Unintended Acceleration -- While Parking
Discussion in 'Gen 3 Prius Main Forum' started by evpv, Dec 29, 2010.
Thread Status:
Not open for further replies.
  1. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm not going to make the assumption that there isn't a problem....
    Neither am I going to jump to the conclusion based on your friends experience and X amount of reports that there is a problem.
    Is your friends vehicle being checked out? The real "answer" would be if anything is discovered.
    Until then, it's all offensive and defensive speculation.
  2. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    My wife jumped a curb while parking - twice. Once almost like the video that F8L posted, landing on the nose of another car. She doesn't fit the age profile of common UA complainers, but she is short at only 5' tall, which is another common trait. She was/is also a relatively inexperienced and nervous driver, not getting her license until late in her 30s.
    In both cases we never doubted the problem was with her foot.
    Oh, and both times it was in a 2000 Mazda MPV.
    It can be alarming to read through the NHTSA stuff, but anecdotes do not a case make. I like this article by Edmunds to put it into perspective:
    Toyota Recalls Put into Context by Edmunds.com — Edmunds.com
    - D
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    You need to analyze these in the context of market share. Toyota is a very popular manufacturer and has sold more vehicles than most. If there were a ODI/NHTSA site for cell phones and you only look at the number of complaints with the iPhone, you'd think it's the worse performing phone ever made. If you were gullible enough to believe "syringe in the Pepsi can" as a real event, you'd think Pepsi is the problem. Same goes with you, evpv.
    Spend more time on this forum and you'll learn which are actual problems and which are human errors. The 3rd gen Prius brake fix is of course a real issue, but has nothing to do with unintended acceleration. There's the real issue of having to press down harder on the brake pedal in order to disengage the cruise control, but this shouldn't be confused with UA or in the case of human error, forgetting that the CC was on and you resume it by accident. The violent movements when reversing is a real issue that Toyota has yet to solve (although easily fixed ourselves for the time being by momentarily releasing your foot completely off the brake pedal when it happens), but again has nothing to do with UA.
  4. peterjmc
    917
    189
    Clarksburg, MD
    I've had my Prius V for almost a month.
    My car unintentionally accelerated while I was stopped and when the ICE kicked in. My foot was on the brake at the time and the car lurched forward slightly while I was stopped. If my foot was light on the brake pedal I surely would have hit the car in front of me.
    Didn't think to report it to my service department but I suppose I should.
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Have you gone to the site and read through many of the complaints? It'll take you quite a while to read 212.
    2010 Honda Civic outsells 2010 Prius by quite a bit. There is something like about ... 10 Civic vehicle speed control complaints compared to 212 for this year on the Prius. Still, 212 out of 140k Prius sold in US is only 0.15% occurence assuming no repeat complaints. But, I had stated I did look at many other brands and years, and UA complaints are fairly rare. It's not just the Prius, Camry, Corolla, RX350's have more UA complaints in NHTSA than Accords, Civics, Fusions That's just how it is.
  6. DataWrangler
    DataWrangler Prius Owner (finally!)
    128
    West Houston, Texas
    [Disclaimer ... I have yet to read the incident reports] How many are there for the 2010 Prius? How many are there for other cars?
    Playing devil's advocate here ... Assuming the parking events are not human error ... Does this occur when the ICE is starting up after being off?
  7. DataWrangler
    128
    West Houston, Texas
    Is this a case of statistical bias? Proportionally more Toyotas on the road would result in proportionally more incident reports...
  8. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Sure, have you count the number of complaints against Pepsi regarding syringes found in their cans even though Coca-Cola outsold Pepsi that year?
    Prius and Toyota in general are victims of media hysteria (made worse by our own government) that led to those complaints, as were the case with Pepsi's needle scare and iPhone's Antennagate.
    Logic and common sense go a long way.
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    When this happened, what was the outside temp & how long was the car running? If it happened recently I'd say the car wasn't running long. ICE temp was barely over 100F then when the car was stopped at a traffic light it dropped far enough to cause the engine to spin up.
    Maybe the cure is to have Toyota replace the software so the car only moves forward when the accelerator pedal is depressed.
  10. donee
    donee New Member
    2,956
    198
    Chicagoland
    :rolleyes: Damn Center Console !
  11. bisco
    52,763
    yes, i do.
  12. DataWrangler
    128
    West Houston, Texas
    While reading through the NHTSA complaints on the Prius I noticed something interesting ... double, triple, and even quadruple posting of the same incident under different headings. This alone would explain why there are more Prius incidents than for other cars.
    Ignoring this, these reports are still troubling, but they are statistically insignificant. I for one won't believe there is a problem until I personally experience it. Unfortunately no one will believe me if it does happen. (kinda like UFO encounters) :eek:
  13. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I haven't had UA or loss of braking while parking but I've had SIA: sudden increase in acceleration.* Nothing dangerous since I'm trying to accelerate. It's more of a response change where the acceleration suddenly goes from low to the expected level.
