Reverse Popping Out
Discussion in 'Gen 3 Prius Main Forum' started by cedosada, Feb 8, 2011.
  1. cedosada
    cedosada Junior Member
    25
    SF Bay Area
    Anyone else experience this? It has happened about 4 times. Most recently this weekend. Driving around the non-hilly part of SF. About 80deg, tried to back up to parallel park and had to push it in revers 3x. Popped out twice after beeping and reversing for 2 secs, about 4 feet. Very slight hill going reverse- about 5 deg.
  2. cedosada
    25
    SF Bay Area
    Btw, braking during pothole bulletin already corrected. Still happens during hard potholes but not the small ones.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    My guess is you didn't hold it in R long enough to engage it and you were actually in neutral rolling down the very slight hill. Next time try holding the stick in R for at least 2 seconds in order to engage it (same with D).
  4. ETC(SS)
    7,350
    Make sure that you're completely stopped before engaging reverse.
    Yeah...I know. I've tried to park in Frisco before.
    No. I haven't had any popping out of reverse issues.....and I parallel park and use reverse a LOT, since my car is a company unit and we're somewhat required (requested?) to back into parking spots.
