Grill blocking w/o scangauge
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Ryanpl, Dec 14, 2010.
  1. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    I took a look at some of the other gb questions but must be stupid :( so I'm looking for opinions. I do not have a scangauge (waiting for pEEf's Priuscan to be offered for sale). Would people suggest blocking just upper grill, lower grill or both? I would be using the 1" foam pipe insulation from Home Despot. Ryan
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I blocked mine for a couple days, but got cold feet and remove the blocking. I could not stand not knowing what was going on with the temps. Your probably OK blocking the bottom only without worry. H
  3. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    With current East Coast temperatures (mid-30s for daytime highs in the mid-Atlantic), you're OK blocking everything. If it manages to get back above 50F, you might consider unblocking the lowermost slit of the lower grille. Above 70F, I would unblock the entire lower grille. See this (identically titled thread) for more.
  4. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Yes.....I was also afraid to block. But see that there is a high temp warning light. that gave me so confidence to go forward with the blocking. Looking for the advantages of it now.
  5. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    I didn't block my Gen III till I got the scangauge. I have the lower grill blocked at 100% and it doesn't seem to be enough (of course it was -9F without the windchill this morning). Will try 1/2 of the upper this weekend.
    I'd be too chicken to do it without the Scangauge.
  6. tomw
    tomw Junior Member
    28
    Milton, ON, Canada
    I blocked all of lower grill and half of upper grill. I would have blocked it all but I had installed some led lights in the upper grill and i don't want to block them. it takes a lot less time for the engine to warm up and i haven't seen the temp go any higher than it usually does. The temp here is hitting -10C to -15C now.
  7. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Without instrumentation to measure inverter temperatures I would block the upper grill fully and the lower grill partially (leaving 0.5 ~ 1 slit opening). Good luck!
  8. Ryanpl
    780
    158
    Brooklyn, NY
    I was thinking along those lines as well 2009. Would you go with 1" insulation or 3/4"?
  9. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    You have an '04. I have an '04.
    I have been fully blocked for about a month or more. Even during the summer I was mostly blocked: Fully blocked on top and and couple open on the bottom.
    My vote: even without the ScanGauge go all out.
  10. Ryanpl
    780
    158
    Brooklyn, NY
    I have family in Michigan City. Based on the temps you need your car blocked. It's a tid bit nipply there.
  11. 2009Prius
    2,705
    512
    63
    I don't think the size is that critical. As long as the pipe insulation fits snugly in the grill slots and doesn't fall out after a test drive you are good to go. :)
  12. Warmed Over
    Warmed Over New Member
    Baltimore, MD
    I have a 2005 and was pleased with mileage in mid 50's low 60's until this current big chill. It dropped as low as 23.3 but I have been nursing it back up with the advice of some of these posts. The dealer says wait for warmer weather ... The info re 'blocking' makes a great deal of sense without any other gizmos. In western Canada in the '70's my first car, a 61 Volvo had a grill blind on a chain that the driver operated from inside. I lowered the blind as the operating temp rose. All other wehicles had grille covers and flaps. Time to resort to engine block heaters and flaps!
  13. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Warmed Over,
    :welcome: to PRIUSchat. :cheer2:
    The unseasonable cold we've been seeing this last week is killing my
    MPGs too... and that's with full blocking up and down with ScanGauge.
    On my ~18 mi. one way commute, 70/30 urban streets/freeway, I get
    up to 157 degF coolant temps only in the last 8 miles. In the summer I
    get there in ~1.5 mi. Brrr...
    On the pipe insulation, go for the cheaper, gray stuff, it lasts multi-years.
    The dark black stuff tends to tear easily and goes sticky in a year.
    The 3/4 in. is a lot easier to get between the grill bars. There are 5
    openings. You may have to slit the insulation in half lengthwise to get it
    to set tightly in the thin top and bottom openings.
    I hesitated blocking until I was doing some barbecuing during the week
    after Christmas two years ago. I was using twice the amount of
    charcoal and thinking I needed some insulation for the Webber kettle.
    Then I looked over at the Prius and instantly understood why grill
    blocking could help with maintaining ICE heat... a no brainer.
    +1 on what Tony said. Unless your pulling heavy loads or long up-hills,
    in my experience you can full block the Gen II without concern up to 50
    degF. Higher than that you better get a SG.
