The Sound Logic Behind the Reverse Beeping Feature
Discussion in 'Gen 3 Prius Technical Discussion' started by RufusNapkin, Dec 25, 2010.
  1. RufusNapkin
    RufusNapkin New Member
    36
    This is a clever, smart-design feature and it is extremely useful.
    Disclaimer: It is not intended for those who have never driven a manual transmission or for those who know what it is and how manual shifting works but have never relied on the exacting habit of skillful shifting of 4 or 5 forward and 1 reverse gears at ALL times while driving their cars. For those who have, however, at one time or another, owned a car with a stick-shift, the beep is a VERY valuable safety feature. When the old habit of going into first via a manual stick shift sneaks up on you from out of the remote corners of your mind as you are cradling that sexy little GenIII stick that looks exactly like the stick shift all sporty manual-transmission cars "aspired" to have, and then suddenly you find out - perhaps a little too late, perhaps not - that instead of going forward you are suddenly going in reverse, the beep is a God send and brings you back to the Moment - Pronto.
    Again, this logic is only relevant to those who have experienced it. Or as Einstein put it: "Logic without experience is invalid".
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I learned to drive in a 1962 Ford Falcon station wagon with "3 on the tree", so my Prius shifts like I expect. Now if I could learn NOT to shift it back in D at every stop.
  3. navy48
    navy48 LBII (Lil Blue II)
    56
    Indianapolis
    while it might be considered 'logical' and 'sound' to some, we didn't care for it and had it re-programed to only beep ONCE. it drove my wife crazy, as we have a really LONG driveway that she must back out of.
    one beep is enough. the way I see it, if you can't pay attention enough to know what gear you're in, then you have more issues than worrying about if you're in reverse or not.
    just my opinion and of course everyone has one and for each, they are all correct. :)
  4. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Could all this be said another way?; Toyota built the car's shifter and reverse beeper for the lowest common denominator - in other words, for those who shouldn't be driving to begin with since they don't know what they're doing!:D Jokes aside, I think it's a stretch to think Toyota used this type of assumption or thinking for the reasoning of the reverse beep.
  5. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    I like the reverse beeper.
    The Prius shifter is not a mechanical shifter, like a usual automatic or manual. It is electronic. Therefore, one loses the advantage of positive position feedback. More than once, the beeper has reminded me that I was NOT IN DRIVE.
    However, I do have a beef with the seat belt beeper that becomes insistent when you get to about 12-15 MPH. That I consider to be one beeper too many.
  6. Mendel Leisk
    41,343
    I like the reverse beeper. It can be irritating, but might save you from a stupid mistake.
  7. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I like it as well because I normally go to d for reverse. Seems backwards to me, but then maybe its me? H
  8. PapaGallo
    PapaGallo Junior Member
    58
    22
    nj
    "The Prius shifter is not a mechanical shifter, like a usual automatic or manual. It is electronic. Therefore, one loses the advantage of positive position feedback " Teakwood
    and the beep reminds you of the fact that you are in reverse, all it takes is one moment of distraction to forget that you either shifted into reverse or were in reverse, and press the gas thinking you were in drive. Its happened to me in two occasions, in which I inadvertently shifted into R and did not realize it because it was not a mechanical shifter, and the beep made realize that i was in R. And as a truck driver used to a back up alarm that is about 100 decibels, the beep of the Prius is no big deal.
  9. JThayer
    JThayer Cubic Zirconium Member
    46
    San Diego
    It seems backwards to me, as well. My initial inclination was to push the knob forward to go forward and pull the knob backwards to go backwards. But it didn't take long to train myself otherwise.
    Regardless, the only thing that the backup beep reminded me of was how annoying it could be. As soon as I found out I could set it to a single beep, I did so.
    But if you like it, then by all means, keep it. To each their own, I say.
  10. Blue Prius Texan
    Blue Prius Texan Crazy? Nah...just humorous!
    78
    Fort Worth, Texas
    My gosh, I've done that several times since getting my new Prius this past week. I feel like an idiot. It's definitely a habit from driving a stick-shift.
  11. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    The Prius doesn't tend to attract driving enthusiasts in the traditional sense of the word. So maybe the beeper is a good idea.
    I drove a GII for three years and never put it in reverse accidentally. First thing I did was deactivate the reverse beep feature.
    It seemed very intuitive to me. As far as a car with a manual transmission goes, there are lots of different positionings for reverse, and it's usually protected by a lockout or a press/pull requirement.
  12. jhinsc
    1,167
    259
    South Carolina
    Are you saying you don't want to wear your seatbelt!?:eek:
  13. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    I really do not object to the reverse beep, beep, beep...
    My Prius is so quiet when "ready", but before the ICE kicks in that the beep is my reminder that the car is on. But then again, at my age I don't take coffee breaks because I can't afford to be re-trained!
    Happy Motoring,
  14. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    It is bass-ackwards. ;) You are not alone. That this subject continually comes up is further proof.
  15. dancergene
    dancergene New Member
    arkansas usa
    my prius has the back up camera so when in reverse it is better than the beeper. think i look at the dash more than the road. going to get a scangauge soon so one more gadget to look at.
  16. Author
    Author New Member
    59
    When the dealer offered to nix the beep before I left the lot, I declined.
    Too many things in my life require pushing something forward to advance in that direction...standard shift Miata, throttles of Cessna 172/Cherokee 140/160, etc.
    The beeper is a great idea, if somewhat irritating.
  17. navy48
    56
    Indianapolis
    really? if only I had a Prius before I went and bought a smart car!:p
  18. oxnardprof
    oxnardprof Member
    250
    17
    Oxnard, CA
    I go along with those who like the beep. It is a helpful reminder that the car is in reverse. I find no reason to be irritated by the beep, but then again, I am an optimist, usually.
  19. ETC(SS)
    7,137
    Yeah, I get the logic.
    I still would have preferred they put the beeper on the outside of the car, especially since company policy is to back into a parking spot or use a pull-through. If this were a personal vehicle, I would run (not walk) to the nearest Toyota dealership and demand that they disable this 'feature'.
    I'm getting used to it...:rolleyes: slooooowly.
  20. Dochatley
    Dochatley Junior Member
    17
    Dallas
    2024 Prius
    :cheer2:
    This sounds like the most logical answer to the beeping I have heard. I have owned many cars over my 36 years of driving, both 4 and 5 speed manual and automatics and not a one of them had a back up beep. When I was in reverse I knew it because I put it there.
