Nav System shows me in the Atlantic Ocean
Discussion in 'Gen 3 Prius Audio and Electronics' started by kuffs, Jan 29, 2011.
  1. kuffs
    kuffs Now 2 Prius Owner !
    Floriduh
    My Navigation System shows me about 20 miles out in the Atlantic Ocean.
    I live on the east coast of Florida and cannot get the Nav to work ? What did I do wrong or are the Satellites not working? Any help? [email protected]
    52,417
    mine shows me in the middle of the arctic:confused: oh wait, just looked out the window, i am!:D
  3. navy48
    navy48 LBII (Lil Blue II)
    56
    Indianapolis
    its all due to Global Warmng. the snow dumped on the east coast is melting at such an alarming rate its causing the Atlantic to expand. :eek:
    where as before you were located in what used to be Florida, you are now afloat. bummer for you but living in Indiana, we'll soon have BEACHFRONT PROPERTY! WOO HOO!!!! :D
  4. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    You need to row back to shore then you'll be fine!:p
    In all seriousness, there should be instructions in your manual about calibrating it? Or call your dealer for help.
  5. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    The GPS in my III will get confused from time to time and show me off the road into the woods or a lake, but I puts me back in the right place within at most 15 seconds.
    Yours keeps you in the Atlantic Ocean all the time? See the dealer. Your car will start to rust if you don't fix the problem.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Well if you never post again, just another mysterious Devils Triangle Disappearance.
  7. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    The DOD has actually been updating the control system and there have been reported issues, especially in the southern united states. They started on the 11th, but apparently are still having problems. This could be the issue.
    Here's an article on it.
  8. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    GPS Testing Brunswick, GA.
    Notice Number: NOTC2777
    The Department of Defense will conduct GPS tests on January 20th through February 22nd, 2011. During testing, GPS will be unreliable and may be unavailable with in a radius of 370NM centered at 304906N/0802811W or the location known as 105.25 degrees and 52.1 NM from the SSI VOR
    See post #1 here:
    SE US GPS Outage - Pilots of America Message Board
  9. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Yep, I posted about this at http://priuschat.com/forums/freds-h...heastern-us-due-defense-department-tests.html.
  10. fuzzy1
    10,603
  11. direstraits71
    367
    65
