Port or Direct Injection?
Discussion in 'Gen 3 Prius Technical Discussion' started by jmeyer99, Dec 7, 2010.
  1. jmeyer99
    jmeyer99 New Member
    Golden, Colorado
    Is the Prius port or direct injected?
  2. donee
    donee New Member
    2,956
    198
    Chicagoland
    Port. Think if they went back to a 1.5 liter with Direct Injetion?!
  3. jmeyer99
    jmeyer99 New Member
    Golden, Colorado
    Where are the injectors? I do not see them on the intake manifold.
  4. bwilson4web
    16,547
    It is port injection which makes sense for a Atkinson cycle. The intake valves are kept open during part of the compression stroke pushing the fuel air mix back into the manifold. It doesn't stay there long as during the compression stroke, another cylinder is pulling in the fuel-air mix.
