Plastic Panel On Top Of Display Center
Discussion in 'Gen 2 Prius Main Forum' started by gt5-33, Nov 29, 2010.
  1. gt5-33
    gt5-33 New Member
    I have a 2005 Prius and I was wondering what the purpose is for plastic panel on top of the display center. How is it removed and returned in place? Thanks Tom
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Do you mean the plastic panel on the dash in front of the display? It covers the projector for the dash display. When you see your speedometer, etc. you are actually looking at a projected image.
  3. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    By chance, could you be referring to this object:
    If so, it's a Gen II-specific MFD sun shade. Ususally it is
    held in place by small velcro strips along its edges.
    More info at the PRIUSchat store.
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I suspect he is referring to the speaker grill on top of the MFD.
  5. gt5-33
    gt5-33 New Member
    That is correct David. Does it cover a speaker? Does it just pop out? The reason I'm asking is because it makes a noise while driving. If I press down on it, the noise goes away.
  6. David Beale
    5,963
    1,981
    Edmonton Alberta
    It is held in with four pegs, two in the front and two in the rear. They have a wedge of plastic molded into them, such that once you press it in far enough it snaps to lock in place (the end of the wedge is a right angle). So I'm not sure if you need to press it towards the centre to release it or not. Probably. You may be able to release them with a thin flat blade screwdriver. I'd try using a piece of cardboard wedged under it to see if that stops the rattling first. No point in breaking it if there is a simpler solution. If the cardboard works then you can find something that will look ok wedged under it. Your dealer can show you a picture from the shop manual of the piece.
  7. gt5-33
    gt5-33 New Member
    Thanks David
