Cannot start 2010 Prius after 3 weeks vacation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Xoka, Jan 11, 2011.
  1. Xoka
    Xoka New Member
    SF Bay Area
    I came back from 3 weeks vacation and cannot start my 1 year old 2010 Prius. No lightes on nothing working... Fob is with me and I cannot open rear door. Car was not locked in the garage during 3 weeks. I have no idea if it's a 12v battery or my remote battery...
    I even do not know how to jump-up my Prius if battery low...
    I try as usually to press the pedal and to press the button... nothing happens...
    Surprise...
    Do you have any suggestions?
  2. jim256
    jim256 Member
    317
    69
    Eastern NC
    I'd start at p 530 in the manual, it has a step by step. It could be the 12v, or one of the conditions in the manual.
  3. duffasaurus
    duffasaurus Senior Member
    177
    Charlotte, NC
    See if your headlights turn-on! This is a quick check on your 12v battery. Also, if you have a DC volt meter, lift the hood and place the meter on the 12v battery test point(+ has a red cap over it) and ground.
  4. Mendel Leisk
    41,901
    Regarding what you should see with a volt meter hooked up:
    About 2/3 down the page here:
    The 12volt Side of Life (Part 1)
    Is a table of voltage readings, and how that corresponds to battery's state of health. Temperature will affect readings, but with resonable ambient temps, not by much. Also, if you've just attempted charging the voltage will show abnormally high.
    A full charged battery should read 12.6 volt, or higher. If you're down around 12.0 you likely have a problem.
    You can look into chargers, to try to bring it back. I'd suggest a relatively low amp charger left on overnight, for one~two nights. I have a 6 amp traditional auto-charger, but recently have been relying on a CTEK Multi US 3300:
    Battery Chargers | CTEK Battery Chargers
  5. sdetweil
    sdetweil New Member
    84
    texas
    same problem with my 5 month old 2010.. sat for a week, totally dead. nothing..
    jumped from my dually to get the back hatch open to trickle charge..
    dealer says to start it once a week.. as if!..
    when I travel for over a week, it better start when I get home at 2am.
    their answer was to have it towed without charging it the next time.
    what BS.
    Sam
  6. bisco
    52,390
    might need fresh batteries. '10's seem to be having a lot of battery issues.
  7. RufusNapkin
    RufusNapkin New Member
    36
    What would be a good/best battery replacement choice?
  8. Xoka
    Xoka New Member
    SF Bay Area
    That not funny... I posted this question over one year ago and after that I was charging 2 times my patterry when I did not use it for 2 weeks and it worked... Not I left it on the street for 2 weeks with closed door and cannot even open the door... I have no traditional key and have no idea what to do, ... Should I call AAA to open my door at this case? My 2 remote controls do not open the door. Just see red light on the remotes.
    Any idea?
  9. mpb
    mpb ção
    Bellevue, WA
    Don't you have the mechanical key on the key fob?
  10. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
  11. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    As mpb stated you most likely have two manual keys as part of your two fobs, push the "push" button on the side of the fob and pull on the ring to release.
  12. hlunde
    hlunde Member
    419
    75
    A lead-acid battery should only lose about 4% of its capacity a week if there is no load. So there is some Prius-specific issue here. As owners, we have only a couple of options. You can keep your vehicle attached to a quality battery maintainer when it's idle for a couple of weeks, or keep a jump-start pack in your vehicle. If you choose a jump-start pack, get a fairly large one since these are designed to provide high "cold cranking amps" but have only modest "reserve capacity". The latter is what you need to charge (re-charge) your Prius battery.
    Of course, keeping your vehicle's battery fresh (replacing it) and/or upgrading to a higher performance battery (Optima) will help.
  13. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Yes you do have a normal key. Its part of your smartkey fob.
    Use it to open your drivers side door. From there you can open the hood.
    Apparently, you never bothered to read the owners manual. Owning and/or operating an automobile brings the responsibility of becoming familiar with it.
    JeanDavid8 likes this.
  14. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    A jump start pack is exactly that, it is not suitable for charging a flat battery. To bring a Prius back to life the smallest of starter packs will be more than sufficient then leave the car in ready to charge the 12v.
    The Optima is a very good battery, but even the best will not start the car if it is left to long.
    The Optima will recover better from a deep discharge, but again the Optima will get into that condition quicker than the OEM battery as the Optima has I believe 35 amp/hr capacity while the OEM has 45 amp/hr capacity.
    I use a 55 amp/hr battery in my Prius and that gives me a good safety margin but it is still not immune to the problem.
    In simple terms if when turned off your car uses 1amp/day = 41.5ma/hr, not the actual figure I know.
    Assuming all batteries are fully charged.
    In 35 days the Optima will be dead.
    In 45 days the OEM will be dead.
    In 55 days the battery I am using will be dead.
    Now the Optima and the battery I am using are both deep cycle batteries, but remember even though it has reached it,s design maximum discharge point at day 35 it still continues to discharge further, this shortens its life. The battery I am using will get to this point on day 55. Deep cycle batteries have a typical self discharge rate of about 3% a month I do not know the rate for the OEM.
    The OEM battery will get to that point on day 45, but will already have it's life reduced because it is not a deep cycle battery.
    The higher the amp/hr capacity of the battery the less it digs into it's life expectancy against a smaller amp/hr battery.
    The only way round this problem is to disconnect the battery if the car is not in use for a long period and put up with resetting everything when you reconnect, or to keep the car on a suitable float charger.
  15. krazypriuslady
    232
    metro Wash DC
    Does someone have a link to the jumper pack and battery minder?
  16. hlunde
    hlunde Member
    419
    75
    I use a Schumacher 1562A, which I bought at PepBoys. See this site:
    SEM-1562A:
    This charger is rather compact. You may find larger and less expensive chargers, but these may not have the built-in "intelligence" to adjust the charging rate to the battery state. So you really want to get a "maintainer".
    re: jump-pack Sears, Walmart, Autozone. Advance Auto, Pepboys
  17. er86
    er86 Junior Member
    42
    Austin, TX USA
    Silly question, but should we use a solar panel in the window for extended absences? WAY back in college a friend used a solar charger because he did not drive his car for extended periods and with the electronics, alarm, etc.
  18. ataylorracing
    ataylorracing ataylorracing
    171
    29
    Fishers, IN
    I called the dealership with a question not related to starting. I told them I had just come back from vacation and they asked if the Prius would start. IT was not a problem since I was only gone for 5 days, but they told me this is a common problem and if I were gone for a couple of weeks I should put a small trickle charger on it.
  19. KK6PD
    4,003
    946
    118
  20. KK6PD
    4,003
    946
    118
    The size and wattage rating would depend on how much power the car sucks on the battery in Amperage while parked. If you can equal, or better, exceed that demand, it would work fine. If you can't meet the required current draw, it would be a waste of time and money!
