Does running higher (40+ psi) really help MPG that much. Testing this weekend
Discussion in 'Gen 3 Prius Fuel Economy' started by kneedraggin, Jan 8, 2011.
  1. kneedraggin
    kneedraggin Junior Member
    I know I know....it seems that this type of post has been beaten to death and while I am definitely convinced that running higher psi in your tires than recommended in the door jam by the manufacturer will get you better mpg....what is debatable is just how high to run them above the recommended specs.
    I am definitely still a rookie to the hybrid scene and this 2010 prius is my first one that I have owned. Upon picking up my new car from the dealer who had set the tires at 35f 33r, I had gotten roughly 45mpg on my first tank. Upon discovering this wonderful site, I decided to bump the pressures up to 40f 38r and managed to get 49mpg on the second tank. After even more researching, it seems many people had success with bumping the tire pressures into the "overinflated" range of 50+ psi and I did so as a trial run at 50f 48r and was amazed to see my actual next tank of gas only hit 45mpg once again. Totally confused, though since all of the miles on each tank were not equally distributed (similar but not identical) I cannot right away assume that pressures above 50psi is in any way detrimental to mpg, BUT this does have me wanting to test out the theory that someone once proposed in here that depending on the roughness or smoothness of the roads you drive on, higher psi in your tires don't always mean higher mpg's. I am doing a road trip from LA to San Diego this weekend and will be putting this theory to the test. I will run 38f 36r on the way down there and 50f 48r on the return home.....trying my BEST to keep all factors (ambient temps, cruise control/climate control settings) the same.
    I will post my results when I get back Sunday evening.
  2. s1njin
    s1njin New Member
    106
    Sellersville, PA
    If there is a elevation / grade difference coming to and from, your results will be completely invalid.
  3. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi k...d...,
    It does help mileage. But initially Prius people started running 42/40 PSI (F/R) to avoid tires wearing out on the outer edges in about 1/2 th mileage they were rated to last...
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Also wind velocity and direction, where the gas pump clicks off during fill and/or MFD consistancy, traffic, driver inconsistencies. On a two tank test those variations easily add up to a bigger difference than you will get from a change in tire pressure.
  5. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    How much gain in mpg for how many psi extra air is very hard to determine in any short mileage testing. Unless you can conduct closed circuit test runs in a climate controlled environment there are just too many uncontrolled variables. Anyone who has ridden a bike with soft vs hard tires can attest to the fact that hard tires require less energy to ride. This will directly translate into better mileage with harder tires, its the quantities that are involved that create the controversy.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I have seen some good test work done on hypermiler, ecogreenie, forums that give a generic idea what quantitative difference tire pressure makes. That would be more meaningful than what an individual could accomplish by driving one car under real world condition. There are too many other uncontrolled variables.
  7. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Depends.
    Different cars, road conditions, weather conditions and drivers work the tires differently.
    I have the OEM Yokohamas and the highest I've run is at 43/41. That was during summer and found that on warm days the car was a bit skittish on lower-grip surfaces. So I've reduced my tire pressures to 41/39 and I find it comfortable.
    Now it's winter and I'm using the same tire pressures. I drive almost exclusively on busier roads so I don't have to deal much with bad conditions. But I also feel comfortable with an occasional bit of slip in poorer conditions. I just adapt to the conditions by making gentler maneuvers.
  8. kneedraggin
    i wish i had the means to REALLY test this theory out...so it goes without saying these results with be highly unscientific.
    I just wanted to do it for my own peace of mind as I did hear from someone that just increasing the tires to well above max sidewall psi doesn't just infinitely increase mpg's. i was most curious as to the best tire pressures would be to maximize mpg without needlessly raising them to above sidewall max
  9. ggcc
    ggcc Member
    132
    Bay Area, CA
    2014 Prius Plug-in
    How about 20f-18r and compare with 35f/32r?? Just kidding!!!
  10. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    This has been covered in a million threads. Yes it makes a huge differnce. I run 47/49.
  11. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    I say go ahead with your test. It would be best if you could do it both ways with each tire pressure . . . Only kidding, unless you do this trip frequently, in which case I bet you could, with something like similar temperatures and maybe even winds.
  12. Former Member 68813
    3,524
    983
    US
    Mythbusters did that. They got 6% better MPG with 40PSI and 7% better MPG with 60PSI over 35PSI control. However, i'm afraid their measurements were not precise as they got only 2% MPG hit at 10PSI!
  13. s1njin
    s1njin New Member
    106
    Sellersville, PA
    Wow.
    10 psi = expected mpg - 2%
    Control (35) = expected mpg
    40 psi = expected mpg + 6%
    60 psi = expected mpg + 7%
    So .... a 14% increase in tire pressure over control nets you 6% bump in mpg.
    70% increase in tire pressure over control nets you only 1% more mpg.
    I wonder how much less all these cars would rattle if they weren't riding on the rock hard 42/40s that are often recommended here. I'm running 38/36 - maybe that's why they don't bother me so much? And maybe that's why my mileage isn't that far off of what others are seeing at that psi.
    Just thinking out loud here folks. I like myth busters.
  14. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The bogus number for 10 psi is one example of why I consider Mythbusters to be entertainment that frequenly but not always has some factual basis.
  15. s1njin
    s1njin New Member
    106
    Sellersville, PA
    I should have clarified my previous comment by saying - "I like Myth Busters because they make me think".
    I can't really get on board with the 10 psi either, but if there is truth in the rest of it, it does give one reason to pause and consider the pressure more.
  16. RufusNapkin
    RufusNapkin New Member
    36
    Firmer shocks and struts. Has anyone tried this approach for increased fuel efficiency and more power? I did this on a Camry and instantly the car ran more effortlessly, all around. (there was NOT a "Whole lotta shakin' going on" from then on)
    ARE there "sports suspension" aftermarket shocks and struts out there for the Prius?
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    There would be some small secondary effects. The car would spend more time at nominal ride height where the wheel alignment is correct (assuming the alignment was done correctly).
    There would also be some effect from the car body maintaining it's nominal design ride height/attitude more of the time. The time the car sits lower (less aero drag) might offset the time the car sits higher (more aero drag) and make that a wash though.
    I doubt that you could measure the difference by checking your mileage at the gas pump but it would be an interesting experiment if controlled properly.
  18. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    Just remember that higher tire pressures will contribute to a more bumpy ride. I also take into consideration just how much a tire will bounce or skip on the pavement in a sudden stop. ABS brake systems will not work well if the tire does not maintain contact with the road surface. I have also posted long ago that any insurance expert who is sharp will check the tire pressure of the vehicle in question if the driver blames the brakes. Maybe most insurance folks would not think of checking this, but I would if I was doing a report on such an an investigation. I have tried the higher pressures and did notice an increase in overall mileage on the freeway, but it was not worth the bumpy ride to save a few percent at the pump. When you consider the fact that some parts of the car may just rattle apart from the higher tire pressures, its not worth it to me. I am happy running 38Front and 36Rear to have a smooth ride and maintain the braking system that was designed for the vehicle. Slowing down overall and not having a lead foot on take off are the objectives for me. Your mileage may vary. I average between 45-50 MPG day in and day out. For a vehicle that is over 5 years old and has 142 thousand miles, I'll just stick to safety first and fuel efficiency second, in that order.
  19. kneedraggin
    Okay....here are the results from my weekend trip down from LA to San Diego. I tried to keep as much constants as I could. NO this is not scientific data nor in a completely controlled environment, but I did want to see if there was in fact any negative effect on fuel mileage with tire pressures above max (50+ psi) like my butt mpg meter was telling me.
    My results: Stock 15" Yokohama Tires
    Trip A (from LA to San Diego)
    61 degrees outside
    Climate control set to Auto 74 degrees (no ac)
    Tires pessures: 38f 36r
    143.7 total miles
    54 mph avg
    51.5 mpg
    Trip B (back from San Diego to LA)
    61 degrees outside
    Tires pessures: 50f 48r
    144.9 total miles
    58 mph avg
    47.3 mpg
    **I will tell you this...not only is the ride MUCH louder and harsher with the tires at 50psi, I definitely feel the actual mpg were suffering at this high of a psi. It was mentioned in a thread before that the "bouncing" of the tires on the rougher roads (pretty much the only kind in LA) actually lead to worse mpg. I am starting to buy into that philosophy. I am unofficially concluding that while running above the manufactures recommended psi FOR SURE helps increase your fuel economy, going really high as in 50+ psi...not the same. I would imagine anywhere in the 38-42psi range for the front tires and 36-40psi range for the rears will "maximize" your fuel economy.
  20. s1njin
    s1njin New Member
    106
    Sellersville, PA
    Nice to see somebody w/ that many miles !!! I drive about 76 a day round trip so I'll be piling the miles on pretty quickly.
    Also, I am running 38f/36r. Figured it was a good compromise between getting higher mpgs and not ruining the ride any.
