Fog light install question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Dochatley, Dec 19, 2010.
  1. Dochatley
    Dochatley Junior Member
    Dallas
    Does anyone know what the tan wire goes to that you connect the red power wire to from the switch.
  2. Cloud
    Cloud New Member
    New York
    I
    Please Elaborate more.
    The Tan Wire? The what? Restate your question please so I can help you.
  3. bartelby19320
    bartelby19320 Newbie!
    Pennsylvania
    I think he is referring to the one wire that comes out of the wire harness that you use the Bridge connector for the fog light switch wiring ~ Step 5.1
    Remove tape from lower connector on ECU and
    locate BROWN wire. Use the bridge connector
    to connect RED wire to BROWN wire. You may
    need to cut RED wire to proper length.
  4. Dochatley
    Dallas
    Bartelby is correct. It says Brown wire but it is really a Tan wire. Anyone know what it goes to or is for?
    Thanks
  5. Cloud
    Cloud New Member
    New York
    I
    Tapping the "brown wire" gives power to the switch. So when you turn on your parking lights, your switch is illuminated
  6. Dochatley
    Dallas
    Thanks Cloud. I knew it was to power the light in the switch but I did not know exactly what the brown wire controlled. So I can assume if I were to cut that wire (heaven forbid) I would just loose dash lights.
    Jerry
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Find attached a copy of the 2010 Overall Electrical Drawing that I downloaded from this site. On page 11, where it shows the Fog Light connections, there is a brown wire that goes to a Rear Fog Light Relay. In the US, we do not have the rear fog lights, so it appears to me that we may be tapping in to this wire for the OEM fog light installations.
    If anyone knows anything different, please let me know.
    View attachment 2010 Prius -Overall Electric Drawing.pdf
    orenji and Dochatley like this.
  8. Dochatley
    Dallas
    Thanks for that info jd. Thats what I was wondering. And thanks for the electrical drawing. I had no idea it was available. I love this forum and that there are so many knowledgable people to help answer questions. It sure makes things easier.
    Jerry
