EV mode not available sometimes
Discussion in 'Gen 3 Prius Technical Discussion' started by Solscud007, Jan 4, 2011.
  1. Solscud007
    Solscud007 New Member
    59
    Nyack, NY
    I didn't see anything in my search. Why is EV mode not available sometimes? i know for sure it isn't available when i start the car. But sometimes else it is not available. And I don't mean "excessive speed" or "low battery"
    i have tried to use it in other circumstances and I get the message EV mode is unavailable. This is after driving for some time.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    There is a thread on here where someone with a Scangauge has determined that EV mode is not available if your coolant temperature is below 67 degrees F.
  3. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    EV button mode is available when:
    HV system temperature is not very high
    HV system temperature is not very low
    ICE coolant temperature is above 20C (68F)
    SOC is above 50%
    Speed is below 40 kmh(25mph)
    Power demand from throthle pedal is below the limit
    Defrosting is off
    Tempomat is off
    Humailesh and jdcollins5 like this.
  4. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Can you give us a further explanation for Tempomat:)
  5. uglymuddah
    uglymuddah Junior Member
    24
    The Netherlands
    Tempomat=CC
    2 people like this.
  6. Solscud007
    59
    Nyack, NY
    Ahh got it. thanks guys. Is stealth mode as good as EV for low speeds?
