Silver steering wheel trim
Discussion in 'Gen 3 Prius Accessories and Modifications' started by HI MPG, Feb 17, 2010.
  1. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    I'm looking to mod some interior trim pieces. Has anyone had any luck with removing the silver trim pieces on the steering wheel? I was fiddling around with them yesterday, and I think they are screwed onto the two bottom steering wheel spokes (the 5 and 7 position if referencing a clock). I don't want to start prying in fears that I'll break off clips... so looking for any help possible. Thanks!
    -Calvin
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Bump, I'm looking for the same info. I want to take the trim off so I can cover it with some 3M DI-NOC CF.
  3. Kore971
    Kore971 PEDD-CESC
    106
    59
    Downey
    You have to take the steering wheel off, the trim pieces dont come out that easy...
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Answering my own question. The shop manual calls for removing the center pad by probing around and releasing some catches to get access to the screws that hold the silver pieces in place, then popping a catch loose for each silver piece. I think I will skip it.
  5. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    I was also interested on how those pieces came off for a different reason: I wondered how tough it would be to put brighter LEDs in the mode and trip/disp controls. The OEM lights are wimpy at best
  6. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    even if you could paint them what are you going to do with the silver buttons that have the icons?
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Mine has dark gray buttons so no problem.
  8. HI MPG
    789
    133
    93
    Orange County, CA
    I would like to do the same... I could barely see the illumination sometimes without having a long stare.
  9. andino
    andino Senior Member
    746
    551
    San Jose, CA
    You have to pull the airbag off and then there are a few screws holding the trim pieces on. You don't need to remove the steering wheel though.
  10. Tideland Prius
    16,602
    He's referring to the bluetooth, radar and LKA buttons (among others) in the silver trim. Given that you have a Prius II, your silver trim has no buttons.
  11. cooper_s_1275
    cooper_s_1275 Prius Newbie
    Hong Kong
    Hi there, Is there any update on this post? Anyone managed to pop off the silver trim on the steering wheel??
  12. drunkin master
    drunkin master Contributing Member
    394
    103
    92
    Los Angeles
    I recall seeing somewhere on a jdm website and yes you do have to remove the steering wheel and remove the airbag or at least thats what it looked like. I will try to see if I can find that site and post the link. I was thinking the same thing but to change out the led lights behind the controls from green to bright white to match my other buttons.
    I tried to pull them off thinking it just pops out but no such luck.
  13. drunkin master
    394
    103
    92
    Los Angeles
    It looks like there are two screws on each side.
  14. Scott the fix it guy
    Scott the fix it guy Junior Member
    It's not that hard to do. 20 minutes max. Here's a video on how to do it:
    Calutzu likes this.
