Gas smell on start up - 2003
Discussion in 'Generation 1 Prius Discussion' started by z_clark, Nov 23, 2010.
  1. z_clark
    z_clark Junior Member
    DFW - TX
    2003 Prius
    2003 model with 150K miles on it.
    Six hundred miles ago, the gas read almost empty at 250 miles but only took 5 gallons. The gas reminder chimed and the display showed a empty tank.
    Three hundred miles ago a check engine light came on. The dealer said it needed a new catalytic converter for $1500. We had the code cleared and did not replace the cat.
    Car ran great for a few days, but then the smell of gas was inside.
    Took back to dealer where they checked fuel lines, injectors, vapor recovery, and for a plugged up exhaust or catalytic converter. They found no solution, but had no problem recreating the gas smell. They gave the car back still smelling of gas!
    This smell is mainly on start up (when motor is running) or stop and go (when motor is running). The smell is only when the vent is on and not on recirculation.
    The dealer's advice was "Keep it on recirculation"..... I am driving it, but let's just say I have a fire extinguisher in the car, running shoes on, and my full coverage insurance up to date.
    HELP!!!! "Keep it on recirculation" can't be the answer. This dealer has been great until now. They are a large dealer in the DFW area, so they work on many Prius.
    Thanks for reading and any help.
  2. Patrick Wong
    18,200
    6,471
    1. Did you verify that the engine oil cap is installed tightly?
    2. Make the Prius READY, turn on the AC and depress the MAX AC button to force the gasoline engine to run, spinning the AC compressor. Inspect the injectors and fuel lines, looking for the leak.
    3. If there's no obvious problem, I recommend that you take your car to another dealer. The fuel line is under pressure, at least 43 psi, and there must be a very small leak somewhere. Good luck.
  3. bwilson4web
    15,511
    Ok, the cabin air intake is located on the passenger side of the car under the shield that holds the wipers. You can see where I've snaked a data cable into the cabin:
    It sounds as if the gas vapor purge line has a leak (or fallen off). Another, more disturbing possibility is a leak in the fuel injector lines. Regardless, given the effects of gasoline fumes, I believe this is a serious problem that needs diagnosis and correcting.
    Suggestions:
    1. Nose detector - with the hood open, rig up a plastic tube so you can 'sniff' the air at the other end. Start the car and using the tube find the strongest source of the gasoline odor. In a perfect world, a small pump exhausting the air from the tube works best and you may want to tape the free end to a small stick or cardboard tube so you can put it where you want it to go. The idea is to keep your body out of the compartment but detect where the odor comes from. Likely candidates: (1) PVC valve area; (2) fuel injector feed lines, and (3) evaporation lines that go to the manifold, air cover and throttle areas.
    2. ScanGauge - most of the emissions systems are operated by the HV ECU and the ScanGauge has the ability to read out the diagnostic codes. Consider the $150-175 as not only a diagnostic tool but in the future, a tool for improving vehicle performance. Do build the adapter that w2co, vincent1449p and I figured out or send me a PM.
    3. Find another mechanic - either another Toyota shop or independent. Sad to say, I don't know of any independent shops but there are some helpful Texas Prius owners who might be able to 'lend a wrench.'
    I forgot to ask, what level of technical stuff with a car do you feel comfortable?
    • Change flat tire?
    • Change oil, wipers, plugs, or 12 V battery?
    • Rebuild the engine and tranny?
    The reason I ask is I want to communicate effectively and chat with you about the options. Where more details are needed, provide them. Where somethings can be assumed (aka., you have a VOM and set of metric wrenches) not post something that might seem obvious..
  4. z_clark
    DFW - TX
    2003 Prius
    Bob,
    THANKS!!!
    I never even thought of building a sniff tester to try to isolate it. I will be doing this tonight!!!
    I'll also look into the scan gauge.
    My mechanical abilities are decent....plugs / oil / replace belts / etc. No major stuff.
    I'll report back when I come to a conclusion. Thanks again!
  5. z_clark
    DFW - TX
    2003 Prius
    FOLLOW UP:
    The problem was the injectors. Two of them were leaking very slightly.
