Accident in Prius, Engine would not shut off
Discussion in 'Gen 3 Prius Main Forum' started by dhs, Dec 17, 2010.
  1. dhs
    dhs New Member
    121
    Virginia, USA
    Yesterday, while driving home in a snow storm, I was in an accident in my 2010 Prius. It was a hit an run, and I ended up on the side. Problem is, while in the car, I could not get the engine to shut off. The button was not responsive. The wheels were still turning,
    It was a low speed event: the airbags did not deploy.
    The car is not badly damaged....the drives side panels are bad, the front bumper is bad and drivers mirror is gone....one window broken....It was drivable, but did not feel or smell right (burring rubber and oil). So I had it towed.
  2. Mark57
    2,945
    2,740
    OK
    You didn't mention if you were injured but I hope you're OK. The car can be fixed easier than you can. I'm very sorry this happened to you. I just got my Prius back after being in the body shop for 7 weeks to repair hail damage so I know what it's like to be without the vehicle. I hope everything turns out OK for you.
    PS, not to make light of a bad situation but the top down view of the Prius reminds me of the top view of a Microsoft optical mouse.;)
  3. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    I feel sorry about what happened to you.
    BTW: During speedo above 0mph, I see no way of stopping the engine, because IGN button or P gear do not engage/act.
    Good luck!
  4. qbee42
    3,080
    Did you press and hold the Power button? That is the normal way to force a power down. It takes about three seconds of holding.
  5. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Oh man, that blows.
    I have to admit, sitting on its side like that it looks like a toy.
    I hope you're okay and that you get your car back soon.
  6. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    Ditto here on regrets and glad you are OK. So the ICE was still running while the Prius was turned on its side? Engines are not made to operate that way so you better have Toyota check it out to be sure there were no consequences from that part of the mishap. That was probably the burning oil smell you noticed.
  7. dhs
    dhs New Member
    121
    Virginia, USA
    Back is sore....Accident was hit an run, and I went up an embankment and rolled.
    Not sure about the car....
    I hope the damage is either minor, or the car is totalled.
  8. dhs
    dhs New Member
    121
    Virginia, USA
    The ICE was running while the car was on its side. Running for about 5 minutes. I will talk to the adjuster probably today.
  9. phoenixgreg
    1,157
    295
    66
    Phoenix
    Not good...I would be very concerned.
  10. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Hope you're ok. Bit bad the other guy didn't stop! I don't know how people can do that to another human being. :(
    My theory on why the engine wouldn't shut off was maybe the car was still in 'Drive' and would require you to either select Park or press and hold the Power button for longer than 3 seconds.
  11. ETC(SS)
    7,357
    I'm glad you're OK!
    You can fix or replace the car!!
    When it comes to the ICE not shutting down after the accident---well, I'm disappointed but not surprised. You should contact the NTSB. I suspect that there's some three-fingered nerve pinch that will disable the ICE, post-accident. Since your airbag didn't deploy, that might be the root cause---I mean SURELY Toyota's ICE will shut down if the airbags are deployed----right?
    I hope they catch the person who did the hit and run on you, but failing that---I would be praying that the car's totaled.
    It probably won't be though if the airbags didn't come out.
    Good Luck!
  12. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    The op hasn't said what they tried to do to shut the car down.
    Did you hold down the power button or just press it in?
  13. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Ditto.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    There should be a fuel cutoff but those only work in high impact situations. There might be engine damage but I wouldn't think so just after 5 min.
  15. Former Member 68813
    3,524
    983
    US
    Depends, if there was still oil pressure, no problem. The OP should be able to tell us if he/she saw oil pressure light while sitting on a side.
    I'm also curious if OP held the button for at least 5 secs?
    Another thing is why the engine didn't go off when no gas was pressed? Maybe it was spinning all electric?
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I know about a year ago when you had all the "run-a-way" Toyota stories there were several debates about kill switches or power button redesigns....
    I think this illustrates once again why Toyota needs to rethink the idea of an emergency kill button and/or how the power button actually reacts. In emergency or traumatic situations it seems either people don't know about holding the button for 3 or more seconds and/or they simply do not do it.
    In this case no harm no foul...but if the button was depressed for 3 or more seconds my understanding is the vehicle should of shut down...
  17. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    One more question for clarification, did you apply the brakes to keep the wheels from spinning?
  18. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Not just a Toyota problem is it? Many cars have keyless entry and running. How do they operate? What 'kill' switches or devices do they have?
    Perhaps the old fashioned key would be a better system. People are familiar with it and you physically turn it off and remove it rather than remembering to press a button on a car that is quiet even when running.
  19. The Electric Me
    9,083
    5,801
    Never said it was "just" a Toyota Problem...
    Has the OP ever answered whether they held the button for 3 or more seconds???
    Most of the discussion I'm refering to came born out of the tragic and unfortunate accident involving the San Diego police officer and his family...I believe it was a Lexus (Toyota Product)...
    Without re-opening the debate much of the discussion became centered around the the ease or ability to shut off the engine in panic situations.
    I just think (unless there was something physically wrong with the automobile) this incident could be illustrative once again of the drawbacks of a delayed 3 second or more cut off...and also that many owners don't seem to either know about the 3 second delay and/or they forget when faced with a panic or stressed enviroment.
  20. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    They need to strike a balance between accidentally hitting the power button and actually using the button in a panic situation. The best way to be able to use the power button in such a situation is to become an informed owner. Otherwise, an uninformed owner can just as easily miss a 3 millisecond panic shut-off button right in front of them.
