Less weight, better mileage
Discussion in 'Gen 3 Prius Main Forum' started by zeke, Nov 12, 2010.
  1. zeke
    zeke New Member
    28
    NW PA
    I found a way to decrease the weight of the car while backing out of the garage with the hatch open.
  2. Blackmamba
    Blackmamba New Member
    113
    usa
    Better yet, just take a **** before you start driving. That's ~5 lbs. No joke.
  3. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    + or - 5 lbs...are you serious? No way! not even a piss and a poop would equal that much unless you are a sasquatch. Even with a Dr Oz approved coiler, you cannot achieve a 5 pound hot squat. Maybe Dr Fusco will chime in on this one? But I can't believe that is not a joke. My guess would be 2 pounds max, much less for a man of normal weight. Probably one pound for even the most corpulent women out there.....sheesh. Talk about hypermilers...oy vay SCHMEAR =)
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    So what kind of numbers are you seeing now? Increase of 2, 3 mpg?
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Ya know, I could tell you a story about something like that. Not quite that bad, but very similar.
    If don' see spoiler in rearview, don' back out :)
    Side note - a way to decrease weight, increase FE - when 'empty', fill with only 4 gallons, or less :)
  6. Blackmamba
    113
    usa
    Lol ok maybe 3-4 pounds. Eat a big meal. Weigh yourself before you need to use the bathroom. Go. Weigh yourself after.
    I think I'll try it tonight too.
  7. fuzzy1
    10,481
    The numbers I've seen indicate a maximum bladder capacity of a liter or less, the same for men and women. That is consistent with 2 pounds.
    The typically used volume is much less, and men and women differ.
  8. max2prius
    max2prius Junior Member
    85
    Walnut Creek, CA
    1 Liter bladder + Large dump = 4 pounds Max! :)
  9. kremlin
    kremlin Prius is a religion, not a car
    Maine
    Intellectual Priussians... what a discussion!! I am so proud to be a part of this crowd! I guess there is nothing else that bothers them more in this life: time to write a research on the weight of human waste. Or simply "google" it...
  10. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    So if less weight = better fuel economy how come the GIII is 10% better than the GII, even though it's heavier (by 100-200 lbs). ;)
    There is more to fuel economy than weight grasshopper!
  11. Blizzard10
    Blizzard10 New Member
    168
    Queens, NYC
    There is no bladder in a Gen III
  12. fuzzy1
    10,481
    There is when I am driving. And there is another one when a passenger is riding.
    My condolences on your medical condition requiring a urinary collection bag. But can't that also be called a bladder?
    No one in my household enters a car with anywhere near that much load. In fact, I don't think the accumulated load reaches much over 1/4 pound before I am ordered to make an emergency pit stop.
  13. Much More Better
    Much More Better Active Member
    655
    163
    This thread has turned to sh**.
  14. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I can't believe more than one person has done this! How could anyone miss the fact the hatch is open??
  15. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    They probably keep the car clean, and window spotless.
    Bad idea :p
  16. Flaninacupboard
    1,297
    213
    Midlands - UK
    But i'm pretty sure you get not only a red warning icon on the dash, but also a loud beeping noise if you try and drive with any of the doors open!
  17. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Ouch that looks expensive. :(
    You're not the only one though. I reversed mine into the garage door when the hatch was open and the car was only a week old! Luckily no damage that didn't buff out.
  18. ManualOnly
    ManualOnly New Member
    193
    28
    There goes your cd 0.25
  19. Blackmamba
    113
    usa
    I'm lowerinbg my car in like a month. It'll be raked. 1.4" in front, .7" back. I'll tell u if that actually improves mileage.
  20. jayrider
    jayrider Member
    163
    17
    southwest illinois
    If you really want to reduce weight then only keep the fuel pips at 3-4 max. More frequent fillups but better mpg. What's your priority ---- mpg or time.
