I'm FINALLY One of You! After 2 Years of Waiting - New Prius Today
Discussion in 'Gen 3 Prius Main Forum' started by Lottamoxie, Dec 29, 2010.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    730
    your words don't make sense - could u explain?
    won't u jolt? I have put my car into park while going forward in the parking lot (aiming for the radio button) and it scares the **** out of me.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Let me try this:
    1) Put in "R" gear and car will move backward
    2) Hit the brake and stop the car
    3) Put in "D" gear and the car will move forward
    All I am saying is, you can skip #2 and put the car in "D" while rolling backward. That practice is bad for auto tranny but it doesn't apply to Prius.
  3. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    Ahh I see.
    Well the backing out I do is primarily from my driveway and I pretty much have to step on the brake unless I want to back into the parked car opposite my driveway (and I sure don't).
  4. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    I sure do have to read that manual tonight.
    - Rearview Mirror did not dim
    - Gotta find the headlights auto-on setting
    for starters.....
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    That was my goal as well, until I walked into the Toyota dealership April 2009 and they had 0% interest. So I put $27,000 in an account making 2%, and pay Toyota out of it every month. It is making me money, but I still feel dirty making car payments until March 2012.
  6. macmaster05
    4,050
    730
    Yeah but won't your car jolt to a stop, mainly if you're going at 5mph or greater? I'm sure the transition isn't smooth...
  7. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    The transition will be smooth because the rotor will have inertia moving forward even when the current is reversed. The reversed magnetic field will push the rotor in the opposite direction until the rotor will actually move into that direction - since there is no contact between rotor and stator, there cannot be any jolt.
    I don'T know if the HSD will refuse to select from D to R or from R to D to avoid generation of parasitic currents when the current gets reversed and the rotor is still rolling in the opposite direction. My assumption, but cannot verify.
  8. macmaster05
    4,050
    730
    Interesting. So how fast can I be going in reverse and expect a smooth transition? I'm scared to try, lol.
    And why does putting the car in Park from 'D' when moving jolt the car to a sudden stop? At what speed does it not allow you to put it in park?
  9. pakitt
    2,173
    1,313
    Colorado
    When from D setting to P it will result in a jolt because the rotor/wheels are blocked mechanically, not electrically.
    I have seen other posts in the forum talking of a max speed beyond which P will refuse to engage to avoid mechanical damage to the rotor/wheels lock. Something like 5mph or less. I cannot recall - I make sure that I press the brakes when applying P....
    I have never tested the speed at which I can shift from D to R or from R to D, but surely I am not braking when shifting when parking my Prius - I don't have to since changing from, say, R to D, will smoothly stop the car and then move it in the opposite direction without actually never touching the gas pedal (the crawl simulation will take care of all the gas/movement I need when parking).
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I think you can do it below 7 MPH. Try it at a few MPH. It is pretty smooth.
  11. macmaster05
    4,050
    730
    You have no idea how excited I am to try. Lol.
  12. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    Question (and yes I did search for it on this forum as well as look in the manual):
    There's a sensor of some kind on the forward right dash near the windshield. What is that sensor for?
    Comment: I think not having auto-on headlights is a big miss.
    Comment: the auto-dimming review mirror is not very good. I miss my manual dimming mirror from my Saab. Just a flip of the switch and it blocked the headlights behind me very well. This one...frankly I don't notice a difference.
  13. pakitt
    2,173
    1,313
    Colorado
    Hi Lottamoxie,
    the sensor is referred in the user's manual (US/Canada version):
    • page 207 "Headlight control sensor" - directly
    • page 591 "Meter, navigation system, instrument panel" - indirectly
    • page 589 "Automatic light control system" - indirectly
    Essentially the sensor is a light sensor used:
    1. regulate the A/C functioning to increase fan speed under the sunshine in summer
    2. regulate auto headlights function
    3. regulate the brightness of the MFD (Multi Function Display) and the head-up display; regulate the navigation display (night/day).
    I am not aware of any other function related to this ambient light sensor.
  14. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    Thanks Pakitt!
    I figured out if I just leave the headlights on all the time then they'll be 'on' without me having to remember to turn them on at dusk! Duh. My Saab has daytime running lights, which are pretty much regular headlights, so this would be the same thing, in essence.
    I still don't like the 'auto-dimming' rear view mirror though. It's not nearly dim enough at night. I'd make it darker by a factor of 2 or 3.
  15. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Here in Pinehurst, I'm averaging 52.7 based upon current temps (which suck), and the few miles I drive. BTW, did you get the fabulous Barcelona Red? What will you name your Prius?
    Happy Motoring,
    Happy B-day;
  16. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    I put the color I selected in PURPLE above...look at your posting; it's right in there. ;-D
    I don't typically name my cars.
  17. twittel
    1,605
    148
    Mt. Pleasant, SC
    Penny's Dad,
    Me thinks your posts are not right, or maybe I don't get it?
    Happy Motoring,
  18. Tideland Prius
    16,589
    It's not the mirror that's the issue. It's the rear spoiler of the Prius. Put the exact same mirror in a sedan and it'll work fine. The rear spoiler confuses the mirror because it's right at the height of the light sensor. It's good in a sense because the headlights are blocked by the rear spoiler anyway but like you've noticed, sometimes the rear spoiler doesn't quite block the headlights and it goes right to the mirror at full brightness. In the Gen 2, we can go around it by rotating the mirror upside-down so that the light sensor is mounted higher up and can "see" the headlights better. We can't do that in the Gen 3... the mirror hits the ceiling.
  19. vday
    vday Member
    312
    Israel
    Like that
    From me too
  20. concertinajohnnyboy
    104
    Minneapolis
    Congratulations!! I've had about six years with the Prius. And, about a year with the 2010 V. I love it. And, Lexus will be offering the same 1.8L in one of their lowest models. Hatchbacks can be very helpful. I have to load accordions in my Prius when I take a vacation to Wisconsin.
