Snow tires or what?
Discussion in 'Gen 2 Prius Main Forum' started by canesfan, Dec 1, 2010.
  1. canesfan
    canesfan Culture shocked...
    544
    Jacksonville, NC
    Help! My hubby has threatened to sell my Prius! We live outside of Portland in a hilly area. Granted, we don't get many snow events here, but when we do it's a big issue that my car is useless. To leave my garage I must go DOWN the driveway, UP the street, and DOWN the next street. Hubby is reconsidering selling my car, but is saying we should get different tires, at least for the winter. He is partial to Les Schwab and they are recommending Toyo-Observe studless mud/snow tires. Any direction is appreciated. :confused:
  2. mike lipke
    mike lipke New Member
    89
    MN
    I have Michelin X-Ice or IceX on ours. Make a HUGE difference. I put them on Corolla steel wheels from a junk yard. Fit fine (with regular lug nuts).
  3. Optimus
    Optimus Member
    260
    17
  4. fos4110
    fos4110 Junior Member
    30
    Kent, WA
    2015 Prius c
    Hey-
    I bought the Bridgestone Blizzaks for my gen 3 Prius and were good with the last snow we had in Seattle. I ordered them from tire rack and had my local Toyota dealer put them on.
  5. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    There are lots of winter tire treads on this site, check them out. There are a few tires that give great results in snow,ice and dry. Check them out and decide which is best for you.Much safer to have good tires for any event and accidents are not good! H
  6. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    I recommend Nokian WRGII. They are all-season so you don't have to worry about changing them and they work very well in snow and heavy rain. They don't wear excessively in the summer. Note that if the snow is deeper than about 6" you can forget moving in it in a Prius. You will high-center.
  7. Optimus
    Optimus Member
    260
    17
    We got 8" of heavy stick-to-your-shovel snow a couple days ago and the Prius had no problem plowing a trail across the driveway 200 feet and through the bank the county snow plow made on the main road into our driveway. For me, driving the Prius in snow is no different than any other vehicle or FWD car. I don't see any limitations just because it's a Prius or a hybrid. Mind you, 24" of snow and plowing with the front bumper through our driveway would be a different matter, but no FWD car would really be that good at it.
  8. David Beale
    5,963
    1,983
    Edmonton Alberta
    Yep, and if the road hadn't been plowed, you'd have driven just far enough to be dangerous before you finally built up enough snow underneath to kill traction. Don't do it! It's difficult enough to navigate snow covered roads without having Prius stuck all over the place! ;)
  9. Optimus
    Optimus Member
    260
    17
    I don't think so. We would have just kept on driving if the roads hadn't been plowed. Eight inches of snow is not really much of a news story here, but I do insist on good tires. I know how to drive in our weather. Been doing it for 20 years. There's a time to stay home and hunker down when it really snows, and there's a time to not worry about it. Eight inches isn't quite enough to bother me.
  10. Rockin Prius
    Rockin Prius New Member
    61
    NYS
    Lots of positives from owners here at the forum... my wife and I love them.
    Nokian WRG2
  11. qbee42
    3,075
    +1 on the WRG2 tires, assuming you don't want to buy studded snow tires.
    It depends on the type of snow. Eight inches of dry stuff is nothing. Eight inches of heavy wet snow over ice would stop my Jeep, let alone a Prius. Snow conditions very: one size doesn't fit all.
  12. Optimus
    Optimus Member
    260
    17
    Again, 8" isn't going to stop us from going places in the Prius, and my Toyota pickup would laugh at 8" of any kind of snow. The only time an "average" of 8" of snow would stop me is if it were actually blowing and drifting snow with widely varying depths.
  13. fuzzy1
    10,308
    You obviously haven't experienced enough different kinds of snow.
    8" of Colorado Champagne Powder is completely different than the same depth of Cascade Concrete or Sierra Cement. No Prius will get through the later, and I wouldn't bet any money on your truck either.
    During certain Chinook conditions, 8" of snow on the road will stop an F250 with chains on all four. I had to help dad use the crawler tractor to tow it out several times.
  14. a_gray_prius
    2,927
    782
    IL
    I have Nokian Hakkapeliitta snow tires while are truly wonderful when they don't plow the streets (or at least before they get around to it).
    Related: These people live on a hill. If you husband sells your Prius and you end up with a SUV/Truck and end up taking out 5 cars because you haven't realized that whatever fancy 4WD system the marketing people sold you doesn't actually work in a lot of conditions, the Internets will be laughing at you.
  15. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    Hi canesfan (from about 3 hours south!).
    I like Les Schwab too, great service and a NW legend. But I'm usually a little disappointed in their selection. Studded tires work well enough but they sound horrible and cause undue wear on the roads. These days good quality studless tires are fantastic.
    The already mentioned Michelin X-Ice, Bridgestone Blizzak and the Nokian WRG2 are all great examples. The Blizzaks are a little cheaper than the X-Ice and both are available at Discount Tire / Americas Tire in Tualatin.
    - D
  16. Optimus
    Optimus Member
    260
    17
    Thank you for schooling me on snow. We just don't get any here in Minnesota. :rolleyes:
  17. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Interesting how some early build Prius like mine had hyper-sensitive Traction Control and others just charge through snow with no problems. My '04 was helpless in 3 inches of snow/ice if I kept on the Michelin Harmony tires
    Going through different studless winter tires, I finally cured the problem with an aggressive set of studded Goodyear Nordic winter tires from Canadian Tire
    I completely agree.
    Having also lived in Utah, even a couple years in Park City, the difference in snow, especially at higher elevations, is amazing. Valley snow and high elevation snow are completely different
    Which is why chain laws exist I guess!
    At the time I lived in Park City, I had a 4Runner with studded winter tires AND chains. I actually miss the climate, the winters were not as bone chilling cold as they are here
    Even better is a 4WD with factory studded winter tires. I never ever drive on highways in 4H, the studded tires and a few sandbags in back for traction are fine even in drifted snow
    These are the winter tires I used to run on my Prius
    And on my FJ
    Funnily enough, folks will pass me in a car in treacherous winter conditions. Almost without fail, I come across them spun out into the shoulder.
    I agree the tread pattern of any aggressive winter tire will cause noise. Just like a mud tire will on dry pavement, there will be a resonance. The studless Toyo Open Country G-02 winter tires I used to have on my FJ also had resonance
    Comparing the traction of the studless to a good factory studded winter tire is a day and night difference. Well worth any tradeoffs
    As far as road wear, around 20 years ago the Swedes came very close to banning studded tires over road wear issues. Rather than ban them, the road research institute VTI simply re-engineered the studding system
    Start : VTI
    which resulted in not only negligble road wear but ironically much improved winter traction.
    Even the Province of Ontario now allows studded tires for winter, at least north of the Sault.
  18. Optimus
    Optimus Member
    260
    17
    Yes, that is strange. I was hesitant to upgrade from our 2002 to this 2004, but I just haven't seen any issues with Traction control. And even the LRR tires (Bridgestone Ecopia EP100) I bought for the 2004 this summer did ok in the slippery stuff (granted they are basically new). Regardless, I've had nothing but good luck with various Blizzaks and put them on anyway. I got a set of the newest model (WS70's). We can't use studded tires here in Minnesota..... When I put the WS70's on (I have a tire machine and balancer), I immediately drove out and "played" in the snow to see how they'd do. There weren't any reviews on the WS70 yet on tirerack.com when I bought them, but they look identicle to the WS60 and so far they seem to handle just as well. I've owned other sets, and probably the "worst" set of snow tires were the Dunlop Graspic DS-3. That being said, the Dunlops were still decent and certainly better than regular all seasons--but just didn't stick like the Blizzaks. In general, snow tires have come a LONG way in the last 15 years. Snow tires used to look like mini mud terrain tires.
  19. jayman
    13,439
    641
    Winnipeg Manitoba
  20. Optimus
    Optimus Member
    260
    17
