Aftermarket / Portable GPS in Non-Nav Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by telefrog, Jul 8, 2009.
  1. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    How did you wire your power to it?
    Thanks!
  2. atrix415
    atrix415 New Member
    SF
    Car battery? This is how I wired my deck in my old car.
  3. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    OK. Where exactly did you run the wires in your 2010 Prius? To be more specific, did you remove any panels? Which ones and how did you remove them? Did you go under the car to get to the battery in the back, or did you route the wires some other way, like maybe to the fuse box?
  4. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    Hi guys.
    I know this is the 2010 Prius forum, but I have a 2007 Prius, and I want to put my Garmin right on the drivers side little window just like this thread shows.
    At the risk of looking foolish, how did you do it? Is the 2010 little window less deep then my 2007? When I attempt to attach the garmin suction cup holder with the ball end to the window, the garmin will not go on it......like the arm is WAY too short. Is there a different arm I could buy, or an attachment to bring it out farther?
    That is the perfect spot, but how can I do it on my 2007? Thank you in advance for your help.
    Frank D.
  5. Mike's Prius
    Mike's Prius New Member
    New York
    Tfrog...how difficult is it to pull that vent panel out for wiring near the small window?
    mike
  6. Pigs
    Pigs derp
    Arkansas
    I would really like some more pictures of this install please. Can you post the whole cable run from start to finish please?
