2007 Gen 2 Prius DEAD HV BATTERY
Discussion in 'Gen 2 Prius Technical Discussion' started by captmarshall22, Feb 9, 2011.
  1. captmarshall22
    captmarshall22 New Member
    29
    florida
    I have a 2007 toyota prius. The car drives, but pulsates. The Check engine light and triangle of death are on. Diagnostic test says "replace hybrid battery pack", but wouldnt the car not even start if the bat pack were dead?
    Any ideas to what it could be? perhaps a bad cell or two? a bad ecu?
    I have tried to get toyota coporate to assist, but its been a week now and no call back after multiple attempts.
    I may just try and re-build or replace on my own...Renting a car at $50 a day is draining me!
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Is there a particular reason for starting another thread on this?
  3. captmarshall22
    29
    florida
    yes. 1. to find a true answer as to waht is wrong with the battery.
    if it were dead, the car wouldnt run at all.
    2. to find someone capable of fixing it locally
    3. so toyota can hopefully see this thread and finally help me out! the car is 3 yrs old!
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    Santa Fe, NM
    Unfortunately, this is not the case. What you have, most likely, is a bad cell in a bad module. This cell is basically a resistor now, not an open. If you ask your dealer for the freeze frame data, it will show V1-V14 and you will most likely see that V5 is more than 1.2V lower than the rest. Thus, instead of 240V you may have 238.7V, which is plenty to spin start the ICE.
    The alternative, a bad sense wire and/or terminal corrosion, still means that you need to remove the battery and inspect it.
    Have you tried either of the two suggestions so far? A third would be an Enginer installer, I think there is one in greater Miami.
    I wish you success.
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    I noticed in your other thread that the first symptom you mentioned was "pulsating". I think that's an unusual symptom for a dying battery.
    Can you tell us a bit more about how the car drives. Normally when the traction battery is dying people experience very rapid swings in the state of charge (purple blue green 8 bar display) and loss of power with lots of revving of the engine to get anywhere. Pulsating is not usually something that's mentioned.
  6. captmarshall22
    29
    florida
    hello all...thank you for the replies.
    symptoms are as follows:
    car turns on, triangle of death and check eng light show (in addition to another light that resembles a low tire pressure).
    The battery will usually show full with light green bars. Then as i drive, it will show half full with dark blue bars. All of a sudden it will drop to one light purple bar.
    As for the way it drives....It will drive fine for 4-5 minutes, and then, the acceleration will drop, the engine will revv, and even if i put my foot all the way down on the gas petal, the car will SLOWLY accelerate......VERY SLOWLY.
    I then have to stop the car, re-start, and its fine again, for a few minutes...until the whole process repeats.
    I have NOT removed the battery or inspected it for any problems..I dont know how. However, i JUST purchased the "how to rebuild a prius battery pack" manual, so when that arrives, hopefully it will help.
    I would rather find a professional locally who can fix the car. Does anyone have a connection in South Florida??
  7. captmarshall22
    29
    florida
    I called the dealer, they ran a diagnostic test....i asked for the FREEZE FRAME data, they said they had no clue what i wanted, and they didnt have any addl info. This was ed morse in delray, an authorized toyota dealer. However, i had a friend who is a mechanic run a diagnostic, he is saying its "cell 5" as you mentioned.
    Now..the big ???...how do i know which one is cell 5, get to it, remove it and replace it?
  8. dogfriend
    7,512
    1,185
    Carmichael, CA
    I have to ask:
    Mileage? Why wouldn't you get it repaired under warranty? 8yr/100k.
  9. captmarshall22
    29
    florida
    mileage is 104,000
  10. dogfriend
    7,512
    1,185
    Carmichael, CA
  11. Patrick Wong
    18,200
    6,471
    1. I suggest that you subscribe to techinfo.toyota.com so that you can access official repair manual info and the safety warnings associated with this job. If you are not careful you could kill yourself.
