New owner confused as hell
Discussion in 'Gen 2 Prius Fuel Economy' started by mattleerocks, Jan 4, 2011.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    730
    12v battery is same as any other car. Probably $100?
    The tank technically holds 11.9 gallons, although I never reach even 9 gallons even when my last pip is blinking.
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    My local dealer quoted me $240.
    11.9 gallons, but it can vary significantly, due to the bladder. See 2004 Toyota Prius FAQ. The most I've ever put in my Prius was 9.975 gallons. To prevent from running out of gas, I would get gas soon at 2 pips and would REALLY get gas ASAP at 1 pip.
    Don't run out as a lot of newbies do by multiplying mileage on MFD * 11.9 thinking there should be enough and then suddenly running out. You have no idea how much is really in there. Also, don't keep trying to force more gas into the tank once the pump has clicked off. I'd almost never top off, but if I did, I'd add no more than 1-2 more clicks.
    Habitual topping off can cause damage, a CEL light and an expensive repair.
  3. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Unfortunately not. :(
    There's been lots of chatter on the subject of the 12V in threads like:
    http://priuschat.com/forums/gen-ii-...installation-yellowtop-12v-aux-battery-2.html
    http://priuschat.com/forums/gen-ii-...ternative-v-power-better-than-optima-oem.html.
    http://priuschat.com/forums/gen-ii-...2v-battery-replacement-preemptive-strike.html
    I even asked a question on this and got an interesting reply at http://priuschat.com/forums/gen-ii-...ry-why-elearnaid-seattle-area-installers.html.
  4. macmaster05
    4,050
    730
    Ok. $240 still isn't bad.
  5. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    If you have any DIY skills at all I'd suggest going with the eLearnAid kit linked earlier by JimboPalmer (post #18 of this thread).
    - D
  6. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Hm, also, if your car isn't aligned, it can make your MPG drop by 2 to 3mpg.
    Cold weather can cause it too.
    Wind.
    Hills?
  7. mattleerocks
    mattleerocks New Member
    24
    Just a little update. So I inflated the tires to the specified PSI and now I'm getting 42 mpg. I've been working to find the sweet spot on my gas pedal that allows me to maintain speed and good mpg. I'm going to have to give the dealer a call to schedule a 12v battery replacement too. Overall its a good car. I'll have to get used to how slow it is but I didn't buy it for speed so its okay.
    Thanks for the advice everyone!
    Pics of my car:
  8. mattleerocks
    24
    Lots of hills where I drive. They are pretty much what kill me right now. Gonna drive my car to Mission Viejo this weekend so I'll see what kind of mpg I can average on that trip
  9. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Drive as though you don't have brakes.
    That means anticipate. Watch for traffic patterns, and stoplights. If you can slowly roll through a signal change (watch how semi drivers do it) rather than stop, wait, start, you will keep momentum working for you. Watch traffic -- are people speeding up, then slamming on the brakes for another slowdown? Just drive slower, steadier, and watch how you flow through the traffic this way. It improves MPG, and it improves your mood! :)
  10. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Mattleerocks,
    Do not confuse accelleration with power. That is a common mistake. The Prius achieves accelleration by avoiding shifting time, and having a transmission with a large ratio range. This allows the engine to get to full horsepower, at a much slower speed than other cars.
  11. mattleerocks
    24
    Battery died on me this morning. Car is at the dealer getting it replaced. Lets see if a new battery improves my MPG
  12. darelldd
    6,059
    389
    Northern CA
    It surely can't hurt!
    So refreshing to have somebody come on here - from a performance car perspective - and respectfully want to understand the Prius for what it can do instead of what it can't do. Hat off to you! As far as the Prius not being "fast" I guess you mean it doesn't accelerate as hard as you're used to. It'll go plenty "fast" enough, though it has been awhile since I've been over 100 mph (well at least in a gas car). As I spend most transportation miles on my bicycle, I'm typically astonished at how much power the Prius has. Way more than any mortal human ever needs, certainly! It is all about perspective.
    Oh, and it has already been said - don't fret the gas mileage until you get used to the car and have a couple of tanks burned. It'll all makes sense before you know it. And you WILL start driving it without thinking about it very soon. It just happens. Then you'll glace at your average mileage at some point and notice that it's pretty good!
    Welcome to the Prius club!
  13. mattleerocks
    24
    Well thats not true. I am guilty of mentioning the negative aspects of the car. Its a slow car that understeers quite a bit (and I have the touring model) and its not a fun car to drive either because of this. But I didn't buy this car as a fun car. If I wanted a fun car, I would have bought the 6.2L V8 Chevy Camaro. But I'd be burning through gas like a maniac. This is a great point A to point B car and its got a lot of practicality in it. Compact car footprint with mid-size interior and lots of trunk space and out of this world mileage. Its a great practical car with a lot of great features. Overall, I like it :)
  14. zonie911
    zonie911 Member
    585
    Nashville, Tennessee
    Keep in mind this gen II has a bladder/type gas tank- and if you let it get too low on gas--it will take a few fill ups to expand the bladder.
    I know the Audi was absolutely fab... but you will grow to love the Prius.
  15. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  16. macmaster05
    4,050
    730
    Suspension upgrades are always worth it.
  17. mattleerocks
    24
    Don't get me wrong. The Audi was a blast to drive but every few months there was something wrong with it. My Prius has navigation, JBL sound system, push button start, and more importantly, Reliability. The reliability by itself makes it more than worth having.
    I hated the Audi because of how unreliable it is. I still got it though :)
  18. darelldd
    6,059
    389
    Northern CA
    I'm still trying to figure out which part of what I said isn't true?
    That the Prius doesn't accelerate as quickly as more powerful cars?
    That you want to understand the car for what it can do?
    That I usually ride a bike?
    That you'll get used to driving it?
    Maybe you aren't giving yourself enough credit for wanting to get the most out of the car vs. only complaining about the lack of power and handling? I get that you enjoy powerful performance cars. But you realize that this isn't that. I'm trying to compliment you... just stand there and take it like a man! ;)
  19. mattleerocks
    24
    I was referring to this statement:
    "So refreshing to have somebody come on here - from a performance car perspective - and respectfully want to understand the Prius for what it can do instead of what it can't do."
    I really can't complain about how slow it is any more so I might as well try to get good mpg lol
  20. mattleerocks
    24
    Just a little update on whats going on. I've driven a almost 300 miles on my next tank of gas. I'm up to 43 MPG now. Tire pressure is above the 42/40 limit, new 12v battery, warmer weather, etc
    I think the only problem is that my oil level is above the max. I think the fact that I take a lot of short trips around town doesn't help either. Either way, I'm pretty satisfied with my purchase :)
