Brakes Go out under 5mph then lock.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by norvelltodd, Feb 3, 2011.
  1. norvelltodd
    norvelltodd Junior Member
    Madison, Ohio
    Has anyone had this issue. As I am rolling to a stop and get just under 5MPH it feels like I am at the bottom of the brake pedel travel and that there isn't enough travel to stop the car. Almost like the brakes have gone out. It rolls a few feet after feeling like that and then the brakes just lock up. No bumps, not going fast, 30,000 miles on it. It is a 2010.
  2. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    Just a feel thing? Did you get the ABS flash done?
  3. RufusNapkin
    RufusNapkin New Member
    36
    Worn brake pads.
  4. norvelltodd
    Madison, Ohio
    Yes, I got the flash done. It isn't like this has been happening for a long time. Just started in the past month. Maybe related to the cold. I have felt the jumping problem too but this is unrelated.
  5. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    pump the brakes
  6. norvelltodd
    Madison, Ohio
    I asked a technician and he said the pads should be fine and that I shouldn't have to do anything with the pads till about 100,000 miles
  7. norvelltodd
    Madison, Ohio
    Pumping the breaks seems to work but why is it happening, is a caliper sticking?
  8. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Under 5 mph, it switches to friction braking. Is that what you're feeling?
  9. norvelltodd
    Madison, Ohio
    I think that is what I am feeling but it feels like the friction brakes are not working properly. When I brought it in, they said they had to replicate the problem for them to diagnose it. I think since it warmed up a bit today, it wouldn't replicate.
  10. bisco
    52,385
    could there have been ice on the discs?
  11. norvelltodd
    Madison, Ohio
    That is more of the answer that I was hoping for. That would mean I fdon't ahve a problem.
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I have had this happen to me once. The big question: did you have any lights go off and or beeps?
    Last year about this time I hit a sharp ridge of ice about 3-4" high approaching a heated crosswalk. As soon as I hit it (about 10-12 mph) my brake pedal sank to the floor (bottomed out) and warning lights went off and beep twice. I came to a stop half way through the walk. Scary. I took it in for the ABS update and have not had it happen since.
  13. qbee42
    3,079
    Most likely your friction brakes were icy or dirty. They don't get much use on a Prius, and as a result often end up a bit rusty or dirty, especially if you drive in winter conditions or near salt water.
    You might want to try cleaning the brakes by forcing them to work. Try this on an empty road:
    1) Accelerate up to about 45 mph.
    2) Shift to N.
    3) Brake until you are going around 20 mph.
    4) Shift to D.
    5) Repeat.
    Do this a few times and see if your brakes don't feel better. It will wear off some of the rust and dirt.
    Btw, if you are a software engineer, systems person, or Canadian, stick a loop counter and escape clause in that loop; otherwise you will be stuck there until your Prius runs out of gas.
  14. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    What about some air in the brake lines, which would only show up below 6 mph, and might be sporadic depending on temperature??
  15. cossie1600
    903
    94
    CT
    We have air brakes?!? Wow
  16. mainerinexile
    403
    73
    Maine
    A bubble of air in the brake line fluid.
  17. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    The OP described it as running out of pedal travel, as in the brake pedal going to the floor. Rust or dirt accumulation would do the opposite, the pedal would be higher than normal and feel firmer.
    Sounds more like worn out pads, fluid level problem, or electronic malfunction. Take it to the dealer ASAP. Make sure they write up the complaint and symptoms in case you have more problems in the future.
  18. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    You've got to take the car to your dealer for brake system inspection. As folks have said it can be anything from nothing to brake cylinder to dirt. Get it checked out.
  19. qbee42
    3,079
    Agreed, but ice would do the opposite.
  20. seegarman
    seegarman Junior Member
    49
    Seattle
    The symptoms you described are scary at best. I feel a defined transition from regen. to friction brakes around the 5-7mph mark with my 2010 since new. As the car approaches the transition speed while I apply brake pedal pressure constantly and smoothly, the brakes feel like the stopping effectiveness is steadily decreasing and I will never stop in time. To combat that occurrence I press harder on the pedal and when the friction pad finally engage, the braking rate dramatically increases and I come to an abrupt stop. I try to stop smoothly with all of my cars which seems impossible with the braking system design on the GIII.
    At this next oil change I will bring this up with the Toyota tech people but you know how that is going to go.:rolleyes:
