2010 Prius problematic?
Discussion in 'Gen 3 Prius Main Forum' started by Marlowe, Feb 3, 2011.
  1. Marlowe
    Marlowe Junior Member
    NY
    My beloved 1991 Saab 900 has gone past the point of no return so I am now looking for a used Prius. I'm attracted to the Prius for the low maintenance as compared to the old Saab and, of course, the fuel efficiency.
    I've been looking at very low mileage cars ranging from 2008 to 2010. Ideally, I'd like a 2010 Prius with the amenities such as leather, etc. My concern is the high volume of complaints I'm seeing with the 2010 models specifically.
    Looking over here:
    www dot arfc dot org slash complaints
    I see the 2010 Prius has made #16 on the top 25 list of most complaints. When I look at the actual complaints I'm reading scary stories about people braking and the car lunges forward instead.
    What is this all about?
    Also, on the 2009 and 2008 models I'm reading about the brakes failing momentarily when running over rough road such as a pothole because of the ABS system.
    Should I steer clear of the 2010's? Also, how concerned should I be about the braking issue on earlier models?
    Thanks,
    Marlowe
  2. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    I have a used 2010 with about 6500 on the odom. I've personally driven it about 1500 of those miles and have had NO problems with braking or ABS. That being said, the regenerative braking takes a little getting used to. The way I understand it is that if you press lightly on the brakes, the car is being slowed via the regenerative system...NOT the brakepads on the rotor. It's only when you brake more aggressively that the conventional brakes are applied.
    As for the earlier models, all I can say is that I know someone with a 2008 who has had it for about 6 months with no issues...braking or otherwise.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Before Toyota released a TSB on it, the Gen III used to produce a scary feeling when braking over potholes where it feels like it accelerates momentarily (but doesn't really) while it switches from regen to friction braking. It's now been shortened to the Gen II's level and isn't as scary anymore, but there will always be people unfamiliar with the technology complaining about it. Don't be one of those ignorant people.
    This is of course assuming you're not that GM exec "Marlow" :cool:
  4. ETC(SS)
    7,226
    :welcome:
    I think that the Prius has it's little flaws, but the reason that it ranks 16/25 in complaints is more driver related than car related. I'm not the biggest Prius cheerleader on the forum, but if you get a good used Prius (G2 or G3) then you'll have a fairly reliable and veery fuel efficient car---if you take time to get to know how to take advantage of it.
    Spend $250 bucks and rent a G3 for a weekend. Hertz rents them.
    There are (*) ah.....little quirks in the Prius driving experience that you'll want to explore fully before pulling the trigger on a G3 (2010 and up is Gen-III or 3rd Generation.) This won't help you out much with the G2----but it will give you a good baseline to compare the G2 with.
    Either way....it's going to be faaaaaaaaar more reliable and cheap to own than any Saab. Sorry bout that if you're a fan of the Saab.
    Low mileage, up-uptioned G3's (and G2's) are out there.
    IMHO----the G3 is the 'better' car (for me, and only IMHO), but the G2 has a little better build quality. Drive both, and you'll see what I'm talking about.
    Good Luck!
  5. duffasaurus
    duffasaurus Senior Member
    177
    Charlotte, NC
    The complaints you read about here are only a very small sample of the extemely "satisfied" Prius owners, numbering in the millions, worldwide. I personally have three Prius, 2007, 2009 & my favorite one 2010. I have had no problems with any of them & feel that the majority of so called "complaints" are based on perceptions felt by users who are not use to driving a hybrid vehicle. You will be satisfied with any Gen. II or III Prius you decide upon, if only for the high mpg & low maintenance costs.
  6. bisco
    52,093
    i feel like i have seen more complaints with th 10 than i saw with the 04 which was first year of gen II. but it seems most of them are about squeeks and rattles and dead 12v batteries than anything serious. it's very difficult to quantify but, it seems most people are very happy. all the best!:)
  7. Seamaster
    Seamaster Member
    123
    70
    GB
    2019 Prius
    Excel
    "Problematic" cars don't become best-sellers.
  8. Marlowe
    NY
    Thanks for the reassurances. It makes sense that some of the complaints would have to do with drivers not being familiar with the Prius driving experience.
    Still, have any of you heard of the situations where the car lurches forward when applying the brakes? Not the ABS thing but rather a more serious lunge that has ended up in accidents?
    Marlowe
    PS I'm not the GM guy. I won't even buy an American car due to a Ford nightmare. I'm all about Toyotas and Hondas at this point.
