Led DRL DIY
Discussion in 'Gen 3 Prius Accessories and Modifications' started by spiderman, Jan 8, 2011.
  1. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Just finished installing some DRLs using LED Strip kit. Big thanks to Rodney () for the idea and helpful tips! The job took about a total of 3 three hours and about $24..
    I bough the kit from iJDMToy.com. I also bought LED replacements for the parking light bulb.
    1. Per the Toyota instructions (thanks Paja), I removed the front bumper skin.
    2. Thoroughly cleaned the underside of the headlight using rubbing alcohol.
    3. The strips have 3M adhesive on them already so I removed the backing and applied the strip to the underside of the headlight. The strip is just shy (1/8") of the leading edge of the headlight.
    4. Wired up the lights. Like Rodney, I tapped into the parking lights. I was originally going to wire it so the lights were on whenever in Ready mode but went the other route. *Note be real careful not to pull hard on the wires coming from the strip, there are easy put pull out.
    5. Reassembled. Bonus, no extra parts!:rockon:
    See photos attached. Added a daylight photo:
  2. HAWAIIANBUILT
    HAWAIIANBUILT Senior Member
    824
    791
    69
    SO CAL
    HEY SPIDERMAN !!!
    Those came out AWESOME !!!
    Great job on the installation, looks real clean and flush when turned off too ...
    Thanks for doing the DYI and the Heads Up info , I've learned my lesson !!!
    Keep us posted on your Progress !!!
    Rodney
  3. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    looks great but how bout some pics in daylight since they are DRL, right?
  4. macmaster05
    macmaster05 Senor Member
    4,050
    730
    ooo nice work!
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It was about 1:00 pm when I took the picture so yeah it was daylight. ;)
  6. Tideland Prius
    16,575
    lol... guess we'll have to wait til spring for brighter photos!
    Looks great though! Are they really that blue/purple? or is it the camera?
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    TP, yeah they do have much more a blue hue than I wanted. I ordered "Xenon White" color.
    Say is it possible to upper case the letters in the title of the thread? When I tried, it forced them lowercase.
    Thanks.
    p.s. there seems to be a blueish tint to the headlight lens. That is causing some of it.
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    it looks great! Excellent work!
  9. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Clearly you must have done something incorrect. Everyone knows a proper install always results in extra parts :D
    Seriously, it looks nice. I think if they were truly the xenon white, it may blend in too well with the white car.
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Nice job ! Thanks for the write-up and photos.
  11. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    OK, lets rephrase that.
    How about a pic OUTSIDE the garage in daylight![​IMG]
  12. Tideland Prius
    16,575
    Must be a vbulletin thing. I can't do it either. I have to manually change DRL and DIY without touching LED. That way, I can get those two words to be in CAPS but I can't do anything about LED.
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    OK added a "daylight" photo. Of course for us up here that does not mean much as we (our neighborhood) doesn't see direct daylight for almost two months (behind a mountain).
  14. macmaster05
    4,050
    730
    How come each diode seems to be grouped in 3s?
  15. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The LEDs are grouped in threes. There is a place you can cut in-between each set to shorten if needed. The space is not nearly as noticeable when looking at them.
  16. bagwell
    592
    49
    the woodlands, tx
    looks damn good....but I'm holding off for much brighter....like these
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Those look good too but I was wanting something more subtle. Plus it will be hard to find a place for those large LEDs on the Prius. The lower grill is about it and that I think is too low.
  18. bagwell
    592
    49
    the woodlands, tx
    that's true.
    anyway, thanks for the write-up and pics!
    was there still a slight gap between the headlight and bumper after the install or is it pretty tight now ?
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ the gap is gone now... very snug fit.
  20. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    It looks very good, today I visited local shop and I saw some similar LED strips. Unfortunately EU DRL have to have a certification to be allowed for the mod.
