650miles in one tank
Discussion in 'Gen 2 Prius Fuel Economy' started by asinn, Oct 21, 2005.
  1. asinn
    asinn New Member
    Hi guys,
    I live in Australia, I just broke my prius record on reaching 1100km (680mile) in one tank. anyone here had even better result before?
    I used to only get around 900km (560miles) however, since i have added acetone in the fuel (I use 98ron fuel in aus) the fuel economy improve quite alot.....
    i am very happy with the fuel economy now, espeically in a time of high petrol prices ^_^
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Try alternating acetone vs. non-acetone tanks, for at least five
    full cycles, and then report back with hard numbers.
    _H*
  3. Tideland Prius
    16,653
    Cool!
    Post it in the "I Beat The EPA" thread hehe.
  4. asinn
    asinn New Member
    I have been using acetone for 3months now, i am very happy with it, I found the acetone does give better fuel economy, but it doesn't not have the same effect as my other car, mini cooper S.
    The mini improved from 480km a tank to 580km a tank, and with the prius, i was averaging around 870km per tank if lucky 900km, however after acetone, i have been getting around 950+, and last week i broke my record and got 1100km.
  5. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    what is the forumla you used how mush acetone per ten gallanes of gas ???
  6. asinn
    asinn New Member
    I add around 100-110ml of acetone per full tank.....
    i don't know how much is that in gallon
  7. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    When Toyota recommends acetone, I'll use it. Not before.
    My MPG has been 67 averaged over the past 10 tanks. Regular petrol, thanks.
  8. Canadian Eh
    Canadian Eh New Member
    Ontario, Canada
    How many litres does your tank take to fill? I use acetone as well, 60ml for 35 litres which is a full tank. I only get 650 to 700 Km to a tank. My display tells me that I am averaging 5.0 L/ 100Km. Also what grade octane do you use?
  9. asinn
    asinn New Member
    I use 98 octane fuel (BT or Shell)
    I usually drive till the tank is pretty much empty...... then i go fill it up..... at once stage i filled my prius up for 50L, I know prius say its a 45L tank........ but i filled it up to the max top....
    and i add around 100ml to my tank...... i used to put 120ml....... but i found 100ml give even more mileage.
    also i pump my tire pressure to the High Speed recommeandation.
    i don't drive on highway much....... once i drove a few hundred km @ around 110km/h.......... the fuel economy went up from 4.8l/100km to 5.6l/100km
  10. Canadian Eh
    Ontario, Canada
    The most I filled my tank was 38L. Here in Canada the most octane you get at the pumps is 94 octane. I use Shell as Shell does not use ethanol in their fuel. I have not yet come to any conclusion in regardes to the use of Acetone in the fuel. I purchased Acetone from The Home Depot, however I have been told that it must be 100% Acetone. Some manufactures "cut" the Acetone which leaves it at less than 100%. So my next visit to my Aunts in the wonderful USA, I will stop at Walgreens and get 100% Acetone and try it as well.
  11. asinn
    asinn New Member
    I used to only able to fill 40L in my tank..... and the pump will automatcally stop....
    i don't know the canda prius spec is..... but here is Aus, the prisu doesn't comes with a fuel tank flip, as in where the petrol bump hose go into the opening of the petrol tank, there isn't any metal flip part ......... so what i do is...... (during tuesday, when the petrol is cheapest in Sydney) I fill my car to the maxium top using the normal way........ then after the pump stop, i take out the petrol hose out of the tank opening...... so you can actually see the petrol flowing into the tank.... if you fill you tank slowly this way..... it will fill it up all the way to the top of the reserve tank......
    I have tried driving the car nearly 70km after the light start to flash..... and i end up filling up 54L at the pump...... this is why i was able to do 1100km last month.... pretty cool.... don't need to visit the petrol station for 6-7weeks
  12. Lather
    Lather New Member
    27
    I don’t know for sure but isn’t the fuel pump located in the gas tank? If it’s cooled by the gas, aren’t you occasionally overheating it?
  13. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    That is Super mileage! What is your driving technique, average speed, # of trips per day, length of trip. ty Looks like 100ml= 3.38 ounces (US)