  9. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Welcome to PriusChat and best wishes as you research what car is best for you.
    Like you, I researched extensively before buying my Prius. I heard/read all the same complaints, recalls, TSB, etc, but I bought anyways. I've never looked back, never regretted my decision and I'm absolutely in love with my Prius!
  10. bisco
    52,093
    only the few instances reported here, but just like u/a, how can you judge it if you haven't experienced it and it isn't reproduceable?
  11. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    That's pedal confusion, where the driver mistakes the gas pedal for the brake. Nobody has been able to prove unintended acceleration in the Prius. Better wait for the NASA report ;)
  12. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Hey, didn't lottamoxie recently go from her old Saab to a new Prius? Maybe she can pipe in here about her experience in here to give you a bit of perspective.
    One thing I can say about driving Prius vs other cars; If you're the type to just get in a car and drive without being concerned or aware whether you're driving a hybrid, then you might be initially disappointed because I can guarantee it will be a different experience. It won't go or stop like your previous car or any other non-hybrid on the road. As long as you're aware of that, and once you become acclimated to driving a hybrid, you'll have a great experience. I let my friend drive mine last night because I didnt' feel like driving at the moment. He got in and tried to drive it like he was driving his truck; floors the gas when taking off and no coasting to a stop sign or light - and yet complains it doesn't drive right?:rolleyes: I should've switched from ECO to PWR mode!:D
  13. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    :popcorn:
    The Troll call-out award goes to 32kcolors, congratulations.
  14. s1njin
    s1njin New Member
    106
    Sellersville, PA
    I've experienced what feels like a momentary (VERY short) surge sometimes while braking. Usually manifests itself when going down a hill and feathering the break to get the regen but not the pads. Than sometimes I have to actually 'get on' the brake because a light changes or somebody in front of me is a bone head. Every once in awhile I feel a short push before it 'grabs'.
    Never was sure what it was. It never makes me feel unsafe, and the car always stops with authority when required. But it is weird.
  15. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    It's unfortunate that the OP's screenname is so similar to malorn, but now that evpv has posted, people better tread carefully!
  16. wogue
    wogue Lexus CT200h
    61
    EU/Austria
    Isn't the brake issue a typical us-(made)-problem?
    It was written in lots of european newspapers that even the nasa found that out.
    EU Prius don't seem to have that... :D ... so far. ;)
  17. LeadingEdgeBoomer
    289
    29
    New Mexico
    The OP has raised many subjects, albeit indirectly. Please search for gigantic threads on some of these subjects. My thoughts:
    1. I needed a new car, but the more I learned about the then-upcoming GenIII, the more determined I was to wait for it. Good decision, yours may vary.
    2. Brakes: I knew about the regen->ABS transition before buying the car. As soon as I got mine, I found a downhill washboard and experienced it. I thought, "Huh, different." At no time was I duped into thinking there was acceleration. Since then a software fix has hastened the transition. No worries.
    3. Widespread publicity has engendered "They'll pay me off if I complain" people to do just that--hence the skewed statistics. This is a litigious country.
    4. Driving like another car: Mine does, recognizing that it is not a powerful beast, but a handsomely-engineered marvel.
  18. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    What NASA report? So far as I am aware there is no NASA report being done on this issue.
    NHTSA announced several investigations last March. U.S. Transportation Secretary Ray LaHood Announces Major Investigations to Resolve Issue of Sudden Acceleration | National Highway Traffic Safety Administration (NHTSA)
    None of these is a NASA report though for the NHTSA review of electronic throttle controls in Toyotas that they were going to getting help from some NASA engineers amongst other people
    It is 6 months after the proposed completion date (Last summer)and I don't recall seeing a report or update from them. Have I missed something?
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    The LA Times has reported that a comprehensive report by NASA on the causes of SUA is expected early this year.
  20. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    You might want to search for some statistics posted on PriusChat a while ago, indicating about 40% (???) fewer fatalities overall in the Prius than in the average car--I think that included experience with Gen III.
    To me, that's the bottom line on safety.
    Truthfully, I think the biggest Prius safety flaw is poor visibility to the rear, esp. on passenger side. If you are a more regular, instinctive user of right side mirror than I am, it probably won't bother you at all.
    The Prius is, as some folks have said, a bit quirky, but hey, you are coming from a Saab, right? From everything I've heard about them (great but weird), you should do fine in a Prius.
