Gaining access to HV battery area
Discussion in 'Gen 2 Prius Accessories & Modifications' started by brewer, Nov 1, 2005.
  1. brewer
    brewer New Member
    I have a DC clamp meter that I want to measure the battery current while in stealth mode and regen braking mode
    by clamping over the main battery cable
    I was told by the local dealer (Sydney, Australia) that opening the battery compartment would trip some hidden microswitch and shutdown the computer
    Not sure if its true or just intimidation by Toyota
    The battery seems well secured & removing some of the access bolts didnt get me anywhere
    Anyone have a method I can use to get access to the cable ?
    thanks
    M
  2. Lather
    Lather New Member
    27
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I don't have/can't give you exact details, but see the link below (scroll down a bit from the picture that opens up) and see if that doesn't give you some clues.
    PLEASE be very careful. You can trip some kind of breaker in there, IIRC, but you should be able to reset it.
    http://privatenrg.com/#2004Ah%20work
  4. Lather
    Lather New Member
    27
    Nice site, thanks. I got some reading to do.
    So that's where the current sensor is. I've already got the back stripped down and the battery box exposed (I threw a few pieces of dynamat on it so I wouldn't have to hear the clicking).
    So, if I had the 12V system disconnected anyway (amp install) and I opened it up, do you think it run afterwards w/o problems.?
  5. efusco
    19,891
    1,196
    Nixa, MO
    Sorry, I'm not sure what you're asking. Are you asking if you open the HV battery case would it run afterward OK? I think so. Again, I think there is some fuse or breaker in there that can trip if you touch the wrong thing. And you might generate a MIL code and have some lights on the dash for a few starts, but unless you do something really dumb I doubt you'd have any serious problems.
    Disclaimer: The link above is NOT my site. I've never opened the HV battery case and probably never will by myself. The stuff I'm telling you is what I remember hearing from others who have and don't vouch for the accuracy one little bit. The HV battery CAN KILL YOU so please don't screw with it unless you're sure you know what you're doing, have reviewed the wiring diagrams (and know how to interpret them) and the appropriate sections in the repair manual. This is serious business.
  6. Frank Hudon
    Frank Hudon Senior Member
    4,147
    probably the best way, as I assume you want to watch the clamp-on while some one drives the car, is to remove the back seats top and bottom and where the 2 cables exit the car just in front of the shock tower, put your clamp-on on the wire there. Positive or negative who cares if you clamp-on reads +-DC as when you start off it'll give negative readings anyhow so if positive readings occure your going to have to clamp the other wire. If your clamp-on is A/C only your out of luck as the feed to and from the battery is DC, it's converted at the inverter end and not the battery end of the system.
  7. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Evan,
    Nice pictures on that web site! And hope you noticed one engine shot shows the block heater hole we can't see and everyone has trouble finding!
  8. Lather
    Lather New Member
    27
    If it triggers a sensor meant for the computer, hopefully I'm okay since the battery would already be disconnected. If it does something to the 200V side, I'm probably screwed.
    But that other site looked interesting. I've been interested in measuring current on both the 12V and 200V side as well a a tachometer. If there's a better way, I'd go for it.
  9. Frank Hudon
    4,147
    is there a better way? yes there is it's called the CAN-VIEW monitor and here's the link
    http://www.hybridinterfaces.ca/
    all the info your looking for and more.
  10. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Oooh I have one of those I never thought about using it! I think my seats are about to come up! One more data point. Some one needs to get a Minni Scanner to me or I will have 25 or 30 meters in the car and the weight of all that instrumentation will kill my milage. Do you suppose there is a 12 step program?
  11. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    F'krissake. Go whack that dealer upside the head, he's LYING
    through his teeth. There is no such "microswitch".
    See http://techno-fandom.org/~hobbit/cars/imeter/ for much poop
    about the battery box and reading the current sensor and why working
    around the battery is really not much different from working on
    household electrical stuff -- except that DC tends to burn rather
    than tingle.
    _H*
