Footwell/Glove Compartment LED?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by john0383, Apr 25, 2010.
  1. john0383
    john0383 New Member
    NC
    Hey Guys,
    Has anyone changed the footwell lights and glove compartment light to LED? If so, what LEDs did you use? I would like to change them to a blue color...any ideas?
  2. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
  3. john0383
    john0383 New Member
    NC
    oh cool thank you! I only see one color in there? I was wondering if there is a way to change it to blue?
  4. eric1234
    eric1234 Active Member
    392
    201
    Hamden, CT
    Do all the Priuses have this footwell lighting? I have a Prius III, and I have lights in my doors, and a light in the glove box, but I don't see any footwell lighting. (Or does 'footwell lighting' refer to the lighting in the doors?
    Many Thanks,
    Eric
  5. qbee42
    3,081
    With the Gen IIs, the glove box lighting is LED from the factory. Is this not the case with the Gen III?
  6. eric1234
    392
    201
    Hamden, CT
    Yes, the glove box light is an LED, a yellow one.
  7. john0383
    john0383 New Member
    NC
    Hey Eric,
    I think I read in the forums here that the footwell lighting is in the base packages of IV and V
  8. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    John,
    You are correct about the packages for the footwell lighting. BTW, the LED unit in the glovebox is the same as for the footwell, so you could order an additional unit if you want to change that one out to white.
    Calvin
  9. eric1234
    392
    201
    Hamden, CT
    Does anyone know if the wiring there if I want to add footwell lighting to my Prius III?
  10. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    I just checked my M II by removing the upper kick plate (plastic) in the passenger's foot well. I looked up there and could not find a connector for the foot-well lamp option. I used a maglite to check so if there is a socket for this option, it's out of normal sight. I did notice a hole in the kick plate which is probably where the bulb assembly goes.
  11. tinaprius
    tinaprius New Member
    26
    SC
    So I don't see an answer to john0383 question about the color unless I missed something. Bought my first Prius on Saturday and would like to change the color.
  12. HI MPG
    789
    133
    93
    Orange County, CA
    No other color unless you want to go with white (the Lexus LED). I know someone who ordered the white LEDs and then covered the housing with blue cellophane. It looked pretty good. So I guess you could approach the same route and then cover it in whatever color you want the lighting to be...
  13. tinaprius
    26
    SC
    Is it pretty easy to do? I have some concerns about my husband messing with my new car.
  14. HI MPG
    789
    133
    93
    Orange County, CA
    It's very easy. The bulb housing itself is not like the standard LED bulbs you see out there. For the glovebox, you just have to open the bottom door and reach behind the horizontal shelf. You'll feel some wires, so follow that to where the housing connecs. For the footwells, you can remove the kick panels... which makes it a lot easier to remove and install. I would recommend changing the footwell ones first so you know how to unclip the bulb housing from the wire connectors. Here's a link to what the bulbs look like:
    http://priuschat.com/forums/gen-iii...8171-interior-led-lighting-10.html#post999276
  15. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    Thanks for this!! I'm gonna steal the lights from my wife's is250 lol
  16. HI MPG
    789
    133
    93
    Orange County, CA
    LOL! Do it. Replace hers with the yellowish ones from your Prius.
  17. bzyrice
    805
    324
    West Palm
    I know this is an old thread.. But we are returning her is250 lease today so I just removed the lights from her car lol.. I'll install in my Prius when I have a second.. Thanks for postin this!
