Sportier wheel for a Prius V ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by captvon, Feb 6, 2011.
  1. captvon
    captvon New Member
    NORTH
    I'm not impressed with the 17' standard alloy wheel. Does anyone have after-market improved chrome 7 to 10 spokes? Pictures?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I'm a fan of Five Axis rims, S6-F shown, especially gunmetal on white Prius. Chrome is too blingy for me.
  3. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    Volk Eco-Drive are about as light as you can get. The forged versions are expensive but extremely light and strong, in 17x7 they should be around 15lbs each, stock is 24lbs. The cast versions are not as light at around 20lbs, but less expensive.
    The finish isn't chrome but it's close. Chroming the wheels will make them even heavier than the heavy stock wheels.
    Volk Racing Wheels - RE30 Eco Drive - Import DPS Online - Your Import and Sport Compact Performance Source - Free Shipping on all orders over $50
    Volk Racing Wheel Distributors
  4. Thai
    Thai Prius Neophyte
    1,197
    89
    I have heard that the OEM 17" rims, while a bit heavier (22 lbs i heard) than the forged rims, are designed specifically to be aerodynamic. So, if true, then putting on a lighter rim may not be any better from the fuel economy side. True or false??
    Anyway, i actually love the OEM rims, but then again i am bias. :D
  5. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    Actually, I have a III with the 15" covers removed and have noticed no drop in mileage. The 15s are definitely "not" aerodynamic and I seem to be getting better mileage than a lot of people on this forum.
    Maybe it's because I started with a muscle car in the sixties and now at 61 y.o. I don't need the drive aggressively anymore. I too love the 17" but think you have to take a mileage hit for weight and tire width. I'm considering some 16s in a year or so.
  6. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    That's the hypothesis based on the worse mpg hit that people with lighter but less aerodynamic 17"-19" rims seem to get compared to OEM 17", but we don't know until someone conducts a scientific test on it.
  7. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Wedssport makes very aerodynamic rims and have been proven to get better mpgs here on the forums
  8. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    The aerodynamic drag of a wheel isn't a frontal surface, it's just dirty air passing along the side of the car. So it's unlikely you would even be able to measure the difference.
    The width of the tire is a much bigger factor because it increases rolling resistance and aerodynamic resistance.
    The weight of the wheel will not make a huge difference for normal applications like a family commuter car. Rotational mass is more detrimental than static mass, so a lighter wheel does make the car accelerate/brake slightly easier. Saving 5lbs on a wheel is more beneficial than saving 5lbs out of the chassis.
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
  10. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Maybe. A poster upgraded from stock 17" to less aerodynamic aftermarket 17x7s that were 4lbs lighter than factory 17" and saw no improvement in mileage. Another poster with lighter 18x8s with multiple, narrower open spoke design suffered a 3 mpg hit.
    Then there's a group here who swear the 15" wheel covers make a difference at freeway speed.
    Would be nice to do some scientific tests.
  11. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    The 18x8 is an inch wider so it will have more aero drag. And the tires were probably wider as well, causing more rolling resistance. Those conditions will undoubteldy contribute to lower fuel economy.
    But aero drag on the face of the wheel isn't a big factor until you get to very high speeds.
  12. unkprius
    unkprius Member
    152
    Probably doubtful any organization would put that much effort into this. But, if one had access to a precise fuel meter and a few m-80's with long fuses, they could run the car on a level surface at 65 mph then blow off the hubcaps and see if the instantaneous mileage changes. :boom:
  13. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yes, but it didn't cancel out the reduced unsprung weight which is also a big factor. It also doesn't explain why the mpg didn't improve upon upgrading to lighter but less aerodynamic rims in the stock size.
    Aero drag on the side of the wheel likely also becomes a bigger factor at freeway speed, but someone has to do some testing to confirm.
    Very funny. All you need to do is do some runs with wheel covers on and some off (which serves as a control).
  14. shawnb2
    shawnb2 Active Member
    533
    107
    22
    Thousand Oaks, CA
    Now just to give you an idea. I had the Enkei EKM3's in a 17x7 on my car for about 7 mos. and I didn't lose anything in the way of MPG's. The factory 17's are about 24lbs. The Enkei's are 20lbs. each. Now my new wheels which weigh only 20lbs. as well are Wedssport 19x8's and I knew I'd take a hit but wasn't overly concerned. It's all about the look and stance and either way it's still way above what I would have ever have gotten in my old car. I lost 5-6MPG's. For those that were interested before and maybe new people in the So. Cal area, I have finally decided to put the Enkei's up for sale. Hit me up if interested. Will be posting them in the for sale section probably by tomorrow.
  15. yadax3
    yadax3 Member
    237
    22
    Northern Nevada
    I've never experienced a big hit to my MPG since replacing my 15" OEM wheels/tires with 17" wheels/tires. Maybe 1 MPG at most but nothing like what people have described on these forums. And I've installed the same 17" aftermarket wheels on 2 different Priuses. In fact, my MPG dropped more when I changed out the tires on my 2007 Prius for all-seasons with good snow tread.
  16. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    Did you go with 215/45/17 tires?
  17. yadax3
    yadax3 Member
    237
    22
    Northern Nevada
    Yes.
  18. andino
    andino Senior Member
    746
    551
    San Jose, CA
    I switched from the stock 15"s to 17x7 wheels with non-LRR tires and took a 5mpg hit. Seems to make a small difference but if you already hypermile, it doesn't seem to be much difference.
