2011 Any Differences From 2010?
Discussion in 'Gen 3 Prius Main Forum' started by Vee, Jan 19, 2011.
  1. Vee
    Vee New Member
    Rochester, NY
    I just picked up my 2011 Three company car last week. There are no differences from the 2010's I have looked at and test drove. I am aware of the new Black / Bisque option.
    Has anyone else found any mechanical or cosmetic differences between the two?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    If there are relevant differences other than bisque/black combo, wouldn't you think they would have advertised them in order to drive sales?
  3. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Howdy Vee,
    Welcome and congradulaions for having a company cool enough to let you drive a Prius. I am a new MY 11 owner myself and looked at a MY 10 before the purchasing the 11. Was your car labeled as a III or Three on the sticker? I know of a few differences the later production 10's had a factory USB interface, it is stock on 11's. The 11's have two bottle holders in the front doors I do not believe the 10's did.
  4. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Interesting. Can you take a photo of it for us to see?
  5. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    You HAVE to push PARK first on the '11 before you turn off the POWER, or it will blow up.
    j/k :D
  6. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Here you go as requested.
    Driver, Passenger doors and USB/AUX interface.
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I have to check but I think my door pockets look like that... I honestly never use them so it is something I'd have to look at.
  8. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Looks like the same interior features of my 2010.
  9. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    Is the NAV (if you have it) any better? How about FM reception? Are the brakes still as bad (failing when going over bumps)?
    Thanks.
  10. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Thanks, but I thought you meant two cupholders in each door. The 2010 has those exact same cupholders so no difference in the 2011.
    Those are normal characteristics of the regenerative braking, not "bad" or "failing." The Gen II has the same regen to friction braking transition so no difference.
  11. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Okay cool my mistake I did not notice those on the MY 10 that I looked at and test drove. But I kinda flushed the MY 10 when they had a MY 11 in stock. I had also done an online vehicle comparison and it said MY 10 cup holders qty. 4 and then it said MY 11 cup holders qty. 6. I assumed thats what they were referring to, maybe I have secret cup holders. I will consult my owners manual.
    I am glad that I have been using the Park Button prior to pressing the Power Button, I would hate to have exploded......
  12. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I have no previous experience with the navigation system to determine if it is better or not. I did take my DVD out look at it and put it back I did not make a record of its version or date. So far so good though going from a car with nothing and not having a portable unit I am happy/mesmerized. I thought it would really suck over here in the Islands, but it seems to be accurate. It is funny to try and hear her (the nav. voice) pronounce the Hawaiian street and place names.
    FM reception is sub par, my last vehicle had the FM antenna in one of the rear windows. That was bad in certain locations and for certain stations, I thought the exterior mounted antenna would be better but it sucks. I don't know if it is the antennas fault though or the way the tuner in the receiver is programed. It will stop and lock on to a known station and there will be no audio. So it knows the signal is there but it does not play it.
  13. Thai
    Thai Prius Neophyte
    1,197
    89
    Well, it looks like MY11 and MY10 are pretty much the same except for color combo differences. Woohoo, my Prius is current at least for another year! :D
    BTW, ED, not sure if you know this, but your Prius Five has unique shock and springs...just wanting to spread that around because no one seems to realize that! :)
  14. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I hate to go searching for it but I read somewhere that the 11 have heated seats and lumbar support for cloth seats or is that for PHEVs?
  15. newtoprius2010
    newtoprius2010 New Member
    Northern California
    The nav system in Toyota and lexus (so not limited to Prius) will freeze up if co-passenger tries to input address while driving. This is a pretty big difference from the honda/acura and currently there is no way to override the toyota nav. It is like if they are trying to freeze that, there is a lot of things driver can do while driving to cause accidents. Other than that, I am fine with the toyota NAV as I like the bluetooth, back up camera and other features that came with it. Also I dont think we need to update it as much. My acura nav was never updated for 5 years and only recently I got that updated. I like the nav as I can't be bothered with hooking another portable GPS around all the time..
  16. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Does anyone look at the sticky threads at the top of the forum? There is a long thread about this starting with the Prius teams announcement about the 2011 model year.
  17. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    Search for a Prius Team post here on PC a couple of months ago in which they talked about the differences between '10 and '11. There were a few, as I recall.
  18. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    The only tangible change is the availability of bisque with the black color. The rest are just semantics (re-naming of IPA to APGS, Roman numerals to numbers spelled out). But I guess the OP is asking about hidden or unadvertised differences not included in the latest 2010 models and the TSBs thereof.
  19. darelldd
    6,059
    389
    Northern CA
    Heck, my 2006 has that. Of course I added them, but still!
    Prius seats
  20. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    I asked the Prius Team about it and they confirmed it was a typo.
