2005 Prius with Very Poor MPG
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jdogg22, Jan 19, 2011.
  1. jdogg22
    jdogg22 New Member
    Tomah, WI
    Hey all. I'm new here because I cannot find an answer to my current problem.
    In October 2010 I bought a new set of Goodyear Fuel max tires as the tires (which came with the car i bought only in April from the dealership) were bad. At the time, my Prius was getting 52-54 MPG per tank. I had gotten everything i was hoping for. I loooooved my Prius. Immediately after having the tires changed, my mpg went down to around 46 mpg. At this time we were having an Indian summer here in Wisconsin and temps were 65-72 degrees.
    Since this time, my mpg has gotten worse. When the cold weather started to hit (very cold in Wisconsin!), my mpg topped out at 42. Now, the display in my car says 32.1 mpg. I had all the proper components done during the tire change (balance, alignment, and yes the tires are all the right size). I've also had the 12 v battery replaced within the past 3 months.
    I have had a few Toyota dealerships do diagnostics on my car (NOT CHEAP) and there is "nothing wrong" with my prius. I realize it is cold and I can undersand losing some mpg but 20 MPG? Car has 31,000 miles on it.
    I am starting to hate this vehicle. I will do just about anything to get rid of it. I could have spent THOUSANDS less on a different car with similar mpg.
    PLEASE HELP! I don't know what else to do.
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    Any other vehicle on the market could have developed a problem even worse than reduced gas mileage. You're lucky you didn't get one of those because then you would be at 20mpg! :eek:
    Seriously. Stop hating and get the car fixed. It is obviously not working within spec.
  3. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    All vehicles suffer in the winter. Seasonal efficiency drops often go unnoticed. Having a screen available raises awareness profoundly.
    Do you ever warm-up prior to driving away? (that's extremely wasteful) Have you checked your tire pressure? (that naturally drops, cold temps make it worse) Do you drive nothing but short trips? (the penalty is obvious on the consumption screen) Would you be willing to take 20 minutes and spend $2 to block your grille? (that works great for heat retention) Is this temporary MPG drop really that bad? (much higher will return in a few months)
    Just go for a long drive. The first 10 minutes are always painful in comparison to what follows. MPG goes way up once the engine and emissions-system is warm. Nothing is wrong if you see numbers above 40 at a steady cruise then.
  4. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi jdog...,
    Do not worry, come late spring you will be gettin 50+ mpg again. Yea, you probably wasted your money on the diagnosis.
    Look around on the website for the sticky regarding poor mileage, and fill out the questionaire, and post it back on here.
    Check your tires, and run them at 42/40 psi. These need to be set first thing, before any driving, in the morning, on a cold day.
    You are going to need to grill block. You can start in the weather we are having now by blocking the top grill slots right away. Do NOT use styrofoam. Do a search on Grill Blocking on here and you will find lots and lots and lots of information.
    In 5 degree weather, getting much better than 45 mpg is almost impossible on secondary road travel. On the highway, it depends on how sunny things are (to keep the tires warm).
    F8L is wrong. It could very well be just fine. If your doing short trips. Or if the temps are below 10 F where you are, then, yea low 40s is typical. And this is from somebody who has done 70 mpg tanks in 80 F weather in Chicagoland suburban traffic.
    You are falling into the same apples compared to oranges comparison many people do. 30 mpg is what you getting in 5 degree F , for short trips. You can tell that because your Prius has a mileage gauge. You really do not know that these other cars are not getting 15 mpg in similar conditions. My 2000 SL2 got 28 mpg in the summer, but 20 mpg on a tank average basis in the 5 F weather. If I drover the SL2 for 10 minutes at a time, then parked it and let it cool, well it would be getting allot worse. I do not know how much worse, because the SL2 does not have a gauge. I have to wait till I gassed it up to find out, but by then, I would have had long trips during the same tank, and the mileage is up to 20 , in 5 F weather.
  5. ursle
    ursle Gas miser
    1,049
    192
    NH
    I have an 06' and drop to 47+ during the winter, I'm at 50.1 right now, something is fishy
    The usuals
    cycle the emergency brake on and off, cable might be sticky
    clean the cabin air filter
    Tires at 42-40
    Oil 2/3rd's up the dipstick
    Put in an optima yellow top battery with fit kit
    I suspect you have a spark plug mis-firing
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Please follow john1701a suggestions.
    There's a reason why I posted http://priuschat.com/forums/gen-ii-...-answer-these-questions-esp-if-youre-new.html. We know nothing about the OP's trip lengths or drives.
    If there were misfiring, it should trigger a check engine light/MIL.
  7. jdogg22
    jdogg22 New Member
    Tomah, WI
    42-40 front to back?
  8. rpeeples
    rpeeples Experienced Toyota Owner
    109
    America's own third-world country
    Just my opinion, but goodyear tires are junk. I used to buy nothing but them, but after the last set, I will never buy goodyear again. I would suspect the tires, IF that is the only change that has been made. I agree other factors need to be considered like some of the other comments have indicated. But I would point to the tires being the problem.
    I am not sure how you can confirm it other than possibly swapping the tires (correct size, rims and all) with another person just as a test. It would be a lot of trouble for sure, but it might be the cheapest way to tell instead of having the car diagnosed at the dealer. Just a thought...
  9. richard schumacher
    7,664
    1,046
    United States
    Yes.
    Tire pressures should be checked at least monthly. Always check tires "cold" (that is, when they have not been driven more than one mile in the previous hour). Checking them hot will give an inaccurate too-high reading.
  10. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    OP - I bought similar tires just before Thanksgiving - I bought the Viva Assurance Fuel Maxes which are the Walmart exclusives. I found that my mileage trended up a touch - I also found that they handle very well in rain and snow - so at least my experience with similar tires has been very positive.
    So - I'd just tell you not to worry too much - the cold will take a heck of a hit on mileage.
  11. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    1) What brand and model of the tire are you using now? Is it 185/65/15 in size?
    2) Check if your Coolant Heat System pump is working. It stores hot coolant in a vacuum bottle to release it during the cold startup. If it is not functioning, it will hurt your MPG especially during winter.
  12. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    We can only speculate until jdogg answers cwerdna's list of questions.
    Jdogg's experience is certainly possible for a properly running Prius. My summer mileage is in the 50's, now I'm struggling (as usual) to keep it above 40 mpg, and that's with grill blocking, an engine-block heater and using hypermiling techniques, including monitoring engine temperature with the ScanGauge and using the heater only enough to keep the windshield clear. Before I did all that I would also have tanks in the mid 30's mpg. I'm maybe 20 miles south of Wisconsin, so the weather is similar.
    In my experience, commute distance and air temperature make a much bigger difference than tire pressure (assuming you're not grossly under-inflated). Generally your commute is fixed, so to improve your mileage one easy step is raising the tire pressure, but we shouldn't get the impression that's the biggest factor. I have a commute of 3 miles, that's my killer, especially on days like today (-5'F this morning, or -20'C for our international friends) and I need to run the defroster to safely drive.
    I recently replaced my tires too, but haven't noticed any hit. I used the Michelin Energy Saver A/S. A bit expensive, but had good characteristics - quiet, LRR, better braking distance than the OEM tires. I've heard some tires take awhile to break in and provide better mileage.
