Hatchback hard to open in cold weather??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SmokeyBear, Nov 25, 2010.
  1. SmokeyBear
    SmokeyBear New Member
    Orem, Utah
    Anyone else have this issue? This is the second year I've owned my 2007 Prius, and it seems to be getting worse.
    In the summer, the hatch will open with ease! The handle recognizes my hand there and unlocks the hatch and whammo bammo we're in business. In the winter, especially the really really cold weather like we're having now (down to about 10 over night) the hatch refuses to open.
    Now, I am a big guy. About 6 foot and 280lbs, I must be applying close to 200lbs of force on that thing before it finally pops open. If the sun has been shining on the back of the car, and the weather is above about 40, it will open fine. On a hot July day, it'll open with about 5 lbs of force on it. Winter is a different animal. There is no way in Hades my 130 lb wife is ever going to open the hatch to get the dog in there..
    I spoke with the dealership and they thought I was from Mars.
    Anyone else have this issue? If so, is there a remedy? :confused:
    Thanks!
    Matt
  2. Tideland Prius
    16,664
    Did you try oiling it? It is harder (my 2010 won't even open on its own when it's well below freezing) but that seems a little excessive.
  3. Patrick Wong
    18,210
    6,517
    Maybe the two hatch struts need to be replaced.
  4. qbee42
    3,081
    Is the hatch unlatching? Assuming so, try using some silicone on the rubber seals. It helps keep them from sticking to the car body.
  5. jayrider
    jayrider Member
    163
    17
    southwest illinois
    You need new struts. The pressure in them is shot and it becomes apparent in cold weather. Had that issue several times with other cars. New struts will fix the problem. Can't believe the dealer didn't recommend changing them. They should be available at the big autoparts chains. Easy swap out -- they may do it for you for free in the parking lot.
  6. stephen2002
    stephen2002 Junior Member
    I've had this issue too. It seems like the latch gets stuck. I find that if I release it and pull the again it'll open. Sometimes I have to do this a couple of times before it'll release. It only tends to do this to me if it has been a while since I've opened the hatch.
    I have also noticed the weather seal does tend to stick in the winter.
  7. SmokeyBear
    Orem, Utah
    Thanks for all the replies guys! This place is awesome.
    For those who suggested new struts.. Those are the 'shocks' that raise the hatch door right?
    If so, that's not the issue here. I should have been more clear in my first post, sorry.
    Its the unlocking mechanism in the door itself. Once I can get the door to open, the hatch will raise up no worries, but it's getting it to open in the first place. It's the little black button thing that you push up on, and it recognizes the key fob in your pocket, and unlocks the hatch, then unlatches it so it will open. That's my issue. When it's cold it's next to impossible to get that button to depress far enough to get the hatch to unlatch. In the summer when it's warm, it's not an issue. It will depress easily.
    And just to be extra clear, I'm not talking about the tiny black button that locks the car. It's where you'd put your hand and push up to get the hatch to pop open before the struts raise the door up.
    Is that any better? Sorry for not clarifying that in the first post.
    So.. Anyone have that issue I'm talking about?
  8. SmokeyBear
    Orem, Utah
    This is close, I have had this same issue you're talking about.. However my issue is getting it to unlatch the original time before it can get stuck and require a second pull. It's like my latch release button is freezing up.
  9. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    My 08 frequently needs two pushes of the fingers on the rubber latch to open. The first push pops the hatch and then it needs a second push to fully unlatch. Kind of like a secondary hood latch. I just figured that was normal as mine does it most of the time. I have also had the hatch stick more firmly when its been colder, but due to my location that hasn't been a problem. I would suspect some minor misalignment of the latching mechanism. I don't know if this is adjustable or not. It hasn't been enough of a problem here to bother investigating.
  10. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Careful with the replacement.
    I remember finally needing to do that on my first hatchback... an '84 Omni! :eek:
    I suggest only one at first. Two made it difficult to close. The restored pressage actually worked too well.
  11. Patrick Wong
    18,210
    6,517
    Well, if your concern is just the hatch opening switch, that is easy and inexpensive to DIY replace, and I have posted on how to do so.
    If your concern is smooth operation of the hatch lock, try spraying some WD-40 down into the hole where it lives. Move the mechanical hatch lock release which you can find hidden behind the small rectangular access port in the black plastic tray over the spare tire. Maybe that will free up the lock.
