Engine Running Light
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Metalman, Jan 11, 2011.
  1. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    I am a new Prius III owner and am interested in knowing exactly when the engine is running. While the vehicle is moving it is very difficult to tell. I understand that there is a graphic screen that shows red arrows moving out of the engine, but when using other screens I can't tell if the engine is running. Has anyone wired an LED indicator light that shows when the engine is running? And if so, where what power supplied for the light?
  2. Savantster
    Savantster Junior Member
    40
    Colorado Springs, CO
    Closest thing I've read on here so far is that many people use a Scan Gauge II and hook it up to the computer. From there, you can watch engine RPM to know if it is running or not. ... other than that, I've not seen anything that tells you if the ICE is running (red lines don't always show since the engine can idle without providing power to the wheels or chargers).
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    A cheaper route (than an SGII) I suppose could be to install a tachometer. Most I have seen these days are LED.
  4. Mendel Leisk
    42,209
    What about if the gas consumption gauge shows infinite mpg or zero liter/100km? Isn't this a positive indicator of no consumption? I believe at a stop and idling it will still show no gas consumption, but it's pretty easy to tell by sound/vibration in that case.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ in your case yes, but the US model is not that accurate. The engine can get 100+ mpg and by the meter it appears "off".
  6. seal2cc
    seal2cc New Member
    52
    Virginia
    Some sort of tach might be good but with the cost of a SG II at $145, and the fact that it offers dozens of other readouts/data points and can be used to disable annoying beeps, seems like that might be a better cost/benefit ratio..? Love mine and it IS fun to see '0 RPM' and like 1300 mpg etc ;)
  7. Metalman
    Metalman Member
    107
    17
    I have read about the SG II and someday we might put one in the Prius. I figured that by connecting an LED and resistor to a circuit that is energized only when the engine is running would be a simple and cheap way to to know what's going on under the hood.
  8. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    The fuel pump would do it, since sometimes the engine runs, at 900rpm or so, but injects no fuel.
  9. Mendel Leisk
    42,209
    I think Harold was asking, either here or at CleanMPG, if he could get his (Canadian) second generation Prius to display mpg. I believe even when he switched to mph display it was showing liters/100km.
    The same thing happened with ours, I think, when I tried switching to mph: still showing liters/100km. Seems like that is in some firmware, can't be switched.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Sorry, my statement probably wasn't clear. The MPG is inaccurate as the engine can be consuming at a rate > 100 mpg (engine not off) but the meter would be pegged at 100 mpg. Therefore it would not be a good indicator that the engine was running or not. Does that make sense?
  11. Mendel Leisk
    42,209
    No, I understood. Just rambling: as to why Canadians can't switch to mpg ;)
  12. Flaninacupboard
    1,297
    213
    Midlands - UK
    I think the actual display board is different in l/100k and mpg vehicles.
  13. Metalman
    Metalman Member
    107
    17
    I would rather know exactly when the engine stops or starts. I certainly don't understand how the engine can run without fuel. I wonder if there is a detailed explanation of how the battery, regenerative systems, engine, etc. work under various circumstances. I would like to understand more about the inner workings of the vehicle.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ lots of good information out there like this site. Or this is cool too.
