Wipers Constantly On
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lex, Dec 30, 2010.
  1. lex
    lex 2005 Prius, always garaged
    119
    Fresno
    Hopped in the car this morning and found the front wipers running intermittently (every 5 sec) no matter what setting is selected--they can't be shut off. A brief search on the forum didn't reveal anyone else coming up with this problem, but surely I'm missing it? Thanks in advance.
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I'm betting your 12v battery is the original?
    You're lucky if they last more than 4 - 5 years and they cause all sorts of weird electrical gremlins as they start to fail. Has your mileage started to drop too?
    Definitely get it checked out - have a search of this forum on how to check your 12v.
    Good luck.
  3. lex
    119
    Fresno
    The original battery was replaced this year, however, the car was not driven for 40 days until I returned from England (I noticed Harrogate) this week. The wipers started this odd behavior after a few days.
  4. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Did you disconnect the 12v whilst away? Did you have to jump start the car when you got back? It still sounds like a 12v issue to me - I am completely uneducated though!
    Oooh did you pass through Harrogate? Were you over here on business or pleasure and did you enjoy the snow? Hope everyone was friendly to you.
  5. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Probability is high that GrumpyCabbie is right.
    There was a report 2-3 years ago of an incident where the wipers came
    on and the headlights intermittently flashed. It was a discharged 12V
    battery.
    Can't say why your newish battery would be low. I'm going to guess that
    it was low on your return and that since then, your trips have been
    shortish, lets say less than an hour. This will do little or nothing to charge
    the 12V battery back up. Patrick Wong has posted that it takes 8 hours of
    the car running in the READY condition to do any significant charging.
    You need to establish the condition of the battery by getting a voltage
    reading after the car has sat overnight.
  6. Patrick Wong
    18,210
    6,515
    The wiper system is of fairly simple design. I doubt that a low 12V battery would cause the problem reported by the OP. My guess is that the wiper switch on the steering column needs to be replaced.
    In the meantime I recommend that the OP find the 30A WIP fuse in the fuse/relay box located under the driver's side of the instrument panel and remove it, so that the windshield is not scratched by the wipers moving across dry glass.
