Is this normal? cracked seat already
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Cassandra, Feb 10, 2011.
  1. Cassandra
    Cassandra ELECTRIC VEHICLE
    57
    Victoria, Canada
    Is this normal? cracked seat already. Warranty covers!
    My 2010 has a bunch of cracks in the leather. The car only has wear of 45000 km. Is this relatively normal? How can I further prevent this from happening? Would something like this be covered under warranty?
    Turns out it's covered under warranty. :)
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Not normal, and should be covered under warranty.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Mines over a year and a half old (bought June 2009) and I have no cracks in my leather... Definitely take it into the dealer and see what they have to say.
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Pics please!!! Do you mean wrinkles or cracks?
  5. Cassandra
    57
    Victoria, Canada
    While I have no recollection of it I'm kind of worried it may have been my ring while I was rustling to use the lever, but I don't think so considering the cut at the far back. Does it look like excess wear cracking or somehow it got sliced? There are indeed a number of wrinkles from wear so I'm not sure.
  6. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    It looks like a split and not a cut. This has more jagged edges. Since it's on the side of seat, maybe it can be repaired? Is this this only instance?
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Looks like it was sliced by something to me; that does not look like wear.
  8. danvee
    danvee Blizzard Brigadier
    326
    53
    New Jersey
    If I remember correctly, the leather is only on the seating surfaces, so this area should be vinyl. It looks like it might have been damaged by a sharp spot in the plastic seat trim directly below it as you enter or exit the car.
    A vinyl repair probably wouldn't be a permanent fix as it's a stressed area.
    I'd take it to the dealer for their opinion and hope that they'll step up.
    Good Luck!
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  10. jdimetal
    jdimetal New Member
    52
    Fredericksburg, VA
    Does not look like wear to me either. Depending on your relationship with the dealership they may take care of it for you at no extra charge.
  11. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    It does not look like wear to me either. I bet you can have that fixed for less than $100 if you do some shopping.
  12. adamace1
    1,403
    193
    Charlotte, NC
    I would bring this to the dealer. I never had a problem with leather like that before.
    Is the leather install by toyota? Or the dealer?
  13. esoniat
    esoniat Junior Member
    79
    Marietta
    That doesn't look like leather to me.
    The straight very clean part of the "crack" to the right looks like a cut, remaining length looks like a tear resulting from the cut.
    I don't think a ring would tear leather, but it would cut cheap plastic simulated leather and that is what it looks like to me.
  14. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
  15. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    I agree with the above posts, only the seat and back inserts are leather. The advertising brochure calls them "leather-trimmed" seats. That split/cut is in the vinyl part, a good upholstery shop should be able to fix it.
    I don't think there is much chance getting it fixed under warranty but you could try.
  16. stream
    2,977
    452
    Long Island, NY
    Agreed.
    They are leather seating surfaces, like most cars in this price range.
    Warranty repair is unlikely.
  17. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    It's not just this price range. The more expensive Lexus (RX350/450, etc.) are starting to get them. I was surprised how much more soft vinyl is on the 2010 RX vs. leather and hard-backed high quality vinyl on the previous RX.
    But, yeah, I agree it's an user-inflicted damage.
  18. Cassandra
    57
    Victoria, Canada
    So I had a sit in the car and the seats wrinkle in exactly the places it's cut. Here's a pic.
    Also what about the tear at the very far back, that couldn't have been the ring also could it? I mean such a strange place, I just can't see me sticking my hand that far back.
  19. tumbleweed
    4,067
    691
    Eastern Oregon
    If you don't think you did it perhaps you should take it to the dealer and show them what your photo shows. Don't mention the ring to them or they will jump on it as the cause and you will never change their minds.
  20. adamace1
    1,403
    193
    Charlotte, NC
    yes take it to dealer ad let them know how you feel I would be pissed. You paid extra for something and it ends up being a worse product then the stock seats. Did this come from japan on the car or did the dealer install it?
