Towing Tear Drop Trailer
Discussion in 'Gen 3 Prius Technical Discussion' started by Saphteemon, Jan 3, 2011.
  1. Saphteemon
    Saphteemon Junior Member
    36
    Orange County
    So....now that I have the Prius......I'm thinking about buying a tear drop trailer for some weekend camping....[IMGLINK]
    http://www.roamingtimes.com/a/consumer/images/camp-inn-teardrop-trailer.jpg[/IMGLINK]
  2. Saphteemon
    36
    Orange County
  3. Saphteemon
    36
    Orange County
    they typically weight about 1000 lbs and have a 90 lb. tongue weight....
  4. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Tents are much lighter, and even more aerodynamic. Especially in the trunk. ;)
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Read the manual... Toyota doesn't recommend towing anything with the Prius.
    2 people like this.
  6. Saphteemon
    36
    Orange County
    phooey......guess i'll have to use my f-250 then.......:p:p
  7. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    I'll bet you could easily tow a trailer designed to be pulled behind a motorcycle. Some of them hold a lot of volume and most are very light and aerodynamic.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Oh I agree, I have a single place trailer I haul trash and stuff with I had plans to hookup to the Prius. Probably still could but I suspect it would void the warranty.
  9. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    People have towed light trailers (<1000 pounds) with the Prius, but I'd recommend not doing a lot of it, and keep the speeds lower.
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Yep. If you save up for the fuel all year it shouldn't strain the budget too much.
  11. RobH
    RobH Senior Member
    2,376
    988
    70
    Sunnyvale, California
    This travel trailer weighs about 560 pounds empty. I've towed it about 600 miles so far, and I'm generally happy with it. The only complaint is the 32 mpg. I guess the aerodynamics could be a bit better... The power is adequate, certainly better than many trucks on the same roads. And this with a Gen2 - a Gen3 has considerably more power.
  12. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Just curious, but what advantage do these little trailers offer over a good quality 4 person tent?
  13. patsparks
    10,664
    567
    No tent to erect!
  14. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I have used my 2009 to tow and launch my 17 foot day sailor - the trailer and boat weigh about 750 pounds and I have been very happy with how the Prius handled it. Your trailer will likely be heavier, but aerodynamics should be a world better than a sailboat.
    On my commute someone has a Tab teardrop trailer parked in their driveway. It is awfully cute and in looking at thir website it seems to be very well thought out and cool.
  15. RobH
    RobH Senior Member
    2,376
    988
    70
    My trailer replaces exactly that. The trailer is off the ground, which means that it is easier to get into, and the surface that you sleep on is not dependent on the surface of the ground. It's a lot drier than a tent in wet weather, particularly if you end up in what turns out to be a streambed. I have a 6" foam mattress in the trailer, instead of the air mattress used in the tent. In general, the trailer travels already set up, while a tent and cooking gear are a project every time you settle.
    On the other hand, the car mileage sucks (32 mpg instead of 47), you can't travel as fast (55-60 mph instead of 65-70). Parking lots can be a problem, depending on how they're set up. Towing anything is a bigger project than not towing it. There is a campsite I regularly use that is accessed by a 6 mile long dirt road that is already marginal for travel in the Prius. The space at the site is limited, and turning the car around is a problem. I'd like to take the trailer there next time, but I'm not sure it will work.
    So the answer is that a small trailer is a step up in convenience and comfort from a tent. It's no replacement for the home-on-wheels many people use, but then $1000 buys you less than $80,000.
  16. Saphteemon
    36
    Orange County
    I like it......:rockon::rockon::rockon::rockon:
  17. dinger_greg
    dinger_greg New Member
    86
    Brookfield, WI
    Is that the 4x8 trailer they sell at Harbor Freight?
  18. RobH
    RobH Senior Member
    2,376
    988
    70
    The red part is the Harbor Freight foldable 4x8 trailer. They have another one that doesn't fold that's rated for a bit more weight. They have sales all the time, plus you can usually get a 20% off coupon. I think I paid about $240 after all the games, down from $400 list.
    The brown part is 4x8 sheets of 1/2" plywood from Lowes/Home Depot. Plus some 2"x2" for bracing and to attach the plywood at corners.
    All of the ready made teardrops that I've seen are a lot heavier than the 560 pounds that this one came out at. That may work with a stronger car, but I was trying hard to keep the weight at a minimum with conventional materials. A conventional teardrop shape is certainly more aerodynamic, but also an order of magnitude more difficult to build.
    As for plans, buy a trailer & cut some plywood to fit. The two sides clamped together and cut as one piece, including the door openings. Other than that, the smaller pieces were roughly cut oversize, assembled, and the excess trimmed off with a router.
    The first upgrade that I'd recommend is to use a 5x8 trailer with 5 lug tires. But that's another $400 and a few more pounds. Plus you'd have to either build up some 5x8 sheets of plywood from 4x8 stock, or use 5x10 sheets at 4x the price. It's a 4x8 world out there...
  19. DaYooper
    DaYooper Member
    106
    Sout of da UP eh!
  20. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Rob, I like your no nonsense solution to building a trailer.:cool:
    You could build rounded end caps from foam plastic and fiberglass and even make them into storage compartments (with access holes to use them from inside the trailer so you don't need outside doors on them).for light stuff. They would help the aerodynamics. Whether is would be worth the effort or not, is another question.
