If your car is less than 45 MPG then try this
Discussion in 'Gen 2 Prius Fuel Economy' started by ggcc, Dec 6, 2010.
  1. ggcc
    ggcc Member
    132
    Bay Area, CA
    2014 Prius Plug-in
    The Story:
    I brought my car 2007 Prius to the dealer for Floor Mat/Accelerator Pedal recall service they chopped off the pedal a little bit shorter. I got the car back and drove I noticed mpg has dropped from 54mpg to 42 mpg. I drove another 200 miles and got only 42-43mpg. I did not feel any different, only MPG has dropped!!!.
    How to fix (shotgun)!!
    To make it short; I got my flash light to check the accelerator pedal to see I got the new one or they modify the pedal. Then I saw a black Electrical Connector next to pedal; not thing was really unusual however, I just reseated (pushed it down) any way to make it snug (because I think they must disconnect the connector in order to remove the accelerator pedal).
    The Result:
    I drove car for 35 miles I saw it goes back to normal now it's at 55 MPG (even the first 2 miles I can feel mpg went back to normal).
    If your car is less than 45MPG please try to RE-SEAT Electrical Accelerator Pedal Connector with your bare hand and a flash light. This will cost you a few minutes...
    If it does not improve then something else.. I think it will not hurt if you try to push electric wires down to its connector and re-seat the connector.
    The connector is next to Accelerator Pedal (between the brake and Accelerator pedal).
    Let us know your result. :cheer2:
    2 people like this.
  2. Rest
    Rest Active Member
    1,210
    CA
    English isn't your first language, is it?
  3. ggcc
    ggcc Member
    132
    Bay Area, CA
    2014 Prius Plug-in
    Yes, English is not my first language. I am trying very hard. Correct me if I am wrong and I am willing to learn.
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    You're doing well. :)
  5. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    The accelerator pedal is a hall-effect system with double redundancy. If there was *any* problem in the signal due to a loose connector, or anything else for that matter, you would get a "Triangle of Death" and a DTC sould be set. If you don't believe this, try unplugging the connector and the going ready.
    It works be generating 2 different voltages for each possible position of the pedal, and these voltages are never the same. The Hybrid ECU compares these 2 voltages and if they are not within a small tolerance of what the slope formula says they should be you get a DTC, or most likely a sharply reduced power output as it assumes the lowest common denominator.
    But I've heard that chanting various phrases while driving can also improver your mileage, so maybe if you chant while looking at your pedal, this will improve mileage! :-P
  6. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    I have yet to get the mileage people talk about here on PC so I'd love to know those chants :D
    mfa-prius likes this.
  7. qbee42
    3,079
    Likewise it also helps to jump in a circle on one foot before entering the car, but only on odd numbered days.
  8. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    I hope most of these remarks were made in humor, otherwise I detect a fair amount of nastiness to an honest observation.
  9. bisco
    51,378
    i only wish that i could speak and write a second language as well as you do, and i had no problem understanding you. as far as the connector is concerned, i think peef probably knows what he's talking about and yet, you definately observed a very large change in fuel economy. it's interesting.
    2 people like this.
  10. Ryanpl
    780
    158
    Brooklyn, NY
    I've read several posts from these guys and I feel they are in honest jest. In all honesty I'm going to check try what the OP suggested when I get home from work this evening and will post any results. I normally attribute my low mpgs to nyu driving but ...
  11. pEEf
    720
    579
    Berkeley, CA
    There are literally thousands of factors that can alter mileage, many are not obvious, and they can change from drive-to-drive. What I can tell you is fact; even if the throttle was somehow getting erroneous info to the HV ECU that somehow escaped fault detection, the driver would definitely notice the car lurching around and not responding properly to his/her foot.
    I have never heard of this happening in any drive-by-wire car. The original Prius had potentiometers in there instead of the zero-wear hall-effect system. They were known to fail on occasion, and they always set a code and sometimes resulted in the car not "going" when the pedal was pushed.
    See if you can think of something else that changed around that time. It may be something you will not be able to determine, such as a bad tank of fuel. A little water in the fuel can cause mileage to fall.
    More esoteric things such as a lower outdoor temperature can cause mileage to drop. Even the length of your trips can have wild effects. A short trip not allowing full warm up, followed by a normal one will drop mileage due to the hot water from the thermos not being there to help preheat the ICE.
  12. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    You'll find me on my knees by my car, with a flashlight, checking that connection...
  13. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Please be sure to hop three times and whistle Dixie before praying on your knees !:D
  14. pEEf
    720
    579
    Berkeley, CA
    I have a big urge to say something lewd here, but it would probably affect my mileage, so I'll just keep it to myself for now... =)
    2 people like this.
  15. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    You seem pretty sure about how this works. Where did you get your data?
  16. bisco
    51,378
    are you meaning the chanting data?:D
  17. qbee42
    3,079
    Toyota technical documentation.