    2. I also suggest that you invest in a quality digital multimeter so that you can accurately measure voltages.
    3. You'll need to remove the traction battery from the car so that you can disassemble it. #1 will tell you how to safely do this.
    4. Once you have removed the top cover of the battery, you can use the DMM to measure voltages of each of the 28 modules. You will find that one module shows lower voltage compared to the other 27. That is the one that has failed.
    5. You can try to replace that module with one that you can buy off eBay but that is likely to be a short-term solution since the module that you install may not have similar capacity as the other 27.
    6. Hence, the suggestion that instead you buy an entire 2G salvage battery assembly, which may cost you ~$500 plus shipping. Good luck.
  12. seilerts
    3,326
    1,512
    Santa Fe, NM
    Yes, you have a bad battery. When the battery suffers a fault, it stops all current flow back/forth to the inverter. This means that the engine is the only source of motive power, so it runs very fast in order for MG1 to supply current to MG2 in order to move the car forward, but the car is now a turtle.
    Salvage is half the price of Reinvolt.
  13. seilerts
    3,326
    1,512
    Santa Fe, NM
    This may be true for Gen 1. Gen 2 modules are more robust. Since this battery already has 100,000 miles on it, it is not likely that a replacement module would have significantly less capacity. On the other hand, it is a good idea to replace modules in pairs with matched state of charge, so that the HV battery ecu is not trying to maintain balance on stronger/weaker/higher/lower modules that are in series.
  14. bisco
    49,379
    i would go for the rebuilt battery. you got 100K out of the first one, that's not too bad.
  15. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    How about a strategy of buying say 10 pairs, and using the pair that matches the old battery? How close in voltage would very good have to be ?
  16. seilerts
    3,326
    1,512
    Santa Fe, NM
    For the price of 10 pairs online, you can buy a whole salvage battery assembly from a junkyard.
    The idea of using a matched pair depends much on getting a matched pair from the seller. Modules coming out of the same battery are the best, but modules that have comparable amp hour capacity as determined by load/discharge test also work. Best practice is to charge the replacement modules to full, then discharge in series to the approximate voltage level of the other batteries in the string. The hv battery ecu will take care of the rest.
  17. captmarshall22
    29
    florida
    thanks for all of the feedback....after being completely blown off by toyota customer support, 5 days of "we will have an agent call you within 24 hrs" and no response...i have decided to go with a local shoppe here in South Florida. The name of the shoppe is Mellors Automotive, i am dealing with Josh Mellor...He was referred to me from the VERY HONEST and kind folks at re-involt. The car is being shipped to him today from my home, and hopefully it will be fixed by early next week. Ill post the results next week...Thank you all for the generous replies and assistance!
  18. seilerts
    3,326
    1,512
    Santa Fe, NM
    Excellent! Please do follow up and post pictures!
  19. captmarshall22
    29
    florida
    i will post all results as soon as i have them! car is being transported to the shoppe today. Toyota finally called me back last night and said, "Sir, your warranty is to 100,000 miles..although the issue occurred at 101,000 miles, that is 1000 miles over your warranty, therefore, we will not assist at all, sorry" Unbelievable! I currently own two priuses and just had my lease on my toyota tundra expire.....As a loyal toyota customer, i really thought that they would have done something to retain my future business.....oh well! Next time i buy a new car i may reconsider....and..little did they know, i am in the PR business....I have influenced about 20 of our clients to buy a prius since 2007....those days are OVER NOW! Lack of efficient customer support was such a bummer..especially from such a large multi-national corporation.
    Am i wrong? any valid contributions would be appreciated
  20. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Hi there, in previous thread you wrote :
    It's a shame that the symptoms at 99000 were so vague otherwise you might have had reasonable grounds to insist that the issue started before 100k. Unfortunately though, to me a description like "subtle shaking" doesn't really give any indication of a battery problem, which kind of makes it looks like a separate problem. Did you notice any other symptoms during 99000 mile incident that were more indicative of a battery problem? (like the ones we discussed earlier).
