Warranty expired at 18 months/36K: here's failure list
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2010 prius in PA, Jan 14, 2011.
  1. 2010 prius in PA
    2010 prius in PA Junior Member
    22
    pennsylvania
    Summary of problems experienced before our 2010 Prius (trim level 2) warranty expired after 36,000 miles and 18 months. Mileage mostly a mix of highway and suburban roads.
    Safety related:
    1. Brakes intermittently cut out on rough road surface: addressed by recall to reprogram (~shudder~) brakes.
    2. One episode of sudden hard acceleration while foot was off gas, and which cut out as soon as I stomped the brake. Never explained despite Toyota holding the car most of a week. Best guess is an unnoticed bump of my leg on cruise stalk which could have triggered cruise Resume function.
    Other: -- where fixed, were free under warranty
    1. 3 episodes of loud (sounds like ball bearings in cylinders) rough cold start, lasts under a minute. Reported to dealer but not readily reproduced, not solved. Dealer did say "oh yeah, when it's cold, right? Bring it back if it happens more often". I logged our episodes in Bob Wilson's survey thread on this topic.
    2. 12V battery failure. Car wouldn't start, dealer paid to tow, diagnose and replace battery. About 16 months.
    3. Driver seat lowering mechanism making loud grinding noise – dealer replaced mechanism at 27K
    4. One headlight bulb failed at 32K, other at 35K – replaced under warranty.
    5. Hatch won't fully lift when cold unless you push it up 34K, dealer replaced lifter pistons
    6. Arm rest tray insert had piece break off, no longer sits in place – replaced by dealer.
    For comparison, here is my list of problems during warranty with other new Japanese cars:
    1984 Tercel 36 months/ 36K miles – zip. Lifetime (til sold) safety issues 140K: zip.
    1987 Civic 36 months/ 36K miles – zip. Lifetime (til sold) safety issues 110K: zip.
    2002 Civic 36 months/ 36K miles – zip. Lifetime safety issues 110K and counting: zip
    Since we drive a lot of miles thought folks might like to see what may lie ahead for them...
    Would be interested if site had a way to chart the frequency distribution by mileage at which folks encounter failure or wearout in various subsystems.
  2. fuzzy1
    10,603
    How did you get a 36/36k warranty on this? The late-'80s Hondas in my household had only 12/12k warranties.
    And how did you miss the front seat belt buckle recall that hit both of ours? The websites I checked show this and two other recalls for the '87 Civic. And the '02 Civic? Too many to count.
    Every car in this household in the past three decades, five of them Japanese-branded, has had safety recalls. While we loved our Hondas -- spouse still does -- and they set a very high standard that this Prius won't be able to challenge for many more years, they were not as perfect as portrayed above.
  3. viclavigne
    viclavigne New Member
    76
    Georgia
    Here's my short list from recent cars:
    2009 Honda Accord - owned 2 years and 32k miles. Rear brake pads completely worn at 20k mile mark. Factory defect, replaced with newly designed OEM pads. New brakes squealing after 4k more miles.
    2009 Honda Civic - owned 2 years and 17k miles. Front end noise when shifting from P to D on occasion, never fixed. Drivers side power window defective auto up control at about 15k miles.
    I've had other cars with more or less problems. No brand is perfect.
    Vic
  4. bisco
    52,396
    :eek:trade it in on a gen II. 04 and 08, 85000 and 20000 miles, nothing but oil changes and tire rotations. not one rattle, nothing.:rockon:
    PriusCamper and Silver bullit like this.
  5. 2010 prius in PA
    22
    pennsylvania
    I was only noting safety failures I actually experienced. Agreed that there were proactive safety recalls on Civic that addressed modes that did not actually fail on my car. The Prius brake s/w recall for me was reactive - I had the failure before the recall.
    Don't have paperwork on the civic warranty mileage limit, but I did reference my records on what failed by 36K (zip), and back then was driving < 12K / year.
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    You claimed for a failed bulb under warranty AND class this as a failure? lol
    You're kidding right? :eek:
  7. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I had the same issue with my 07 Civic Hybrid. The Auto-Up would get 3/4 of the way up, and go back down. It would go all the way up if you didn't use Auto-Up but you could see it shift a little. Mine was replaced with about 5k miles on it. Also had a transmission go bad around a year after I had it, under 10k miles. Talk about an experience, sometimes it would run right and sometimes it wouldn't.
    I had a 95 Mazda Protege, that had been recalled for a faulty light/turn signal switch. IF the headlights were on, and you flipped the stalk for the signal, the headlights would go out. Sadly, this was bought used from a Honda/Mazda dealer and they didn't fix it ahead of time. I found out by researching that it was a recall and took it in to have it fixed. Needless to say, lots of driving at night was done without signaling.
  8. Mr.Vanvandenburg
    1,358
    591
    2020 Prius Prime
    I had 3 Hondas, and 3 Toyotas. I will stick with Toyota.
  9. Flying White Dutchman
    4,376
    313
    if a armrest piece brakes off maybe you where to hard on it?
    bullying is not good you know ;-0
  10. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    So far at 13,500 miles I got the software fix for the brakes and had a loose plug to a window switch in the drivers side window panel.
    Gee if that is all I have deal with in the first 17 months and 13,500 miles I'm sure not going to complain.
  11. nooaah
    nooaah New Member
    380
    Philadelphia
    1. Hatch won't fully lift when cold unless you push it up 34K, dealer replaced lifter pistons
    Whoah, wait. I thought this was just an issue with the Prius in cold weather. This is fixable? You have no idea how many times I've thoughtlessly banged my head on the hatch in the morning over the past two years lol.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    In another thread discussing the pros and cons of buying an extended warranty, I mentioned that the issuer has to pass on the costs of warranty abuse. it is this sort of thing that I mean.
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    '04 Prius, about 125k miles.
    2 silly recalls ignored (mats and brake pedal shave)
    recall on steering column performed
    repairs: 0
    dealer maintenance: 0
    diy maintenance: maybe $400 total.
    It might be around in 40 years as part of my estate.
  14. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    2010 Prius, 26K miles.
    1 recall (brake thing)
    Repairs:0
    Dealer Maintenance: 2 oil changes
    DIY maint: 0
    Complaint: only getting 55.6 MPG average lifetime.
  15. SageBrush
    11,627
    2,533
    Southwest Colorado
    There is a recall for that :D
    Just a quick reprogramming.
  16. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    I think your list of issues is incredibly minor. You had a dead battery...that happens. Something got stuck in the seat height adjustment mechanism...that happens...
    The "brake issue" isn't really an issue, its a feedback adjustment. As for the clunking start...a fluke starting concern that is a lot more common on a lot of cars than you think.
    Headlight bulbs? A wear item that would have cost you $35 at PepBoys to put right...no HIDs.
    Gas pistons on the hatch...I have never had a hatch with gas pistons not start having problems raising in cold weather after a couple years...on any car. Again...very minor issue.
    Big success IMHO.
    Your 80's Civic and Tercel didn't have any issues because they didn't have any features. You're telling me they went to 150k miles on the original battery? I don't buy it.
    PriusCamper likes this.
  17. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    It's true that cars have gotten more complicated, and have more stuff to fail, but some of these issues are valid criticisms.
    Short-run-cold-start noise. There is a design flaw in there somewhere. They should find it and fix it. I don't care if other cars do it too.
    Short 12V battery life. C'mon. We've only been making lead acid batteries for 100 years. Discharge from being small is one thing, but failure (needing replacement) is another. Probably outsourcing to China, without adequate quality control.
    Short headlight bulb life. Can happen to anyone, but 30-40k is very short. Probably more outsourcing to China.
    Hatch struts only last 2 or 3 years, no matter the brand. However, if you really do prioritize reliability, you use springs.
  18. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    My oil filter wore out at 5,000 miles and needed to be completely replaced.
  19. SW03ES
    2,480
    176
    Gaithersburg, MD
    Come back to me when we see an engine failure. The thing makes a clunking noise under a very rare set of conditions. Its a "characteristic", not an issue.
    Toyota doesn't make batteries. The 12V battery is made by a little company you might have heard of...Panasonic. Discharged batteries are VERY common on new cars as they sit on lots and get started a lot without having adequate time to charge. This again is something outside of the manufacturer's control.
    Toyota doesn't make lightbulbs either. Little company you might have heard of...Philips. Do you turn them on a lot during the day? 35k miles isn't terrible life for a halogen bulb...and anyways this is a wear item...
    Nobody in the industry uses springs in hood or hatch applications. Also dangerous...
    Again...if you think these are troublesome issues...you are incapable of being satisfied with any modern car made by any manufacturer.
  20. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Prius:
    28k and nothing.
    Vectra: (upmarket malibu)
    0.1k windscreen cracked
    0.2k windscreen wiper motor failed
    0.5k heated mirror failed
    10k fuel pump failed
    15k satnav headunit failed
    18k heated mirror failed
    20k fuel pump failed
    25k door control module (windows, locks, mirror) failed
    30k fuel pump failed
    35k dumped it's nice person for a prius.
