keeping one of the aux power sockets live on 2010 model
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Earman, Aug 30, 2010.
  1. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Pulling everything apart and running wires to the battery is a bit of a PITA (to put it mildly).
    Why not get an 800w inverter ($50), install it near the battery, then just run an extension cord up front. The added bonus is all the other stuff you can run/charge (laptops etc).
    I run a 1500w ($100) inverter near the battery (always on), and just have an extension cord running up front under a seat. We've even run full PCs with monitors in our Prius (long trip - good chance to load and configure software - which in today's world can take a day)...
  2. Earman
    Earman CDN Prius III Technology Blue
    78
    Vancouver, BC, Canada
    It is only one watt so it won't recharge the battery but it will provide a trickle charge sufficient to keep it's full charge while in storage. The rear window is slightly tinted (original) I did not add any extra film on it.
  3. alanderego
    alanderego Member
    87
    26
    Honolulu, Hawaii
    Thanks for the great posts.
    Does anyone have the wiring diagram for the center console power outlet?
    I did the same in our 06 Ridgeline and 07 Odyssey.
    That was simple.
    You just remove the relay and insert a jumper in place.
    I am just wondering if the Prius has one as well.
    Thanks,
    Alan
