Which year Prius is the most reliable according to Consumer Reports?
Discussion in 'Newbie Forum' started by BentSpace, Feb 10, 2011.
  1. 1997
    0 vote(s)
    0.0%
  2. 1998
    0 vote(s)
    0.0%
  3. 1999
    0 vote(s)
    0.0%
  4. 2000
    0 vote(s)
    0.0%
  5. 2001
    1 vote(s)
    5.3%
  6. 2002
    0 vote(s)
    0.0%
  7. 2003
    0 vote(s)
    0.0%
  8. 2004
    0 vote(s)
    0.0%
  9. 2005
    2 vote(s)
    10.5%
  10. 2006
    0 vote(s)
    0.0%
  11. 2007
    2 vote(s)
    10.5%
  12. 2008
    9 vote(s)
    47.4%
  13. 2009
    1 vote(s)
    5.3%
  14. 2010
    3 vote(s)
    15.8%
  15. 2011
    1 vote(s)
    5.3%
  1. BentSpace
    BentSpace Member
    195
    Reno
    Just wondering if someone with a CR subscription could tell us which year Prius got the highest reliability rating and overall rating according to their detailed reports that you must be a subscriber to see. If possible, if someone could post the whole report that would be more than awesome. If not, just the conclusions would be much appreciated. Thank you.
    52,284
    i don't have a cr subscription, but i'd be surprised if there were a year better than others. we've had zero problems with our 04 and 08 and everything here seems pretty random. 2010 rattles might be the most consistant thing i've seen.
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Search my posts from within the last year
  4. BentSpace
    BentSpace Member
    195
    Reno
    Thank you.
    I saw your clip in Drill-down Feature in Consumer Reports which was exactly what I was looking for except if it was zoomed out a little so the rest of the dots are visible. Maybe I'm asking for too much, sorry.
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    07 thru 09 appear to be the most reliable. There is not enough data to predict the reliability of the 2010.
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    CR says that the 2010 has brake problems! (the dreaded black dot). There must be a problem because the average guy saw the reports on TV.
    Do you want to buy the year with the least problems? The problem with buying a used car is that it's used and older than a NEW car. That means you will have more problems with an older car than with a newer one.
  7. macmaster05
    macmaster05 Senor Member
    4,050
    730
    07-09 is a solid choice. but it's mostly just luck.
  8. BentSpace
    BentSpace Member
    195
    Reno
    Yes, exactly.
    True, wish I could afford a new car. Did you know though that the average new car loses half it's value after the first 3 years. Probably not that bad for a Toyota.
  9. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    The older the car the less reliable. So it's tough to judge. I recall every Prius model year was very reliable in CR up to the Prius II, thru 2009. More than any other car model.
    The Prius III apparently had a brake problem--not unusual for a first year model--even a Prius.
    The Prius II is as good as it gets.
  10. qbee42
    3,079
    2018 is supposed to be a really solid model year.
    :rolleyes:
  11. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    Why is this a 'poll'? You are asking for actual information.
  12. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  13. BentSpace
    BentSpace Member
    195
    Reno
  14. macmaster05
    4,050
    730
    If the electrical of the 2010 is better then why does it throw codes when installing LEDs on the license plate.
    The subpar electrical ratings for 07-09 could be a few ppl reporting problems with HIDs but that doesn't mean the ecu is better on a 2010.
    I still think it's more a matter of luck.
  15. bisco
    52,284
    so, 08 is the best year?
  16. mainerinexile
    403
    73
    Maine
    The year that you own, whatever that is, is the best year!
  17. bisco
    52,284
    exactly!
  18. SageBrush
    11,627
    2,533
    Southwest Colorado
    It is useful to know details about 'problem' categories. E.g., the '04 has fuel system complaints related to partial filling of the tank bladder in cold weather. The solution is to fill at a slower rate, and so in my opinion for my car is not a problem at all.
    2) I am not sure why the '04 has a black mark next to audio and electrical. Perhaps it is related to a run of MFD's that Hobbit learned to fix. By now either it is not going to occur, or it has been fixed.
    3) I think the '06 - '08 run has had a spate of HID failures, but now that Toyota picks up the tab for light replacement owners really don't care.
    4) 'Engine Cooling' might refer to inverter coolant pump problems. Again, this replacement is either a <$100 DIY job or can be handled by Toyota for free, so who cares ?
    Bottom line: the G2 from its first year onward and the G3 are paragons of reliability. There is no specific year to avoid, so buy according to the merits of the individual car.
    * Avoid accident cars
    * Avoid flood cars
    * Think twice about cars that have lived in extreme climates
    My car is an '04, now with about 123k miles
    Repairs: 0
    Problems: 0
    Trips to the dealer: 1 (prophylactic engine coolant flush after I foolishly added some crappy anti-freeze.)
    Maintenance: easy and inexpensive DIY. About $50/year
  19. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    The CR rankings are cumulative, meaning newer cars will automatically get higher ratings due to lack of history.
    In other words, I believe the jury is still out on the 2010 as far as the electrical ratings are concerned.
  20. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Nope. See Reliability histories. The average problem rates are listed at the very bottom.
    From the above:
    The scores they're referring to are the one of five dots under the key for reliability ratings.
