A clean mass airflow sensor seems to help
Discussion in 'Gen 2 Prius Fuel Economy' started by mfa-prius, Jan 20, 2010.
  1. mfa-prius
    mfa-prius Old member
    299
    46
    Hansville, WA
    Mounted on the front of the throttle body, just below the air cleaner. If you take the air filter out, and look down the throttle body throat, you'll see the MAF sensor poking in from the front. It's held on by two screws, located in the perfect position to prohibit use of normal-sized screwdrivers for easy removal. Many others recommend just buying a spray can of MAF sensor cleaner and spraying it from the top, without removing it -- see jayman's post a few pages up.
  2. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Under the air filter.
  3. dcooke35
    dcooke35 Junior Member
    michigan
    Can you please tell me what exactly you are shooting with the spray, I have removed the air filter, and dont seem to see the MAFS.
  4. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    The air 'filter' part of the filter is on the left, the other half of the box is the air intake. Look down that hole with a flashlight and you'll see it. looks like a little glass bulb sticking out horizontally.
    - D
  5. Patrick Wong
    18,210
    6,513
    I would say that you need to remove the MAF sensor (by first unscrewing the two screws holding it in place) so that you can clean the two wires. If you can't see the wires, you at best will only be cleaning the air temp sensor which is the amber bulb.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
  7. mcsj
    mcsj Member
    125
    Earth
    So are you guys saying that dirt accumulates on the "clean/filtered" side of the air intake? If so, does that mean the air filter is not that good?
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    In the Atkinson engine, the intake valve stays open until the piston is about 1/3 of the way up the cylinder. This mean some gasoline vapor is pushed back into the intake tract. I think this is what can foul the MAF sensor, not intake air that is unfiltered, but engine air pumped back out into the intake.
    Hobbit has a diagram http://www.techno-fandom.org/~hobbit/cars/training/800/atkinson.gif
  9. Patrick Wong
    18,210
    6,513
    My 2004 has 115K miles. I recently removed the MAF sensor and cleaned it. However the amber bulb looked amber, not grey, so the sensor really didn't need cleaning.
    When I lived in southern CA I replaced the engine air filter at 15K mile intervals because the filter got pretty dirty that quickly. In southern AZ the air is generally cleaner and I am now observing 30K mile change intervals.
    It is possible that the engine's Atkinson cycle is helping to foul the MAF sensor but I personally have not noticed that. I am wondering if Prius that have a problem with their MAF sensor also have not had their engine air filters replaced at timely intervals.
  10. viclavigne
    viclavigne New Member
    76
    Georgia
    Dirty MAF sensors are not a problem just for the Prius or even Toyota engines in general. As a former Honda owner, I know that some of the Honda websites also talk about the benefits of regular MAF cleaning, and the problems that result from not cleaning them. Also, if you google "MAF cleaning benefits" you'll get hits on a lot of car makers, including VW, BMW, Audi, Ford, etc.
  11. richard schumacher
    7,666
    1,047
    United States
    Or had chronically overfilled oil.
    ydpplqbd likes this.
  12. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Is this still good advice to just squirt CRC MAF cleaner onto the MAF through the air filter?
    How would one know if it’s needed and could it hurt?
  13. ChapmanF
    18,537
    That would be pretty much car-maintenance theater.
    If you look closely at this photo of a MAF sensor, you can make out the two fine wires deep down its throat.
    You're not going to get any angle where your sprayed CRC cleaner reaches those wires, unless you take the sensor out of the duct.
    The good news is, that's very easy to do.
    Cleaning the sensor won't hurt anything (as long as proper MAF cleaner is used, and you don't touch the wires with anything but the sprayed cleaner). It also probably isn't badly needed, if the engine is running well, with no codes about the sensor or mixture, and reasonable fuel-trim numbers.
  14. Another
    1,819
    517
    Naples, Florida
    Thanks
    Have no issues, no codes, use good gasoline so I’ll just not fix the thing that isn’t broke.