  12. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Is it trying to unlatch and failing to do so fully? Or is it not unlatching every time you push the switch? If the latter, then maybe you're keeping the fob in an outside pocket where the battery in it is getting colder and not working well, or it's in an inner pocket and the extra shielding of your winter outer clothing is interferring with the signal, maybe?
  13. SmokeyBear
    Orem, Utah
    This is the closest answer so far..
    If it were an alignment issue with the latching mechanism though, what would explain the ease in warm weather, and pain in the bum in sub zero temps? Just a simple expansion/relaxation of the metal in warm and cold weather??
  14. SmokeyBear
    Orem, Utah
    Since I'm really new here, is there any way you could point me in the direction of this DIY project? I am convinced it's just the opening switch, or something to do with it. I see there are a couple screws in there, but I am yet to take it apart.. Thought I'd ask first. I've learned before that with some things, it's best to ask before doing.
    Thanks for the replies guys... keep em coming.
  15. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    It opens slowly in 50 degree Calif weather. Then I lean in and bang my head thinking it's fully open. The Gen III does not yet have this problem. WD40 did not help.
  16. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    The problem with removing the original screws holding the hatch
    release switch may have to do with all cross-head screws not being the
    true Phillips head type. For example:
    One obvious issue is the "blades" on the true Phillips are parallel sided,
    whereas on the other types the blade sides are tapered towards the tip.
    However, most likely, the difficulty comes from a particular cross-head
    screw type originating in Japan:
    My experience is with a medication dispensing machine made by
    Yuyama of Osaka Japan. After servicing almost everything medical and
    laboratory related, and up until 6 years ago I had never even known
    about other kinds of Phillips, then during the service training on these
    units along came JIS as they called it. Each screw has a dimple which I
    take to understand to indicate that the cross-point head is not a
    Phillips. The screws are also metric for sure.
    We're using JIS screwdrivers available at RC Helicopter hobby shops as
    that is a common problem with the RC Toys. Most helicopter blades
    appearantly are held on by JIS screws. Phillips just tears the recess
    apart.
    Further I hunted the net to see about the ISO cross-point screws you
    mentioned. I can't find them anywhere, just nothing. I did find a lot
    about ISO metric threads. But never in reference to the head drive
    recess. Also nothing about ISO screwdrivers as I'd expect.
    I'm almost sure what you refer to as Eiki ISO screws were actually JIS-
    Type screws with ISO metric threads. Two ways of saying the same
    thing basically. Similar to if I'd call them Yuyama ISO screws.
    I have also heard of a "Pherson" (spelling?) head screw that outwardly
    looks like the Phillips head, but I can't find anything about it on the 'Net.
    Edit: Ahh, found it. It's a Frearson or Reed-and-Prince head as shown in
    the illustration above. Probably not applicable here as, at least in the US,
    it is used on bronze wood screws used in boat building...
    one of my past careers was as a boat builder...
    to which I will gladly still answer. :p
  17. direstraits71
    367
    65
    Yeah, thermal expansion/contraction could be causing the condition assuming its some minor mechanical interference. If that seems to be the problem try to see if it can be adjusted, or you might take it apart and reassemble and see if it changes. I don't know if that's hard to do or risky or not. If you're still in warranty, take it in to the dealer and see what they say.
  18. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Low fob battery, low 12V, try some light grease as for the struts I lubricate them with light grease, but, it only helps some. I have also noticed a slowness in Winter and I am in California!
  19. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    gob some white lithium grease on the base and the latch mechanism.
    in winter several of my other cars locks will "stick" its actually water freezing the mechanism shut.
    displace the water with grease and voila, doesnt stick anymore.
    perhaps a good wd40 spray to displace all water, then grease liberally.
    open and close the mechanism a few times to spread the grease.
    also try pushing down on the rear hatch when pressing the unlock button.
    if its jsut a bit tight, jammed, maybe downward pressure will relieve the jammed up pressure point, and latch will unlock freely.
    just thinkin a bit.
    definitely wd40 all gaskets if they get wet they could also easily freeze shut.
    my struts are weak in the winter, hach doesnt open all the way, i am always bangin my head!!!!
    you could always leave one rear seat folded down and let the dog climb in the rear door and go into the trunk area from there...
