2008 without smart entry and start failing to unlock doors
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by swamped, Nov 30, 2010.
  1. swamped
    swamped New Member
    Massachusetts
    all of a sudden, my 2008 prius, basic package without the smart entry system, stopped locking or opening the doors when i pressed the button.
    at first i thought it must be a dead battery, so i replaced it with a new one and got the exact same behavior. i checked the old battery and it was still giving off 3 volts as was the new one when i checked that with a volt meter. when i press any of the buttons on the key, a small led light goes on and on the dashboard a picture of a key lights up briefly. the owner's manual does not show the key as a warning light.
    everything seems to work using the manual key on the doors and the stub stuck in the ignition slot to start the car.
    ideas are most welcome.
    thanks
    49,492
    i didn't know you could get an 08 without sks. how is your 12v?
  3. swamped
    swamped New Member
    Massachusetts
    battery is fine. car runs great though with slightly lower mileage after the local toyota dealer tuned it up a few weeks ago.
    the base package when i bought it uses the same key, but you have to actually insert it into the slot to start the engine.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Please use this quick test and report the battery finding anyway. At least you can eliminate it. BTW, have you ever had to jump start the car?
    This:
    http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html
  5. bisco
    49,492
    tune up? what did that consist of? how many miles on her?
  6. swamped
    swamped New Member
    Massachusetts
    39K miles, tune up was 2 hours to change the oil and check fluid levels.
    i just put my volt meter to the jump point under the hood and got 12.5 volts.
  7. qbee42
    3,074
    That isn't a tune up. That's an oil change, which shouldn't change your fuel mileage unless they over-filled your oil.
    As for your locks, do they work when you operate them from the driver's door controls?
  8. swamped
    swamped New Member
    Massachusetts
    locks work fine from the door controls
    the tune up was whatever they do at 35K miles, but they seemed to charge me for primarily an oil change.
  9. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Thats because thats all they did.
    Try the battery test I posted. It takes 10 seconds.
    It checks the battery under load. Compare to listed values.
  10. bisco
    49,492
    is there a switch under the steering wheel that shuts it off?