    But, given that behavior I won't entirely dismiss the idea of an electronic error.
    * Has only happened since winter arrived. I drive in ECO mode. A minute or two after starting, accelerating up a mild slope, near top of the ECO zone on the HSI, LOD on ScanGauge is only in the high 50s or 60s but then it suddenly jumps to the 90s and acceleration increases.
  14. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    The engine in the Lexus RX350 has similar delayed characteristics. You're reading too much into it.
  15. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    I thought not. A preliminary report was given in August, indicating the've investigated 58 cars out of 3,000 complaints. But that report doesn't indicate if the results were from NASA or NHTSA. I'll put a lot more weight on the NASA results.
    "Investigators with NASA and the National Highway Traffic Safety Administration have reviewed event data recorders, or vehicle black boxes, on 58 vehicles in which sudden acceleration was reported. In 35 of the 58 cases reviewed, the black boxes showed no brakes were applied. In about half of those 35 cases, the accelerator pedal was depressed right before the crash, suggesting drivers of the speeding cars were stepping on the accelerator rather than hitting the brakes. Fourteen cases showed partial braking. One case showed pedal entrapment and another showed that both the brake and the pedal were depressed. Other cases were inconclusive. The black boxes are devices that track a number of details about a vehicle around the time of an accident, including which pedals were applied and how fast the car was traveling. Olivia Alair, a Transportation Department spokeswoman, said the review of the black boxes was “one small part†of the investigation, which is expected to be completed later in the fall. Alair said they were still at an “early period in the investigation†and experts with NASA and NHTSA were “conducting research at labs across the United States to determine whether there are potential electronic or software defects in Toyotas that can cause unintended acceleration.â€
    So here's what they've found so far:
    23 cases that were inconclusive
    19 cases of partial throttle application
    14 cases of partial brake application
    1 case of simultaneous brake and throttle application
    1 case of pedal entrapment
    Let's wait for the final results.
  16. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Normal. Once the ICE coolant temp hits 103F full power is available and kicks in. Really noticeable if you are going up an incline.
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Until then, the smart money is on cockpit error.
  18. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    The Prius has several computers, if one ore two go all Terminator, the rest will shut everything down and the display will light up in lovely red and yellow symbols! The ABS system needed a tweak to tone down the millisecond loss after a bump thing, doable because Toyota could easily replicate it, no doubt helped by the work many here on PC did exploring the issue with their own experiments! Can anyone replicate the SUA incidents? No?
  19. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    I did some research on the NHTSA site for Prius unintended acceleration complaints for models ranging from 2001 through 2010. Using the Vehicle Speed Control section, I recorded the total number of complaints, the number of those complaints regarding unintended acceleration, and the number of unintended acceleration complaints within a year of when the vehicle was sold. Obviously the first few years were much lower sales volume, but the Prius has had fairly steady sales figures for the past few years.
    2001 Prius
    Total Vehicle Speed Control Complaints: 14
    Total Unintended Acceleration Complaints: 3
    Unintended Acceleration Complaints in the first year: 1
    2002 Prius
    Total Vehicle Speed Control Complaints: 7
    Total Unintended Acceleration Complaints: 5
    Unintended Acceleration Complaints in the first year: 0
    2003 Prius
    Total Vehicle Speed Control Complaints: 3
    Total Unintended Acceleration Complaints: 2
    Total Vehicle Speed Control Complaints: 40
    Total Unintended Acceleration Complaints: 22
    Unintended Acceleration Complaints in the first year: 3
    Total Vehicle Speed Control Complaints: 77
    Total Unintended Acceleration Complaints: 52
    Unintended Acceleration Complaints in the first year: 15
    Total Vehicle Speed Control Complaints: 60
    Total Unintended Acceleration Complaints: 50
    Unintended Acceleration Complaints in the first year: 10
    Total Vehicle Speed Control Complaints: 80
    Total Unintended Acceleration Complaints: 55
    Unintended Acceleration Complaints in the first year: 9
    Total Vehicle Speed Control Complaints: 101
    Total Unintended Acceleration Complaints: 80
    Total Vehicle Speed Control Complaints: 51
    Total Unintended Acceleration Complaints: 42
    Unintended Acceleration Complaints in the first year: 32
    Total Vehicle Speed Control Complaints: 212
    Total Unintended Acceleration Complaints: 184
    Unintended Acceleration Complaints in the first year: 184
    Digest, make some graphs, research other cars and submit similar data for comparison, dismiss all of them as driver error.
    Reference:
    https://www-odi.nhtsa.dot.gov/complaints/index.cfm
    Step 1: Vehicle--> Search Selected Type
    Step 2: Year-->Select Year-->Submit Year
    Step 3: Select Make-->Toyota-->Submit Make
    Step 4: Select Model-->Prius-->Submit Model
    Step 5: Select Component-->Vehicle Speed Control-->Click "Select this box if you would like to see a full summary" -->Submit
  20. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Simple question, did you read the complaints?
Thread Status:
