroadster
    jackjroadster New Member
    New York
    Hi. Does any one here have links to videos on how to replace a spoiler? thanks for any help
  13. jackjroadster
    New York
    I came across this one from how to replace a spoiler,but I think it's a general one so I having second thoughts. I was trying to look for other videos since my cousin from Alabama is asking for one. Could we rely on this even if it's a general one? thanks for any opinion.
  14. Kutanks
    Kutanks Member
    118
    MA
    Anyone know where to buy the touring spoiler?
  15. geethanr
    geethanr New Member
    Grayslake, IL
    Spoiler replacement Red 2010 Prius
    Hi Folks,
    Help needed. My wife broker the spoiler by backing out of our garage with the rear hatch open. I ordered a spoiler from parts.com. Can some tell me if this needs to be painted? My spoiler is black.
    And do I need to order any parts?? I could not find the green clips or the double-sided tape to order that I guess hold the spoiler in place.
    Thanks much,
    GMan
  16. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
  17. Rest
    Rest Active Member
    1,210
    53
    CA
    So just yesterday I backed my 2007 Prius out of the garage with the hatch open and it hit the garage door, just like others have done. Besides a small scratch on the spoiler, it's popped up a bit on the end. Something snapped and it won't sit flush in the rear with the hatch now, it also makes noise while driving.
    I'm going to have to keep it and try to repair it myself, because I just can't get over how expensive it is to replace or get repaired. I was thinking about repainting the rear deck spoiler anyway due to paint weathering, the rest of the car is fine. I just need to remove it, repaint it, replace the broken clips and reinstall it. Doesn't look that easy though, I have to find the correct paint color and replacement clips.
  18. tyang54
    tyang54 Junior Member
    Santa Clara, CA
    If you go to parts.com choose : Toyota>Prius>Touring (or Base)>Body hardware>Lift Gate>Spoiler you can order a new spoiler $248.78. It is not clear what color you get or if you have to paint it later.
    I had the same encounter with the garage door while the hatch was open and was able to repair it with minimal cost.
    The trick was to make sure that the metal underneath was bent bent back to its original shape. When the spoiler pulled loose it actually bent the metal into which the spoiler was bolted. The spoiler clips were not connecting because the bent metal lifted the spoiler higher than it should have been. Once the metal was pounded back down, the spoiler fit down flush and the clips locked into place.
    I managed to break off one of the plastic female ends of the clip and ended up using JB Weld to glue it back in place.
    metal is pulled out...
    make sure this metal is flat with the surrounding
  19. Rest
    Rest Active Member
    1,210
    53
    CA
    Finally got around to fixing my rear spoiler. Had to buy two rivet clips ($3 each) from the dealership, for each end of the spoiler. Also, if I had known to use a trim panel tool to pop off the trim clips and not to pull the panel off by hand, I wouldn't have had to use plastic epoxy on one of the trim female clip ends that I broke.
    I've read where others have said to remove the rear wiper motor to get to one of the spoiler bolts, even a removal schematic says to do this. However, I didn't have to do this at all as none of the bolts were under the motor. So I'm confused why others have had to remove this motor.
  20. billh
    billh Junior Member
    27
    cleveland
    FYI; I had my hatch open in the garage, garage door open. Wife came home and hit the door opener, not realizing it was already open, then as she pulled in saw it closing and reopened. As it went back up it caught the hatch. Well you know how that doesn't work. But I got a very easy and inexpensive fix. Scotch has velcro like fasteners but much more rigid and stronger. I mushed the two fastener parts together and removed the tape exposing the glue surfaces top and bottom. Pushing up on the wing gave me just enough room to slide the fastener into the gap. the Fasteners hold well, although the wing is slightly higher (maybe 3/16") than original. The annoying rattle on hitting bumps and closing the hatch is gone, and with the hatch closed you would really not see the difference. Total cost about $3.00. Time to repair about 5 minutes.
    Andyprius1 likes this.
