Help buying rims online.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by macmaster05, Dec 17, 2010.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    729
    Let’s say an online store is having a great sale on rims. Other than looking at the size and offset of the rim, how do I know it will fit my car, especially now that my car is lowered (~1.4â€)? How do people buy rims online? Is it always shot in the dark?
  2. a_gray_prius
    2,927
    782
    IL
    I'd be really inclined to just call the store having the sale. For my Evolution, there's a lively community at evolutionm to turn to for advice on sizing and fit. Prius owners aren't so keen on modification in general, so that information is more sparse here.
  3. macmaster05
    4,050
    729
    I called the store. He said the specifications for 2004-2009 Prius is a 5x100 bolt pattern, the offset is +38mm to +45mm, and rim size can be between 15x5 to 18x7.5. He said that given this range, these specs even apply to moderately lowered vehicle.
    The problem is the 17x7.5 SSR Type C rims I'm looking at have a +48 offset. In fact, many aftermarket rims are outside the offset range. They seem to be +35 or +48, but nothing in between. Why is this? Will they not fit? Would I need to order extra parts like spacers? Thanks.
  4. sktn77a
    sktn77a Member
    294
    NC
    Can't tell you if the offsets will work but another thing you need to know is whether they will clear the brake hardware. There is no measurement for this - you have to try them and see. If the wheels are available at tirerack.com, you can see if they fit the prius - they actually check the wheels on the car before they guarrantee they will fit.
  5. macmaster05
    4,050
    729
    Thanks. Tirerack.com's selection is somewhat scant. They don't have a lot of the JDM stuff like SSR Type C, but I did see them list some wheels with a 50+ offset. Would they be able to guarantee fitments for wheels they don't sell?
    Then I was reminded that I'd need to buy a TPMS sensor. Apparently that could cost $200+? Good god...
    Thanks.
  6. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    Those ssr's will fit, just make sure they're 5x100 and are Tpms compatible. The only consideration really is tire size to stay as close to stock diameter as possible
  7. macmaster05
    4,050
    729
    TPMS compatible...what does that mean? My current tpms sensor will work or I have to buy a new one? Where do you buy them? Is it specific for each wheel?
    I've never bought rims before, I'm still learning haha. Most of all I appreciate your forebearance. Thanks.
  8. a_gray_prius
    2,927
    782
    IL
    There's a space for the sensor body to go basically. The TPMS sensor body is located on the other side of the valve stem. Not all rims have that space. I moved my TPMS from my stock rims to my summer set of Volk CE28Ns. There is one for each wheel, and it's probably a good idea to get the seal/rebuild kit when you swap them over. Can you PM me the place, I could use another set of rims for another car.
  9. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
  10. deltron3030
    437
    64
    Lakewood, CA
    Best bet it to contact the manufacturer....also most rims built after about 2005 are likely Tpms ready.
    Tpms = tire (air)pressure monitoring system.
    your stock 2010 prius has one in each wheel. They are part of the actual air valve. The new rims you get must have clearance for the sensor.
  11. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    pay attention to the weight of the rims, heavy ones will spoil FC and acceleration, mine are 16" rims and I couldn't find aftermarket one that came close to the Toyota ones without breaking the bank. I hope that helps
  12. macmaster05
    4,050
    729
    Yeah you basically get what you pay for. There are some inexpensive lightweights like Buddy Club Racing rims and Motegi Traklites
  13. a_gray_prius
    2,927
    782
    IL
    From my experience, Motegi Traklites are generally thought to be pretty decent and Buddy Club is also well-reputed.
  14. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    You don't HAVE to buy new TPMS sensors. You can run without them, but you'll have the annoying dummy light on the dash forever then.
    Don't forget, that you'd have to get the new TPMS IDs programmed into the car ECU as well (if you get new ones). Unless you've got a good relationship with your dealer, you'll probably end up paying them around $40 to do the programming. Or, you could get the ATEQ tool (I have it, but it was acting up when I did my winter tire swap so I just used my TIS cable and techstream to do it) and do it yourself.
    I'm not sure if you plan to replace your existing wheels & tires or if you plan to get a second set and swap them for any reason. If you're replacing and going to get rid of the old set, I'd recommend getting the existing sensors swapped over.
  15. macmaster05
    4,050
    729
    Thanks. I was going to wait until I needed new tires (probably another 30k miles/2 years) to upsize and get new rims. I really have no need for rims/tires now, I was just enticed by this sale. In reality, I'm probably going to sit this one out. *sigh*. Thanks.
    By the way you're probably wondering what the store is. It's more-japan.com. Their sales starts 5pm PST on Monday Dec. 20. Rumor is that it's a crazy sale, up to 97% off on some stuff. Yes, 97% off. SSR wheels are on sale. The owner of the store said be on your computer before 5pm because the best deals go the fastest. I don't mind sharing this info to fellow Prius brothers and sisters. Good luck to all.
  16. Azipod
    Azipod Member
    139
    NorCal
    MacMaster05,
    You will need to carefully remove the TPMS from your rims and mount it on your new wheels. Make sure to buy a TPMS rebuilt kit to replace the washers/gaskets when you switch the TPMS unit to the new wheels.
    When are you going to buy your wheels? I want to buy your Touring rims! :)
  17. deltron3030
    437
    64
    Lakewood, CA
    Macmaster,
    I may have a set of 16" ssr f-type wheels for sale, 11lbs per wheel, tpms compatible, and brand new. PM me for details
  18. Supreme
    Supreme Hypebeast
    182
    Philly
    Size and offset is all you really need to know.... +48 offset on a 7.5" rim is going to be pretty sunk in there, you'd have to run spacers if you want the wheels more flush.
  19. macmaster05
    4,050
    729
    Supreme, doesn't a very positive offset with wide tires mean that the edge of the wheel will be very flush with the fender, or even sticking out?
    Deltron, I was really hoping for Type Cs, I like how the gunmetal looks with my car. I know I'm really picky. But it sounds like a great deal. BTW why are you selling them?
    Azipod, I'm flattered that you're anxious to buy my rims haha, I really am. It's good to know they can always find a good home. Unfortunately, as I've said before, I'm putting this mod on the backburner. I'm really satisfied with how my ride looks now so I'm really in no rush. It usually takes a long time for my mods to come to fruition.
  20. Supreme
    Supreme Hypebeast
    182
    Philly
    The more positive the offset, the closer in to the body the wheels will sit. The more negative, the further away from the body the wheels will sit.
    That is why you'll see supra's/350z's/etc running wheels in the negative or very low positive offset wheels.
