Newbie looking to get a used Prius
Discussion in 'Gen 2 Prius Main Forum' started by Evo8tohybrid, Jan 20, 2011.
  1. Evo8tohybrid
    Evo8tohybrid New Member
    Murrieta
    Hello everyone! I'm looking to get a used Prius as a daily/grocery getter so i could finally give my Evo some well deserved rest. I was wondering, is it worth it to get a used Prius with more than 100k miles?
    I was looking to get one in the next two weeks btw :)
    Any inputs is well appreciated.
    I'm pretty stocked about getting one so one day i really hope to become part of the Prius Hybrid family!
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    What's your budget? I'm not sure I'd go w/one over 100K miles as its HV battery warranty will be over (unless it'd been replaced under warranty or some other reason already). Provided your budget is high enough, I'd recommend getting a 2nd gen (04) or newer.
    These should help:
    http://priuschat.com/forums/gen-ii-...ed-prius-need-help-what-look.html#post1215778
    http://priuschat.com/forums/newbie-forum/88979-used-prius-buyer-best-model-year.html
    http://priuschat.com/forums/dealers-pricing/88518-18-000-please-help-me.html#post1241833
    https://priuschat.com/forums/knowle...andard-optional-equipment-some-countries.html
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    04 had the most issues. 05 was better. 06 and up are pretty solid. Pay close attention to option packages. Get one with SmartKey for sure!
    In CA, you have 10 year/150K mile HV battery warranty.
    100,000 miles is a good spot. Even for lack of some preventive maintenance, it is still possible to do a major service and have the expectation that the car will go for a long time. If you can, get one with service records. A private sale from an original owner is the best bang for the buck; certified pre-owned from a Toyota dealer is the most expensive. 100,000 mile service should include a complete drain/refill of both cooling systems, drain/refill of the transaxle, a new engine water pump (you can get up to 150K but then you have to pay for the cooling system service again), spark plugs, and PCV valve. That gets you potentially another 100K miles without doing anything more than changing the oil and filter regularly -- though a transaxle fluid change every 50-60K miles is strongly recommended.
  4. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Woah, didn't realize the OP is in California. Please confirm. Before looking it up, I figured the city was in GA. :confused:
    Yes, if the OP is in CA, to be on the safe side (to ensure the 10 year/150K mile HV battery warranty is valid), I'd stick w/Priuses that have been bought and only registered in CA.
    Non-CA and non-CARB state HV battery warranty is only 8 years/100K miles.
  5. Evo8tohybrid
    Murrieta
    Thank you so much for your inputs everyone. And yes i am in California. I saw a 2006 Toyota Prius for $10k but it has 103k miles on it from a local used car lot. What i was most concerned for was the battery. So even if i bought a used Prius from a non-Toyota dealer my battery would still be covered under the Manufacturer warranty am i correct?
  6. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Yes, it should be. Just make sure it doesn't have a salvage title and hasn't ever been declared a total loss (if it does, it will have virtually no warranty on anything). Also (to be on the safe side), see my earlier post about CA purchase and registration.
    You can see the terms of the warranties in the warranty booklet. Hopefully the seller has it or you can borrow one, to see for yourself.
  7. Evo8tohybrid
    Murrieta
    Cool thanks for the tips :rockon:
  8. seilerts
    3,326
    1,518
    Santa Fe, NM
    Carfax shows the registration history if I recall correctly, and the dealer ought to give it to you for free. Depending on the options (Smartkey, backup camera, HID headlights, etc.) $10K sounds pretty good.
  9. nfg2u
    nfg2u Junior Member
    South Florida
    My first post! :) Great info here..
    I just purchased a 2007 Base very clean, smart key, backup camera, leather and 60k miles with 40k warranty left from a Toyota dealer. Its clean and I took it on a road trip for 2000 miles right out of the lot. Keep your eyes and ears to the ground. I did a lot of eBay and Craigs list searching.
    Steve
  10. seilerts
    3,326
    1,518
    Santa Fe, NM
    Congratulations Steve! Given that you are in South FL, take some time to review threads on the 12V auxiliary battery testing and replacement. If what is in your car is the original, then it is nearing the end of its service life, and is not covered by warranty. Otherwise, you should have many years and miles of trouble-free operation ahead of you!
