Audio and map screen
Discussion in 'Gen 3 Prius Audio and Electronics' started by tabasco, Nov 16, 2010.
  1. tabasco
    tabasco Junior Member
    Virginia
    Is there a way to keep the screen on map and still have the audio show? I tried this with dual screen but it only appears to stay in maps when I do this. I find myself switching to audio often so I can see what song is playing on xm.
  2. metro-mike
    metro-mike Junior Member
    53
    Tacoma WA
    I RTFM last night as I just bought my 2010 IV and it talked about when you are on the audio screen you can set it to be the main screen. It is talked about on the last 10 pgs or so in the FM.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The Nav system defaults to the MAP screen after 20 seconds. If you do not want to automatically switch back to the MAP screen, go to SETUP and select GENERAL. Then select AUTO SCREEN CHANGE and select OFF. Then it will remain on the screen selected until changed manually.
    Page 236 in the NAV manual.
  4. tabasco
    Virginia
    Let me be clearer . . . I would like to have the map screen plus the audio screen at the same time and on the same screen. Is this clearer?
  5. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    Quite clear, and with a simple answer - no. If you're viewing the map screen there's no way to see the audio information (except volume while you're changing it). And if you're viewing the audio screen there's no way to pop up the map on the same screen as a split display.
    You just have to live with pushing the "MAP" and "AUDIO" buttons next to the display to show one or the other.
  6. fmi
    fmi Junior Member
    24
    Phoenix
    He should be thankful he doesn't have to pull out an atlas and work the tape deck.:D
  7. mgschal
    mgschal New Member
    Oregon
  8. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    On a 2012 Prius 4 w/ solar and thus 7.1 Nav this doable.
    As stated turn off up auto screen.
    Then with map screen up,, press map mode button and select screen you want. I have mine split as requested often
  9. RaZa
    RaZa Member
    480
    93
    o_O
    Unless you change the split screen mode to show both the map and audio... I've done this myself and it seems to work fine except I can't stand looking at the ugly map on the nav. I only ever have the audio screen up on mine now. I'd be happier if the stupid unit didn't even have a nav.