    Our Toyota dealer was unable to figure it out after 2 trips and leaving the car there for multiple days. We took it to our local Good Year mechanic who found the problem very quickly. We use Good Year for all non hybrid issues, and are always happy.
    We had Good Year (Blagg Tire in Grapevine TX) replace all of them.
    Thanks for the help. I'll update if any thing changes.
  6. z_clark
    DFW - TX
    2003 Prius
    Update:
    My follow up was to quick.
    The smell is still there on start up and heavy acceleration.
    We have been told
    1. An intake valve is sticking open, letting fumes by.
    2. Not a safety hazard.
    3. Fuel additives may help
    Does this sound correct? I have a hard time believing that fumes could get past the gasket an into the cabin so quickly.
    We don't plan on doing the valve work because of the cars age and value. We hope to drive it for another year as is, or until we can find a good deal on a used gen 2.
  7. Patrick Wong
    18,200
    6,471
    I suspect an exhaust system leak or another fuel system leak. I think further investigation is required. A gasoline odor should never be ignored.
    I doubt that a "sticking" engine intake valve would cause this problem. If in fact the valve remained partially open during the compression, power and exhaust cycles, you would notice significant engine backfire and driveability issues.
  8. z_clark
    DFW - TX
    2003 Prius
    Follow up:
    We had toyota replace the catalytic converter for $1500, owch! The problem still persists. We were told to put some miles on it "to let it burn off". After a tousand miles, the gas smell is still the same as it alwasy has been. It may be getting worse, as you can smell it outside the car at times too.
    We have dumped $3K into this and are very frustrated. The car has been to the dealer 6 times, to Goodyear 3 times with no improvement. It has not caugh fire yet, but I almost wish it would!
    We will probalby be replacing it with a gen 2 sooner than we wanted. Not sure how a trade in will be possible, as our 2003 reaks of gas. We may try at Grapevine Toyota, as they are the ones that can't seem to fix it after 6 trips and big $, so maybe they will offer something for a trade in. Very frustrating.
    Any advice appriciated. I mainly wanted to follow up, and rant for a bit. We love our gen 1, and would really like to keep it in the family for another few years. :(
  9. Patrick Wong
    18,200
    6,471
    I recognize that your car has been serviced 9 times total for this issue and the persistence of the problem is very upsetting.
    I am wondering whether anyone put a fuel pressure gauge on the fuel rail? The spec is ~43 psi. After the car is made IG-OFF, the remaining fuel pressure is supposed to remain unchanged for at least 5 minutes. Has that been checked?
    Have you been able to determine whether the fuel smell comes from the front of the car (i.e., the engine) or the rear of the car (i.e., the fuel tank)?
  10. z_clark
    DFW - TX
    2003 Prius
    Patrick,
    I really appreciate your response.
    I have been told that all fuel lines have been checked. Perhaps I should ask the specific question about using pressure gauge, as I was just assuming they did.
    The smell is from the front, under the hood.
    Toyota has told us "it will not catch fire", but we are not buying it. I bet they wouldn’t put that in writing...haa haa... :eek:
    We have thought about taking it to another dealer. We are not wanting to start at step one again, but different eyes may be what is needed. Really don't want to get rid of our Gen 1, we love that car!
    Thanks again for any continued advice, it is much appreciated.
  11. Patrick Wong
    18,200
    6,471
    OK, then you can eliminate the fuel tank plumbing as a source of the gasoline leak.
    I think it would be good to see if the fuel line pressure will be maintained when the engine is turned off. If the pressure drops, then maybe both of the original remaining injectors should be replaced (as you say that two were replaced in post #5.)
    When the car is IG-OFF, you might remove the engine air filter housing cover and then lift out the air filter. Open the throttle plate by rotating the spring-loaded shaft. Now you can look into the intake manifold.
    Do you find that the gasoline smell is especially strong, coming from the intake manifold? If so that might be a further clue that an injector is leaking fuel into the intake manifold. The fuel smell could pass through the air filter housing into the engine compartment.
