barnyard smell
Discussion in 'Generation 1 Prius Discussion' started by papo, Dec 19, 2010.
  1. papo
    papo Junior Member
    princeville il
    does anyone experincene a ordor like cowshtt in there prius i have strip the carpet and interior, I HOPE THIS IS NOT A BATTERY GOING OUT, i just bought this 06 off my son with 100,000 miles on it i like it alot since the cold weather the mileage has drop about 10 miles to the gallon, can anyone help me on this problem, thanks
  2. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
  3. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    Regarding mileage, check your tire pressure. I like to run nitrogen in mine, have less issues with varied pressure during temperature changes.
    Maybe change the oil, to a better viscosity for winter season.
    Not sure how winter mix fuel affects mileage, but if you can find fuel without alcohol, you'd get better mileage as well. At least that is my experience.
    Regarding Odor, Drain issue is certainly a concern, but you might want to change the air filter above the glove box also. I suspect it has one just as our Gen 1's do. I purchased my car used, and this filter was absolutely filthy.
  4. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Why don't you just ask your son; "what the heck we're you doing in the car before I bought it from you?". :D Seriously though, in addition to cleaning the HVAC system cleaning suggested, is it possible a little critter got into the car somewhere and died?
  5. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    If all else fails, you could take it to a dealer and they could do the ozone treatment. They pump the car full of ozone and it will actually remove just about any odor (even cigarettes) from the car.
  6. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Check for mice in the heater.
