Removing the LED Shift Lever Light
Discussion in 'Gen 3 Prius Main Forum' started by Fizzer, Feb 2, 2011.
  1. Fizzer
    Fizzer New Member
    Hi all,
    I have recently purchased a 2010 Prius III. So far, I'm in love with most of the features and design of the vehicle. But one of the things I find bothersome is the constantly-on Shift Lever Light that shines down in the middle of the car.
    Does anyone have a simple, step-by-step guide for removing and/or disabling this light? It would be much appreciated.
    Thanks!
  2. BrettS
    BrettS Active Member
    290
    137
    Orlando
    Honestly, since it's so small and recessed in it's little hole I think your best bet might just be to get something opaque and stick it up in the hole... probably a lot quicker and easier than disassembling anything.
  3. FEINT
    FEINT New Member
    22
    Japan
    I wouldn't mind changing mine to something a little brighter.
  4. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    I'm not crazy about it myself!!
    At night I like it dark when I drive ,I turn everything down!
    What I have done is take a foam rubber ear plug and stuff the hole with it works great!!or a black M Marker will tone it down!
  5. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    At night, I just wear a blindfold so the light doesn't distract me.
    Maybe this thread is just an early April Fool's joke!
  6. Joe C
    Joe C Junior Member
    Chewing gum works well.
  7. ETC(SS)
    7,180
    +1 on plugging the hole, or putting a dab of fingernail polish (or sharpie ink) to tone it down, or block the light. You can always remove a cap, dab of paint, ear wax, or whatever you stop the light with later.
    If you're reeeeeeeeally hard-over on killing the light all the way dead, and you go through the trouble if disassembling the roof panel to get to the offending LED, you can always cut and cap the power lead to the LED. This might be preferable to removing the LED itself.
    Prius drivers are a persnickety, tech crazy bunch, and if you go to sell your vehicle then this non-optional 'option' may be one that your perspective buyer knows about and cannot live without.
    Oh yes...and :welcome: to Priusdom!!!
    Good Luck!
    Let us know how it works out!
    Geo Dude likes this.
  8. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    That light is great. Why remove one of the best things about this car? It works, and it is not too bright.
  9. chado1000
    chado1000 New Member
    I like having that light there. Its just enough to see everything without distracting your eyes.
  10. E Street Shuffle
    E Street Shuffle Pa-Pa-Pa-Prius
    Decatur, GA
    Until summer when the temp in the car gets up to 100+ ... :D
  11. JJB
    JJB New Member
    39
    Alpharetta, GA
    Right! I bought my prius for that light. Afterwards I found out that it gets pretty good mileage. Bonus!
  12. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    That's funny as a lot of people are unaware of this light until it's pointed out to them.
  13. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    The first time I backed the Prius out of the dark garage I didn't turn on the headlights and wondered why I couldn't see the gearshift lever. Once I turned on the lights the gear shift appeared. I like the LED light.
  14. fuzzy1
    10,481
    I wonder if there is any correlation between 'Prius drivers who came from a stick shift' and 'Prius drivers who don't see any point in having this light'.
  15. dick_larimore
    162
    70
    Central Indiana
    I have owned and driven both manual and automatic transmission vehicles. Yes, when you drive manuals, you just know where the shifter is - day or night. However, the Prius shift "knob" is something a little different. When you put a joystick on the middle dash next to the HVAC controls and a cup holder, I think it is good to remind the front seat passengers where it is. From time to time, people unfamiliar with the car will drive it. The night light could be of assistance.
  16. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    Another side benefit to this lamp is that it is switched on with the headlights. For those of us who want to add a Homelink mirror system, that circuit could be tapped into for the auto-dim feature of the mirror.
  17. GoMetricToday
    GoMetricToday 42 is the answer to the ultimate question.
    64
    Erwin, TN
    I rather like the light. As others have posted on here it isn't really that bright. Just enough light to see the shifter. I have very good peripheral vision and I don't find the light distracting.
  18. tomstodola
    tomstodola Member
    129
    Ontario, California
    2019 Prius Prime
    Nice suggestion, except if the mirror has a compass, then it will only display when the lights are on.
    I actually appreciate the small LED light for some of the same reasons as previously stated. The joystick does not have a lighted indicator on it, so in a dark car you could accidentally hit the lever and drop the car into neutral (at least if you hit it into reverse accidentally the annoying beeping would let you know it!).
  19. Beauregard
    Beauregard Member
    89
    25
    Colorado
    2015 Prius c
    A small round Band-Aid.........
  20. Metalman
    Metalman Member
    107
    17
    Insert a 1K ohm resistor in the circuit just before the LED. That will dim it. If not enough, go to a larger value resistor.
