Navigation ETA Incorrect
Discussion in 'Gen 3 Prius Audio and Electronics' started by Prius4all, Feb 9, 2011.
  1. Prius4all
    Prius4all Junior Member
    SoCal
    I switched the display on my navigation to display the ETA assuming that it would use the vehicle time as the base but it is an hour off. I am supposed to arrive an hour later then I do according to the ETA. I tried to find a setting for the time in the Navigation system in case it is using a different clock but couldn't find it.
    Has anyone else had this problem?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    There's an on-off setting for Daylight Saving Time under Setup > Clock. Moreover, the time zone can be changed on this same screen.
  3. Prius4all
    SoCal
    I have the correct Time Zone and Daylight Saving is set True. So the Navigation doesn't recognize the Daylight Saving setting? Is that setting new to G3?
  4. Prius4all
    SoCal
    Turning Dayling Savings OFF worked BTW.
  5. Rebound
    Rebound Senior Member
    3,991
    2,638
    Portland, OR
    Why would you need to tell a GPS your time zone? Oh, I suppose if you live right near a timezone boundary, you might not want the clock to change every time you go to the grocery store. Is that why?
  6. 2010P3
    2010P3 New Member
    Maryland
    When you set up your Navi, you can tell it what speeds you drive. It automatically sets those speeds (fairly accurately for me), but maybe your driving conditions are far different from the ones they pre-programed.
    You can check your owner's manual for more information about setting up your navigation system.
  7. dkelly
    dkelly Member
    118
    Gilbertsville, PA
    GPS transmits UTC time. All GPS units need the ability to convert to local time.
  8. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have found out that during the trip, the Nav will adjust the ETA based on your actual speed versus the programmed speed.
  9. macman408
    1,179
    367
    Really? I've found the opposite - for example, a road that had apparently been misclassified as a "main street" instead of a "freeway" in the system (or perhaps the speed limit had increased – HA! – since their data was collected). As I continued down that road, I would tick off about 3 minutes from the ETA for every 2 minutes of driving, or something in that range.
    In any case, the nav is way more accurate than my off-the-cuff estimates, even if I happen to know the driving distance. Usually.
  10. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Aren't we saying the same thing? When the ETA ticked off 3 minutes for every 2 minutes of driving, isn't this the Nav adjusting the ETA based on actual speed ?
  11. macman408
    1,179
    367
    I'd say it's not adjusting the ETA based on actual speed at all, other than the secondary effect of recalculating based on the current distance to the destination; say I'm going 60 mph, my destination is 60 miles away, and the Nav thinks the speed limit is 30 mph. It thinks the ETA is 2:00 (instead of 1:00). In one minute, I'm now 59 miles away, and it thinks the ETA is 1:58 (instead of 0:59). In 30 minutes, I'm 30 miles away, and it thinks the ETA is 1:00 (instead of 0:30). It obviously still thinks that the speed limit is 30 mph. It's not doing anything at all with your current speed; it's just that it recalculates continuously based on the distance remaining. It doesn't set the ETA when you start driving and just tick off minutes one-by-one.
    If it adjusted the ETA based on actual speed (and not just distance remaining), I'd expect it to figure out that I'm going 60 mph on this road instead of 30, and eventually chop off that extra hour all at once. I don't really expect this intelligence from a GPS, though, perhaps at least partly because there would be too many opportunities to get such an adjustment wrong.
  12. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I agree that yours is a better explanation in that it is recalculating distances and not adjusting on speed. Either way it is adjusting ETA as you travel.
  13. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    The Toyota Nav system is just not as sophisticated as a Garmin, Tom Tom or Magellan - after all, it only costs 4 times as much. The answer is, of course to manually (there is no other way) turn the Daylight Savings Time off in the winter and on in the Summer, making sure the Time Zone is correct.
