Air Filter Under Passenger Side Windshield
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chiguy, Feb 1, 2011.
  1. chiguy
    chiguy New Member
    25
    Champaign/Urbana
    I managed to puncture the plastic grill and filter that is under the windshield and wipers on the passenger side (2010 Prius). I've been looking for a replacement but I have no idea what it's called. I found this thread which seems to describe what it is in the 2nd post: http://priuschat.com/forums/gen-ii-prius-main-forum/83822-where-exactly-air-intake-cabin.html Do you guys know what this part is or have a part #?
    Thanks!
    Edit: found a pic from a Gen II
      File size:
      375.4 KB
      706
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Puncture? It is just a fairing to keep leaves and junk out of the gutter. I can't imagine the damage being that bad.
  3. chiguy
    chiguy New Member
    25
    Champaign/Urbana
    The hole is about the size of a US quarter. I ran my ice scraper into it this morning cleaning the ice off the windshield. :rolleyes:
  4. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    try looking around at parts.com??
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I wouldn't worry about it. Perhaps cover the hole up with some ducktape. :)
    Is the hole in the picture?
  6. chiguy
    chiguy New Member
    25
    Champaign/Urbana
    The picture above is just something I found online. I'll post a picture of my actual car sometime later today.
  7. chiguy
    chiguy New Member
    25
    Champaign/Urbana
    I'm not too sure what the part is so I'm not sure what to look for. :p
  8. ksstathead
    1,244
    245
    Kansas
    Or smooth it out and put a wire screen over it...
  9. ksstathead
    1,244
    245
    Kansas
  10. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Given all the venting on that piece, I wouldn't worry about. Or you could cover it with a piece of black electrical tape.
  11. ksstathead
    1,244
    245
    Kansas
    wiper cowl grille seems to be the part description. Not sure of part #, but I would sure try to fasten a cover over it and live with it if not too ugly. It needs to be screened to keep rodents and leaves etc out.
  12. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    You might be able to find a snap in plastic plug cover at Home Depot or Lowes. Just trim or drill the hole to the same size.
