Anyone... Paint Mud Flaps / Guards?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by peterjmc, Jan 31, 2011.
  1. peterjmc
    917
    189
    Clarksburg, MD
    Has anyone purchased the Gen 3 Mud flaps / guards and had them painted? I was thinking about getting it painted to match before I install them. I would be getting them painted for the side that faces away from the wheel.
  2. andino
    andino Senior Member
    746
    551
    San Jose, CA
    Re: Anyone... Paint Mud Flaps / Gaurds?
    You could just use rattle can paint if you want. The problem with painting the flaps is that they will eventually get rock chips. Even the face away from the tires.
  3. strieby
    strieby Priusman
    76
    Bakersfield, Ca
    I had my 2008 & 2010 models painted. I had a good paint shop do it. If you don't the paint will start peeling off in about a year. It cost me $60 for each car.
  4. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    DIY may be worth a try... easy to paint before installation. :rockon:
    Can't see where perfectly exact color match is meaningful.
    The mud guards/flaps are in a wholly different orientation
    than the surrounding bodywork, and reflected light from the
    nearby road surface. You'd have to get down on your hands
    and knees to even try to get a good look-see on matching.
    It's a car, not a concert piano. :rolleyes:
    Two 'Net sources for Toyota shake cans:
    Dr. ColorChip: Automotive Paint Chip Repair Systems
    PaintScratch Touch Up Paint, Spray Cans
    IIRC, the "system" requires a special flex-undercoat for plastic,
    color coat, and maybe a clear top coat.
    Good luck.
  5. darelldd
    6,059
    389
    Northern CA
    Heck no! My wife uses them as curb-feelers!
  6. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    I painted mine with dark blue Krylon Fusion spray paint. The lid looked like a close match to my body color, but it turned out lighter on the mud flaps. They looked goofy on the car, so I've stripped them back to black.
  7. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    i tried it with all the right products
    it didn't work
    don't waste your time.
    RB
  8. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I'm going to paint mine using all the correct stuff* and I'll post a step by step here and we'll see how they hold up. They are definitely a light duty item - not for the mud and snow folks. I live in a city with paved roads - the only hazards are running over an occasional wino now and then...
    *scuff them up
    *adhesion primer
    *base coat
    *matching paint
    *clear coat
    And were I live we don't have curbs... :)
    I am and optimist... :rolleyes:
  9. peterjmc
    917
    189
    Clarksburg, MD
    Cool! When do you plan on finishing it by? I'd like to see pics.
  10. peterjmc
    917
    189
    Clarksburg, MD
