Any Recommendations for Snow proofing the Prius
Discussion in 'Gen 2 Prius Main Forum' started by jennymc, Jan 11, 2005.
  1. jennymc
    jennymc New Member
    Does anyone have any recommendations for snow chains or other types of devices that will help get traction for the Prius in the snow? I think I am going to have to drive my Prius to Lake Tahoe this weekend and they got 9 ft of snow last week, so I want to be safe. I have driven it in small amounts of snow an inch or two, but nothing major.
    Any recommendations would be much appreciated.
    Thanks,
    Jenny
  2. tochatihu
    tochatihu Senior Member
    9,853
    3,814
    Kunming Yunnan China
    2001 Prius
    For the previos generation (2001MY) Prius I bought "SCC Shur Grip Z cables" in the 315 size. This size will not be correct for your Prius, with its larger tires. So far I have avioded circumstances requiring them, but I have test-fitted them at home.
    The front (drive) wheels do not have much clearance to the front struts in Prius, so I doubt that conventional/old fashioned chains will even fit. So I suppose that cables are the only choice for temporary traction.
    If you have not used such things before the main points are confirm that you can fit them on before facing the bad conditions, drive 20 mph or less with them on, and remove as soon as possible.
    DAS
  3. hmbprius
    hmbprius New Member
    I was just about to post the same question: its the time of year where you don't get a choice: the freeways (I50) require chains. I have found some chain/cable web pages and the SCC_Z-chain (www.ssc-chain.com)does apear to have the lowest clearance...but has anyone used it on the 2004/05 Prius? I have no experience with chains/mountains and new to this (when I lived in NY I had my rust bucket Jeep and 4wd).
  4. cheaplawyer
    cheaplawyer New Member
    best way to snowproof the prius - leave it at home and rent a 4wd suv something; clearance is limited btw chassis and ground - nothing cures that in deep snow other than something w/ higher clearance and 4wd
  5. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    I bought cable chains from my toyota dealer, but havenot had to use them yet. ground Clearance may be an issue.
  6. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Is ground clearance really an issue? I thought the chain requirement was to make sure people didn't get stuck on the plowed road causing an impossible traffic jam. Are the roads open when they have 4+ inchs of snow on them?
  7. alcor
    alcor New Member
    Eugene, Oregon
    I just purchased a set of "Quick Fit Diamond" chains from Les Schwab Tires. They are a large North Western tire store. These are actual chains that are recommended for S.A.E. Class S vehicles, and recommended for ABS braking systems. We looked at the Prius Manual, and the technician actually looked at the car and tires and saw no reason whatsoever why these would not work perfectly. Now I admit to not having used them yet, however, when and if I do, I will give a full report. I do like them because as chains go, they seem relatively easy to install, and they are real chains.
    Alan
  8. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Re: Chain binders
    Purchase and cary TWO sets of rubber chain binders. Use both sets when you apply chains. If one binder breaks (count on it happening some time), your chain(s) are still snug and you keep driving.
    With two chain binders - the cable chains stay snug and do not damage the vehicle. You drive with confidence knowing that your chains will stay on, in spite of your lack of experience or attention to detail.
    Regardless of how other vehicles drive, keep your speed down around 25-30 mph.
  9. hmbprius
    hmbprius New Member
    I had also asked the dealer for their recommendation: they called some other services departments and basically all they could do was point to the page (unhelpful) in the owners manual that basically says use chains when indicated and with care. Not helpful Toyota!
  10. kkister1492
    kkister1492 New Member
    355
    Fremont, CA
    We purchased the Shurgard cables. Put them on last week in the garage to make sure we knew how and that they would indeed fit (they did) before taking off for Tahoe. Fortunately, the roads were clear and we didn't need them.
  11. hmbprius
    hmbprius New Member
    There are 2 different forums discussing this topic here at Prius Chat: Check out http://priuschat.com/forums/viewtopic.php?...p?p=63075#63075
    One Prius owner had to apparently sign a release from his dealer that he would not sue if the chains damaged the car! That seems to contradict what is in the owners manual (that does state you can put them on). I wouldn't have signed!
  12. Sufferin' Prius Envy
    3,998
    Costco has these “chains†on their tire web site . . . but not the size for Prii . . . SO, I went to the manufacture’s web site.
    They look interesting in that they are made from polyurethane not metal, are easy on/off, and good for mud and sand too. Also OK for S.A.E. Class S vehicles. (Smallest S.A.E. clearance standard)
    http://www.flextrax.com/
  13. smort
    smort New Member
    UT
    used the same chains from Les Schwab in Yellowstone last January. worked great. easy on and off
    Smort
